OME lift question
Discussion in 'Suspension' started by phil12382, Nov 22, 2014.
  1. Nov 22, 2014 at 12:21 PM
    phil12382
    phil12382 [OP] Active Member
    Phil
    Cols,OH
    08 4x4 dbl cab trd off rd
    Bilstein 5100's all around with OME 885s in front . 265/75/16. 5k hid, Fog 3k. Anytime fog light mod. Grillecraft upper and lower. Firestone airbags. Daystar Cradles. Illuminated 4x4 switch. Scan Guage II. LR UCA.
    what thickness spacers should you be running to get the full 3in lift with the 885's?
  2. Nov 22, 2014 at 3:54 PM
    xtyfighterx
    xtyfighterx Master Shredder
    Ty
    CDA Idaho/ Deadhorse Ak
    09 DC SW TRD OR/ 2015 tundra CM off road sr5
    3in lift, 5100s front and rear, OME 887 springs 2in aal, 285 75 16 Duratracs, mb 352 black wheels, white sport grill, derp'd lower valance, derp'd front toyota emblem white, tinted windows, tinted tail lights, trd shorty antenna, trd hitch cover, trd valve stem caps, trd neoprene covers, trd all weather floor mats, kenwood double din, stampede window visors, flyzeye interior leds, anytime fog light mod, flashlight mod, kool vue intake, LED dome light, Lund bug shield, TRD shift knob,front mud flaps removed, Debadged, truxedo roll up bed cover, led fog light bulbs, led parking light bulbs, led dtrls bulbs, led headlight bulbs, led back up light bulbs, led license plate bulbs, tinted license plate covers, 18" magnaflow muffler, 32in ebay, light bar, coverking neoprene resr seat cover, oem trd skid plate, trd decal on center caps, oem trd exhaust tip, blacked out pinch welds, color matched mirror covers.
  3. Nov 24, 2014 at 7:44 AM
    phil12382
    Phil
    Cols,OH
    its odd because im seeing a 10mm and a 13mm spacer then i see some that says 3/8 1/2
  4. Nov 24, 2014 at 7:55 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I have 1/2" w/ 885s
  5. Nov 24, 2014 at 8:55 AM
    xtyfighterx
    Ty
    Some run 1/2 others have 1/4 some have 1/2 on drivers side and 1/4 on passenger side
  6. Nov 24, 2014 at 9:14 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    10mm is essentially 3/8"
    13mm is essentially 1/2"
  7. Nov 24, 2014 at 9:18 AM
    xtyfighterx
    Ty
    If you,don't want to deal with top plates get 887 coils I just went this route it gives around 3in lift.
  8. Nov 24, 2014 at 9:32 AM
    phil12382
    Phil
    Cols,OH
    i already have the 885s on the 5100s and roughly got 2.5 but was going to just add the top plate spacers which should be fine correct? maybe ill just do the 1/2
  9. Nov 24, 2014 at 9:34 AM
    geekhouse23
