OME lift wanting to add a top plate spacer and blocks in the back for little more lift
Discussion in 'Suspension' started by Omatac, May 8, 2015.
  1. May 8, 2015 at 4:15 AM
    Omatac
    Omatac [OP] Member
    Got the OME set up right now with a AAL in the back, everyone says spacers n blocks what not are bad. I just want a little more clearance maybe like an inch because when i noticed one day i went mudding got home and my fenders are being rubbed got all scratched up n took paint off. Guessing this happens at full flex 275 75s
  2. May 8, 2015 at 4:16 AM
    Omatac
    Omatac [OP] Member
    Any issues with just a 1 inch block n spacer?
  3. May 8, 2015 at 4:18 AM
    redtacoma88
    redtacoma88 Well-Known Member
    John Austin
    TN
    2012 TRD Off Road
    See Build Page...
    Ok.. I guess you could add a block in the back if you wanted to.. but in the front you dont want to go over 3" of lift.
    also remember
    that under full compression your still going to rub, the best thing to do is find out exactly where your rubbing the fenders and then trim accordingly
    Telkins88 likes this.
  4. May 8, 2015 at 4:51 AM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    The 1" more lift will not help you.
    And yes, don't go over 3" in the front. Where are you rubbing?
  5. May 8, 2015 at 10:32 PM
    Omatac
    Omatac [OP] Member
    No pics ATM but where the fender flares curve from the side of the car and tuck into the wheel well. Rubs in the middle maybe about 6inchs twords the back.
    Its not the plastic I'm worried about its actually rubbing on the painted body parts. Mahalos for all the tips
    Why not over 3? i know 6 is pushing it with stock parts. Help inform a noob :)
  6. May 9, 2015 at 11:29 AM
    teneighty
    Above 3" and your cv angles will be too extreme. A 6" lift uses a drop bracket to lower the Cv angles. Generally speaking 6" are for looks and 2.5"-3" are for offroading. Well, that's the consensus but both can be used.
  7. May 9, 2015 at 11:55 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    What's your current lift setup?
    Specifically coil numbers and AAL size..
