Ome Rear Leaf Springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by soljah111, Jun 20, 2011.
  1. Jun 20, 2011 at 11:50 PM
    soljah111
    soljah111 [OP] Well-Known Member
    Jon
    Denver
    11 supah white OR
    None yet
    So I have the Toytec 2" add a leafs on my non tsb rear springs and I am looking into getting the Ome Rear Leaf springs. Currently my rear springs have some squeaking and I think this would be a nice upgrade to get rid of that and to be more functional. Will the ride be better with the ome's? What would the height difference be?
  2. Jun 20, 2011 at 11:53 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    The rear leafs get you 2 3/4" over US ( non-TSB ) stock height
    The ride is not really any firmer than my Canadian 4 leaf ( TSB ) pack
    They still can have the same squeaking issues as the stock leafs
    I am at 24 1/2" centre of wheel to underside of fender in the rear
  3. Jun 20, 2011 at 11:56 PM
    soljah111
    Jon
    Denver
    11 supah white OR
    None yet
    Do you like them? Should I do it?
  4. Jun 20, 2011 at 11:58 PM
    OZ-T
    Peter North
    British Columbia
    I do like them .
    I am a carpenter and needed a better platform for carrying weight , for me they are great .
    I'm still chasing a squeak in my pack , but I think I am going to get it figured out .
    With a 200 lb cap they only squatted 1/4"
  5. Jun 21, 2011 at 12:03 AM
    soljah111
    Jon
    Denver
    11 supah white OR
    None yet
    Thanks, I think I'm going to do it.
  6. Jun 21, 2011 at 12:04 AM
    OZ-T
    Peter North
    British Columbia
    You need to get 4 new OEM bushings too .
  7. Jun 21, 2011 at 12:05 AM
    OZ-T
    Peter North
    British Columbia
  8. Jun 21, 2011 at 10:00 AM
    soljah111
    Jon
    Denver
    11 supah white OR
    None yet
    I appreciate the help.
  9. Jun 21, 2011 at 10:26 AM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    I have the OME as well. The ride is probably better for me than with my 2" AAL. I no longer bottom out while towing/hauling. They are 100% better than stock/AAL. I do have the squeaking issue that others have mentioned but the fact I no longer bottom out, I guess it is a trade off.
  10. Jun 21, 2011 at 10:35 AM
    ffblaze911
    ffblaze911 Well-Known Member
    Frederick, Colorado
    TRD OFF ROAD
    Supercharger
    why would you do it if you don't have any front suspension lift? and yes they will lift higher than tsp and you will also need break lines
  11. Jun 21, 2011 at 10:37 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    not true recomended but not required.....
    3" and more you will need longer brake lines
  12. Jun 21, 2011 at 10:43 AM
    OZ-T
    Peter North
    British Columbia
    You don't need new brake lines
  13. Jun 21, 2011 at 10:59 AM
    ffblaze911
    Frederick, Colorado
    TRD OFF ROAD
    Supercharger
    well you don't but its recommended....
  14. Jun 21, 2011 at 11:27 AM
    MAXTacoma
    Lexus GS 350
    x2.... I didn't replace mine and have been fine.
  15. Jun 21, 2011 at 2:54 PM
    ffblaze911
    Frederick, Colorado
    TRD OFF ROAD
    Supercharger
    I called the manufacture and they highly suggested doing it.
  16. Jun 21, 2011 at 2:58 PM
    OZ-T
    Peter North
    British Columbia
    Do it then
    I have lots of slack in mine
  17. Jul 6, 2011 at 7:57 AM
    09taco4x4
    09taco4x4 Well-Known Member
    Louisiana
    09 DCLB TRD Sport 4x4
    Valant cold air intake kit Borla catback exhaust 6" Pro Comp Stage 1 Walker Evans 2.5's w/ TSB spring and add-a-leaf Light racing upper a-arms 285/70/R17 Dynapro ATM tires 17x9 XD wheels
    I have thought about getting the OME springs too but if they still squeak I won't waste my money on them. I want to find out if there is a better solution for the squeak fix than inserting a bike tube or plastic between the leafs. If all else fails I could always do a coil over and 4 link set up!
  18. Jul 6, 2011 at 8:15 AM
    OZ-T
    Peter North
    British Columbia
    This ^^
  19. Jul 6, 2011 at 8:37 AM
    09taco4x4
    Louisiana
    Anyone using the AP rear leaf springs?
  20. Jul 6, 2011 at 10:14 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    For those who have them, where did you find the best price on these?
