OME questions for my 2004
Discussion in 'Suspension' started by TengoTaco, Dec 17, 2008.
  1. Dec 17, 2008 at 8:01 PM
    TengoTaco
    TengoTaco [OP] Newb
    La Quinta, CA
    2020 OR 4x4 Manual
    8112, SPC, Elka 2.0 rear and Icon AAL. About 1.5”
    Well I'm sitting here with my credit card going over what i'm going to get. I need some advice before i pull the trigger. Heres what i have in mind:
    ---881's Coils
    ---N91SC "Comfort" Shocks
    Now here are my two questions:
    Are the comfort shocks the best choice? They have a standard shock. I don't want the truck to be any more "floaty or Leany during a turn."
    Is there anything extra that i will need to buy? *excluding tools*
    Im going to put this on the front and see how much it lifts the truck before i get anything for the rear.
    Tyler
  2. Dec 17, 2008 at 8:04 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    thats what i have....the 881's. they gave me 2inches on my double cab. i am running billy 5100's on mine though. the ome shocks should be great for you....since they are valved for those coils.
  3. Jul 29, 2010 at 6:36 AM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    is there a spring that ome makes that lifts around 2.5 inches after sagging?
  4. Jul 29, 2010 at 7:59 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Do some research.... If you notice on this site, there are MANY different types available.
    http://www.cruiseroutfitters.com/tech_OME_coils.html
    You need to research to find out what size lift each of those applications gives you.
  5. Jul 29, 2010 at 6:08 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    It's called adjustable coilovers.
