OME Question
Discussion in 'Suspension' started by Gossamer, Mar 7, 2010.
  1. Mar 7, 2010 at 1:14 PM
    Gossamer
    Gossamer [OP] Howard Roark
    West of Illinois and East of Nebraska
    How much are UCAs going to help the "wandering" after a 3" lift? Anyone comment on before and after?
  2. Mar 7, 2010 at 1:22 PM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    The UCA's are going to stop the wandering...
    Between 60-65 mph, your steering wheel shakes and it feels like it's unsafe to drive. You definitely are going to want UCA's after you lift it 3".
  3. Mar 7, 2010 at 1:24 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    thats what i have heard as well, but does the lrs stop it even more because they have the full alignment ajustments, or do the uniball ones work better
  4. Mar 7, 2010 at 1:39 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    yes... your wandering is caused by algnment
  5. Mar 7, 2010 at 1:41 PM
    Gossamer
    I don't have any shaking...but the truck moves from side to side the faster I go...the only thing that's off much is the caster. in order to get that within spec, i know I"ll have to get UCAs but I never knew being off that little bit would cause it to slide back and forth so much.
  6. Mar 7, 2010 at 2:06 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Some times you can get away with a "little" out. Some times you can't. There are factory specs for a reason.
    Get the UCAs and you should be able to get the alignment back in.
  7. Mar 7, 2010 at 2:11 PM
    Stillfly199
    Stillfly199 ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    I thought that alignment didnt cause shakes, it only caused the wondereing? I thought that the tire balance caused the shakes?
  8. Mar 9, 2010 at 9:08 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    X1000 uca's will allow u to get your caster to ideal settings.
