OME lift- Top plate spacers question
Discussion in 'ToyTec Lifts' started by Designated Hitter, Feb 25, 2012.
  1. Feb 25, 2012 at 5:55 PM
    Designated Hitter
    Designated Hitter [OP] Well-Known Member
    Daniel
    Orange County, California
    2011 TRD Sport DCSB 4x4
    I'm about to order the OME lift kit. I want to do the top plate spacers with it. My questions are:
    • What size spacers are these?
    • Will these account for the taco lean or do I need to get the trim packer in addition to the spacers?
    • With the 2" aal will I be level or close to nose high?
    I prefer level to a bit nose high rather than tail-end high. Will this get it done?
    2011 trd sport double cab short bed 4x4.
    Thank you for any input
  2. Feb 26, 2012 at 3:14 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You need to tell us what OME coils you are referring to.....
    There are many different types.
    Generally, it's NOT a good idea to run lift coils & spacers together.
    Get the proper amount of lift that you need in the coils - and you won't need spacers.
  3. Feb 26, 2012 at 3:21 AM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    Skip the top plates but do get the 5mm Taco lean shim
  4. Feb 26, 2012 at 10:48 AM
    Designated Hitter
    Daniel
    885 coils, sorry
  5. Feb 26, 2012 at 10:51 AM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I'm on 885x just get the 5m taco lean shim and you'll be fine unless you plan on adding a plate bumper then get the 886x and if you want the Bro lean get the 1.5" AAL instead of the 2"
  6. Feb 26, 2012 at 11:06 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    The 5mm trim packer for taco lean only works if you are getting OME shocks too .
  7. Feb 26, 2012 at 11:08 AM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    There ya go :cool:
  8. Feb 26, 2012 at 12:32 PM
    OZ-T
    Peter North
    British Columbia
    Some people people get the OME coils and 5100's and say they have an " OME lift "
    Just clarifying
  9. Feb 27, 2012 at 9:16 PM
    Designated Hitter
    Daniel
    Can I get the 1.5" aal w/out having the rear tsb?
  10. Feb 27, 2012 at 9:21 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    you can get them no problem the back of your truck will be about level with the front.
