OME lift
Discussion in 'Suspension' started by rpking, Mar 21, 2012.
  1. Mar 21, 2012 at 10:42 AM
    rpking
    rpking [OP] Well-Known Member
    Roger
    Ohio
    Tacoma 4x4 TRD off road
    painted engine cover, bed cover, color match door handles, window tint, seat covers, weather gaurd floor mats, TRD stainless steel cat back exhaust, front skid pan, bug deflector, custom holster mount in center console, OME 884X springs and shocks, 2" AAL, OME shocks
    I want to order the OME lift today but have a question, I have read on here some say the diff drop is not required. MY truck : 2011 access cab v6 4x4, I'm going to get the 884 springs and the 2" AAL with shocks and no top plate spacer. I think the lift comes with the trim pack for the lean, so do I need the diff drop?? Thanks
  2. Mar 21, 2012 at 10:53 AM
    rpking
    Roger
    Ohio
    Thanks for the info
  3. Mar 21, 2012 at 10:15 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I just installed the OME lift. I didn't install the diff drop though and I have no vibes.
  4. Mar 21, 2012 at 10:31 PM
    TurboGT
    TurboGT Stirring the pot since...
    Gabe
    Portland
    '16 Inferno DC LB 4x4
    None yet, starting over!! OME lift w/ Dakars & 885's Remote Start w/ window control
    Another newb question.... what would happen if one didn't need the diff drop but installed it anyway? Can it hurt having it either way?
    I'm finally starting to understand this lift stuff...
  5. Mar 21, 2012 at 11:31 PM
    rpking
    Roger
    Ohio
    I have read that UCA's were not needed unless the truck was lifted 3" or more, the longer I wait and the more I read the more confused I get. That's my main reason for wanting to go with 884 springs I only want 1"- 2" of lift, hoping to avoid all the vibes and alignment issues
  6. Mar 21, 2012 at 11:44 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    With the 884 could you should be fine and avoid the vibrations.
