OME questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by Motomax114, May 12, 2014.
  1. May 12, 2014 at 7:40 PM
    Motomax114
    Motomax114 [OP] IG - MKearney114
    Max
    Sacramento
    2000 4x4 TRD/SR5
    Sorry if this has been coved.. I scrolled through the show me thread some but just have a few unanswered questions. Some areas talked about longer brake lines, shims for angle driveline spacers ect. What's really involved with installing the OME LKS kit?
    Will the ome lks kit level the truck? Or do I need spacers?
    I got front and rear springs and shocks with the kit.
    I read the rear springs being called Dakar, are there different rear springs.
    Just stuff like that. Thanks in advance.
  2. May 12, 2014 at 9:27 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    Not sure what "LKS" stands for but the OME suspension is a great setup it just depends what coils you bought? 880's will level the front with the rear and probably put you a little nose high. If you got 881, 882, or 883 then you'll need some rear lift to match the front unless you like the brolean
  3. May 13, 2014 at 7:31 AM
    Madjik_Man
    Colorado Front Range
    OME rear leafs are Dakars. FYI.
  4. May 13, 2014 at 5:11 PM
    Motomax114
    Max
    Sacramento
    2000 4x4 TRD/SR5
    Thanks for the replies. Lks is the light kit hks is the heavy kit. I got 880 because I do not have a bumper or winch.
    So Dakar is just what they call the rear springs ok thanks. I thought maybe there was standard and Dakar.
    So with the Dakar rear springs and 880 up front should it sit level ? I hope
  5. May 13, 2014 at 6:45 PM
    Mainmoe02
    Moe
    Austin, Texas
    Probably gonna have some rake. The dakars give about 2.25" of lift for 1st gens and the 880's give about 1.5" lift after settling (from what I've read). If you want it to sit level with dakars on the rear then your probably gonna need 881's to give the 2.5" lift needed to match the rear.
    Example...
    I have eibachs which give me 3" lift up front. I also put the dakars on the rear for 2.25" of lift. I was sitting perfectly level with this setup.
    Never mind the fake tires and wheels in this^ photo, it was a photoshop effort.
