OME light lift 2 inch my christmas present from the wife...
Discussion in 'Suspension' started by stunt man hans, Dec 6, 2010.
  1. Dec 6, 2010 at 2:04 PM
    stunt man hans
    stunt man hans [OP] DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    ok so today i did some calling around and i think i settled on an old man emu lift. i was going for the icon set up but 4,000 dollars is rough so is 2,000 grand. not to mention i like the reputation that ome has built for itself over the years. after talking to a rep at arb this morn i decided to go with the ome light lift kit its a 2inch lift and won't screw anything up meaning all the factory settings and adjustments should remain. its important to me as this is m daily driver to maintain the factory or even a softer ride and still be able to mount a front arb bumper and rear bumper with a tire swing in the future and have the weight be accounted for in the suspension. i also don't want anything finicky or tricky to maintain lol. i want to set it and forget it. let me know what you think. the lift i'm thinking of running is the OMETACO5LK lol i think its gonna run me around 900 to 1,000 dollars for the kit and then installation costs which is another question what would be a decent price for the installation job on this type of lift? thanks in advance guys for any info you can offer up.
  2. Dec 6, 2010 at 2:21 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    What springs are you getting and does the lift include a AAL for the rear? Got a link??
  3. Dec 6, 2010 at 4:36 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    885 coils and the leaf pack if i choose the guy told me i could get the add aleaf later if i wanted to increase the load capacity of the beda little. i told him i wanted something flexy enough to keep my tires on the ground but soft over the bumps lol! i want a 4x4 cadilac that has ground clearance enough to clear most trails but not high enough to screw up my driveline configuration.
  4. Dec 6, 2010 at 4:39 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    anybody else running this lift up in here?
  5. Dec 6, 2010 at 7:24 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Your rear will ride stiffer than stock , especially when unloaded , with the Dakars .
  6. Dec 6, 2010 at 7:45 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    I have the OME shocks 885 front springs and a 1 1/2" AAL.
    I have added a Relentless Fab front bumper and some bed weight along with a All Pro rear bumper and some heavy skids so I will be going to 886 springs soon.
    Otherwise I say it is a great pick for a simple and very efective lift.
    Pick up a 1 1/2" AAL or 2" if you want more and you will be happy.
  7. Dec 6, 2010 at 8:15 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    what model tacoma do you have? v6 or 4cyl reg cab or double cab etc. my truck is a regular cab and i only plan on doing bumpers front and rear with a tire swing in the rear but the bumpers are going to be arb and i know that they are pretty heavy something like 200 pounds for the front and who knows about the backits still in development. i told the guy at arb what my plans where and this is what he recomended for me idk. he told me it would handle considerably better than stock trim and it would be easy over the bumps more so than the factory setup. but now hearing that the dakar springs will make the ride even more stiff legged i'm confused what to do...
  8. Dec 6, 2010 at 8:21 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    this is the first truck i have ever lifted and i want to use something quality but that won't kill the check book. i want to go up about 2 inches and not change the geometry of the drive line ie. cv angles and drive shaft angles. that brings along its own set of problems. i have 1,000 dollars to spend on the lift itself i want something that will only lift it a little but have decent articulation and soften the ride a little. the d- bag at the dealership installed e load duratracs on my truck and it feels like they are made of granite lol.
  9. Dec 6, 2010 at 8:37 PM
    OZ-T
    Peter North
    British Columbia
