"OME" Lift What good buy or not
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bromagen25, Apr 17, 2011.
  1. Apr 17, 2011 at 1:18 PM
    bromagen25
    bromagen25 [OP] Well-Known Member
    Stock
    Rear Breather
    Just want to run this past all you all to make sure i am not forgetting any thing. Cheapest place i have found to get every thing in one go around.
    Iam getting the 886 because i am going to get a bumper some time a long with a winch. i know the ride will be rough. It also said in the ome section that it gives 1.75 in of lift i thought it was 3in of lift with the ome setup?
    How Much lift after all done and said do you think i will get?
    Do i need front extended brake lines as well?
    OME SECTION on wheelersoffroad
    (OME 90000 NitroCharger Sport Front Shock Set) $306.00
    (OME 886 Spring Set) $157.00
    (OME 05-Current Tacoma Leaf Spring Set CS047) $387.00
    (Wheeler's Bushing Kit for CS047 Spring Set ES CS047 BUSH KIT) $15.69
    (CS047 U-Bolt Set, 918212) $29.95
    (OME N182 Shock Set) $173.00
    (OME FK29 Driveline Packer Kit) $11.39
    (Tacoma Rear Brake Line Set BLINE-08X) $58.50
    (REV RTDD2-KB Diff Drop Kit) $24.00
    (Camburg 05-current Tacoma Upper Control Arm Set, Ball Joint Style 310039) $379.00
    Any thing i am missing or your thoughts?
  2. Apr 17, 2011 at 2:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The 886's should give you about 2.5" lift with the bumper and winch. mountainwolfpup is running the same set up, so you can PM him to see what he got.
  3. Apr 17, 2011 at 3:16 PM
    bromagen25
    Stock
    Rear Breather
    thank you
  4. Apr 17, 2011 at 3:36 PM
    DonnoD
    DonnoD Well-Known Member
    don
    las vegas
    07 dc 4x4 v6
    i just installed ome886 with bilstein 5100 set at 0 and got 3.5" of lift with allpro bumper no winch
  5. Apr 17, 2011 at 3:45 PM
    bromagen25
    Stock
    Rear Breather
    wow. OK that's great hope the same gos for the ome shocks. after they sag i hope to get 3in.
  6. Apr 17, 2011 at 3:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The AP bumper doesnt weigh much, so you could have gotten 3" lift (or close) with teh 885's and had a better ride.
  7. Apr 17, 2011 at 7:23 PM
    DonnoD
    don
    las vegas
    07 dc 4x4 v6
    im sure it will settle down a bit. specially when i put a winch and a full set of skids
  8. Apr 17, 2011 at 7:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    That will help alot.
