ome question???
Discussion in 'Suspension' started by TacoSupreem, Jan 28, 2010.
  1. Jan 28, 2010 at 3:49 PM
    TacoSupreem
    TacoSupreem [OP] Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    I just received my ome 884's and nitrocharger shocks today.First thing i did was measure the coil spring height because when i was looking at buying a new lift i could not get a straight answer as to how much lift i would get with just the springs? So the springs measure 15 1/4 inches? I thought they were 16 inch springs? So am i only gonna get like 1 inch of lift with these coils? So anyway this kinda made me red so i called ARB!
    First of all ARB said they don't even list the 884 for use with the tacoma? WTF:mad: Basically i just wanted a slight lift and improved performance and handling without having to use spacers to acheive this. Can anyone that has this setup tell me how much lift they acheived with just the coils and shocks? Also can i use the ome rear shocks and the stock springs without bottoming out the shock? As always your help is greatly appreciated.
  2. Jan 28, 2010 at 4:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The 884's will give about 2" + lift. They are 1.25" longer than stock, and a 590# spring rate. The OME rear shocks are fine for the back end of the truck.
  3. Jan 28, 2010 at 4:31 PM
    TacoSupreem
    Hayden
    Kentucky
    I'm just wondering how i'll acheive the 2+ inches of lift if the 884's are only 1.25 inches longer than stock?
  4. Jan 28, 2010 at 4:35 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    1" = 2" of lift
  5. Jan 28, 2010 at 4:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    And the higher spring rate. ;)
  6. Jan 28, 2010 at 4:38 PM
    TacoSupreem
    Hayden
    Kentucky
    Sooo a one inch taller spring will yield a 2 inch lift?
  7. Jan 28, 2010 at 4:41 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    Yes. From my 884 with 1/4" top plate spacer I got over 3" lift on my 4 banger, confused me but whatever haha
  8. Jan 28, 2010 at 5:10 PM
    TacoSupreem
    Hayden
    Kentucky
    ok cool is was worried there for a minute?
  9. Jan 28, 2010 at 5:14 PM
    TacoSupreem
    Hayden
    Kentucky
    me bein 4wd and i have a v6 i wonder how much sag i'll get?
  10. Jan 30, 2010 at 2:34 PM
    weidjd
    weidjd Well-Known Member
    '10 DC TRD OR 4x
    Saw COs/RR,TSB + 1.5AAl, LR UCAs
    I was told to go 885w/Spacer to get 3" on my dc. That 884 will be less than 2"
