OME or bilsteins?
Discussion in 'ToyTec Lifts' started by Ratfink, Mar 1, 2010.
  1. Mar 1, 2010 at 8:29 AM
    Ratfink
    Ratfink [OP] Well-Known Member
    zakk
    jacksonville florida
    07 prerunner
    toytec 3 inch best seller lift, FRONT-OME N1402 struts, med 885 coils w/ top spacer. REAR- 5100 blistens and add-a-leaf in the back. Black weather tec mats all around. Tint 15% in front and 10% in back. 12 inch 900 wat pioneer sub. krunch amp 1500 wat. Black billt grill lower and uper. blacked out tail light and break light. plasti dipped middle of front bumper.
    OK so I am confused i need some help.. I have the 3 inch best seller lift on toytec. Its a coil And 1inch spacer in the front and leaf spring in the back. I still have my stock shocks with my lift and my ride is really rough.Im trying to decide what to do. i could eather get the OME 9000 for the front only, or the 5100 blistens for the back and front. the toytec site suggest the OME 9000 but it cost 300$. the 5100 are front and back for 300$ what should i do???? My main goal is to fix my stiff front suspension. thanks..
  2. Mar 1, 2010 at 8:33 AM
    98tacoma27
    98tacoma27 :POOPCORN: Moderator
    Ben
    Beech Creek
    05 Tundra SR5, 88 SR5 PU, 98 TRD OR (CRUSHED)
    5100's all on fours
    Either is a good choice. It just depends what you want to spend. If it were me, I would put the billy's on all four corners.
  3. Mar 2, 2010 at 9:44 AM
    Ratfink
    zakk
    07 prerunner
    do u have a lift on your truck.. will they work for my lift? and make it less stiff.
  4. Mar 2, 2010 at 10:07 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Not yet (backordered..........:frusty:). Yes they will work and should smooth it out for you.
  5. Mar 2, 2010 at 10:27 AM
    ToyTec Lifts
    ToyTec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    Curious, what OME coil did you end up getting?
    Your an access cab correct?
  6. Mar 2, 2010 at 11:38 AM
    Ratfink
    zakk
    07 prerunner
    the med 885 coils and Also includes ToyTec Top plate spacers for a full 3" front lift & (6) top plate studs for the front. and in the back i got
    REAR: (2) 2" lift ToyTec Add-a-leafs by Alcan spring (a long add-a-leaf for the best ride), w/OEM style anti-friction Pads, & new leaf spring center pins. i never got new shocks with the lift. will the billys all around be the best purchase to fix my prob?
  7. Mar 2, 2010 at 11:38 AM
    Ratfink
    zakk
    07 prerunner
    double cab
  8. Mar 2, 2010 at 12:00 PM
    ToyTec Lifts
    Rocky Mountains
    Yap, that's why.
    Those coils are not designed for the stock shocks!
    Upgrade those shocks and you will be golden.
    Personally, I would go with the OME shock in the front and you could go billy's in the rear.
  9. Mar 3, 2010 at 9:21 AM
    Ratfink
    zakk
    07 prerunner
    are the billys in the rear going to be better than the stock shock in the rear?
  10. Mar 4, 2010 at 5:10 PM
    ToyTec Lifts
    Rocky Mountains
    Of course!!
    And longer.
  11. Oct 22, 2010 at 7:33 PM
    ser240z
    ser240z Well-Known Member
    Scott
    Monterey Park, CA
    09 Dbl Cab 4X4 6spd
    Sorry to revive an old post but I'm looking into this kit and can't seem to decide which to go with either. What are the main differences between the OME and Bilsteins?
    Thanks
    Scott
  12. Nov 13, 2013 at 12:01 AM
    J0HN_R1
    J0HN_R1 Well-Known Member
    Calgary, Alberta
    2014 Tacoma TRD Sport DCSB
    Bilstein 5100's @ 2.75" FR, Deaver 1.5" TSB leafs RR
    Sorry to necro-post, but... I'm in a similar boat.
    Been trying to decide whether to get;
    - Bilstein 5100's (x4) w/front set @ max, with stock coils & 1.5" AAL
    - OME 3" coils w/spacers, with stock shocks & 1.5" AAL
    * Yes, this is a "budget" lift. But I gotta start somewhere, other than spacer-lifts...
