OME Lift
Discussion in 'ToyTec Lifts' started by Yok3d, Aug 10, 2010.
  1. Aug 10, 2010 at 3:41 PM
    Yok3d
    Yok3d [OP] Member
    Evan
    SLO/Davis
    05 DCLB
    Flowmaster 40 Delta Muffler
    I was thinking about ordering the OME Complete Lift Kit in the next month or so. I have heard that UCA's are a must for any lift over 3". I will mostly be doing highway driving and the very occasional ride out to the beach. Being a starving college student I can't afford both the lift kit and uca's :(. Would it be worth it to just hold of on the lift until I can get both or will I not run into issues with the OME lift with the driving I am doing?
  2. Sep 27, 2010 at 1:50 PM
    Claytor
    Claytor Well-Known Member
    Clayton
    TX
    SR5 4X4 TRD OR
    Full OME Lift W/top spacers, Dakars in the rear, extended rear brakelines, CHROME Satoshi, 17x8 American Racing Mojave Teflons, Nitto 295/70/R17 Trail Grapplers
    I have the exact same question... if anyone has any advice
  3. Sep 27, 2010 at 1:52 PM
    Brunes
    Brunes abides.
    Rotorhead
    I would hold off/save up- You are likely to have issues with alignment if you don't. You could get away with it for a while...but you might chew up tires pretty quick.
  4. Sep 27, 2010 at 1:52 PM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    Hold off. Your alignment will be trashed if you dont
  5. Sep 27, 2010 at 2:06 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    i don't have aftermarket UCAs OME lift there is nothing wrong with my alignment.
  6. Sep 27, 2010 at 2:08 PM
    Brunes
    Brunes abides.
    Rotorhead
    When you say "nothing wrong" You mean that you don't feel anything wrong or do you have the specs for your alingment...Cause I would say you are extremely lucky if you don't have any alignment issues on stock UCAs.
  7. Sep 27, 2010 at 6:22 PM
    borderbrat
    Jeremy
    Victoria BC, Canada
    I say everything was in spec and if feels fine.
  8. Sep 27, 2010 at 6:31 PM
    bnavin
    bnavin Negative Ghostrider
    Ben
    Littleton, Colorado
    OME lift, driveline spacer, iPod interface, rattle canned center console and radio face flat black, LEER topper, Yakima rack, 20% tint all around
  9. Jan 7, 2011 at 2:34 PM
    Streaking10 Taco
    Streaking10 Taco Well-Known Member
    North East Bay
    '10 DC-SB Pre-Runner Off-Road
    Icons in front, Icon Tubular UCA's, Dakars w/MX6 Shocks, Redline hood supports, FlyZeye
    Question for the masses.... I just moved out of a Chevy 2500 crew-cab Diesel into a 2010 DC-SB Pre-Runner Off Road, so heres my question:
    Can I install the Billstein 5100's front and rear with the OME 886 front coils and the Ome Leaf springs in back and will it be level?
  10. Jan 7, 2011 at 2:57 PM
    borderbrat
    Jeremy
    Victoria BC, Canada
    yes you can. Install the bilsteins at zero lift setting although I have seen it done at 0.85. And you can mix and match whatever shock spring combo you want in the rear so long as the shocks are long enough to accommodate the spring. I'm not sure about the 886 coil i thought 885 were recommended unless you have an aftermarket plate front bumper with a winch. But with OME coils up front and OME leafs in the back alone it will still have rake. you will need to give the front a little more than what the coils will give you. So setting the 5100s at 0.85 should level you out.
  11. Jan 7, 2011 at 3:28 PM
    Streaking10 Taco
    North East Bay
    Cool thanks :D:D:D
  12. Jan 7, 2011 at 3:42 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I have OME 885s and they give my std cab a full 3" of lift in the front.
    My toe-in and camber, the alignment factors that affect tire wear, are perfect, within 0.1 of zero.
    That being said, yes, I have an imperfect alignment: my caster is at zero when factory calls for roughly 2.7 degrees IIRC. This makes the truck a little more "twitchy" (more eager to turn, less eager to go straight) than it otherwise would be. I may yet get around to doing UCAs to correct this. Or, I may not.
    What some techs will do is try and get everythings "as close as possible to in-spec" - so they'll set camber around 1 (or whatever the max "in spec" value is) so that they can get caster as-close-as-possible to an in-spec range. When they do this, it is an imperfect alignment that WILL affect tire wear.
    If you don't have UCAs, you have to tell the tech to deliberately optimize CAMBER, at the expense of caster.
    Hope this helps.
  13. Jan 7, 2011 at 3:45 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Don't put on 886s unless you already have a heavy bumper and winch installed. 886s without that extra 200lbs up front will jar your fillings out.
  14. Jan 7, 2011 at 3:51 PM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Pick-em-up-truck
    Ultimate Tailgate Machine
    I called wheelers offroad and got 885's, shocks front and back (everything OME), an AAL, and Light racing Upper control arms for right at $1,000.
  15. May 13, 2011 at 7:58 PM
    BuzzardsGottaEat
    BuzzardsGottaEat "Pick up some speed.. You'll make it."
    Chaz
    South Dakota
    93 Pickup 4x4 [22R-E] 5MT
    OME suspension, LCE Performance parts, Konigs, etc. [see build]
    it helped me anyways.. i've literally had my finger on the submit button for buying my lift twice now, but cant afford UCA's yet, guess i'm waiting.. thanks for the info
  16. May 13, 2011 at 8:00 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    886 coils are not supposed to be paired with the billies , they are recommended for use only with OME shocks
  17. May 13, 2011 at 8:17 PM
    taco084gb
    taco084gb No matter where you go there you are.
    Galen
    NorCal
    I have the Full OME lift 886 coils and the DAKAR leaf pack with all leafs in it. But I also have the ARB bumper,warn8000 winch,lights and heavy tow hooks. And for the back I have a tool box with about 300lbs of tools and things I carry on a regular basis. Ive had this setup up for almost 3 yrs now and have NOT needed the UCA's. Alignment is within specs and can verify when I get home to get paperwork. I dont have any abnormal wear on tires as my first set of rugged trails I got 52,500 miles out of them. I mainly drive Hwy with an occasional offroad trip. I now have 74,000 miles on the truck as we speak. So I guess it depends on the truck and what you have on it.
  18. May 13, 2011 at 8:35 PM
    kieth
    kieth Well-Known Member
    British Columbia, Canada
    06 trd
    Full OME lift with Dakars, 886s and LR UCA's, Firestone air bags w\ onboard compressor, 2 kicker CVT 10" subs , MB Quart 1000w amp ,Alpine media player
    i have the ome 886s and ome shocks with light racing UCA's without any extra front weight and the ride is unreal, no broken teeth. my truck drove like shit and the alignment was way out before i got the UCA's, dont really know how it could be fine on a different truck, the stock UCA's will be at disgusting angles and your suspension will bind when your off roading.
