OME or Fox, Donahoe, Saws ect.
Discussion in '1st Gen. Tacomas (1995-2004)' started by BCH, Oct 3, 2010.
  1. Oct 3, 2010 at 4:00 PM
    BCH
    BCH [OP] Shiester
    Lafayette Ga
    SR5 4x4 4cyl
    Viper, ARE Camper
    Bout decided on the 882 springs for my truck but I am interested in a really good ride. If I can keep a 2" good riding lift after settling I would be very happy. Will the Coilovers or the OME stuff ride better on the road and an occasional farm trail while hunting. I am not hard on my truck at all so thats not a concern. What is better for this truck ????????? I weigh 320 lbs. I want to do the right thing but I'm still undecided. Pictures would help a lot
    2004 4cyl 4x4 ARB Bumper and winch
  2. Oct 3, 2010 at 5:18 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    OME N91S shocks. Throw a trim packer in there too (they're on Toytec) and it should be even. Rides well from experience.
  3. Oct 3, 2010 at 6:50 PM
    BCH
    BCH [OP] Shiester
    Lafayette Ga
    SR5 4x4 4cyl
    Viper, ARE Camper
    Coiovers or 882's ??????
  4. Oct 3, 2010 at 7:17 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    A couple of thoughts:
    Coil springs settle over time. You can use the 'sag' word if you like but its all just settling.
    Adding additional weight way out front, hanging of the very front of the frame will enhance the settling effect. The more weight = more settling (over time).
    How quickly this settling happens will depend on the quality of the spring itself and what it is subjected to.
    The only way I know of to counteract the settling (over time) is to put more (and more) preload into the coil. The ability to dial in the exact amount of desired lift is one main reasons for considering an adjustable coilover strut like Fox, Icon, King, SAW, All-Pro, etc., etc., etc.
    my $ .02
  5. Oct 3, 2010 at 7:33 PM
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    Go with Icons!
  6. Oct 3, 2010 at 8:18 PM
    jcmartinez17
    jcmartinez17 Well-Known Member
    jc
    ontario
    10 trd tacoma prerunner
    gotta agree, i got donahoes which are icons and awsome ride
  7. Oct 3, 2010 at 8:31 PM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    Coilovers are definitely better but they cost about 3x as much as an OME setup. OME is very well respected though. You just won't here to many people bad mouthing them. Sounds like for your needs, OME is the way to go.
  8. Oct 3, 2010 at 9:14 PM
    BCH
    BCH [OP] Shiester
    Lafayette Ga
    SR5 4x4 4cyl
    Viper, ARE Camper
    So, Say I get donahoes.........Do you have to get a spring rated set or are the coils on those all the same ?
  9. Oct 3, 2010 at 9:17 PM
    BCH
    BCH [OP] Shiester
    Lafayette Ga
    SR5 4x4 4cyl
    Viper, ARE Camper
    Also, How will they ride with the bumper set up I have
  10. Oct 4, 2010 at 12:38 AM
    gobias
    gobias as in Gobias some coffee
    02 Dbl TRD
    OME. Coilovers are awesome but way too expensive for most people's needs IMO.
    Have 9k mi in the past 3 months on my OMEs and I love 'em. They've handled lots of highway/city, Moab, mudding, and trails out in the boonies just fine.
  11. Oct 4, 2010 at 5:53 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    i think they are all 650# springs
    with all the extra weight, i'd suggest you go with adjustable coilovers
