OME Rear Leafs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HDFD10, Mar 28, 2010.
  1. Mar 28, 2010 at 2:55 PM
    HDFD10
    HDFD10 [OP] Well-Known Member
    Going to purchase a 3" set tomorrow. My stock leafs with AAL will not haul sh!t without sagging like a mofo. Question is will these beef up my rear noticably? And how hard of an install is it? Any tricks to know? Thanks for any info!!
  2. Mar 28, 2010 at 3:06 PM
    Brunes
    Brunes abides.
    Rotorhead
    You should notice less sag with loading- You should also see a bit more flex when you get to wheeling.
    Take it slow with the install...and get the rear end alignment checked. It's not really adjustable...but you can set it wrong.
  3. Mar 28, 2010 at 3:10 PM
    HDFD10
    Rear end aligment? Never heard of that one?
  4. Mar 28, 2010 at 3:14 PM
    Eesh
    Eesh Well-Known Member
    Regina, Sask., Canada
    trd Sport
    Where are you going to buy them from. They are on back order pretty much every where.
  5. Mar 28, 2010 at 3:18 PM
    Brunes
    Brunes abides.
    Rotorhead
    Like I said-It's not adjustable but you can put it back together wrong. Mine had like a .4* thrust angle when I put it back together. Took it too the alignment shoo and ended up knocking on it with a deadblow hammer to get it down to .01* (0.0 is ideal).
  6. Mar 28, 2010 at 3:53 PM
    Rocktaco
    Rocktaco Member
    Rockford, Illinois
    09 TRD OR DC pyrite Mica
    Bakflip G2, Dynolock, Lamin X, weather techs
    Im sure you kmow but there's a TSB for rear leafs. MAy save you some money. Lots of postings about tsb 0308-05
  7. Mar 28, 2010 at 4:25 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    you will get about 2.5-3" of lift, but loading will be greatly improved. just hauled ~1650# of concrete and it did great! i highly suggest you get the shocks to go w/ them. you will need the longer u bolts, and maybe even the 3* shims. i didnt install them and have slight vibes at 10-15 mph. going to pick up a set to see if it will help. install is easy if you have tools.
    im sure you know that the OME leafs are in a completely different league than the TSB leafs...;)
    if not, search around here and you will see why he wants the OMEs over the TSB...
  8. Mar 28, 2010 at 6:42 PM
    HDFD10
    Yes, for sure want the new OME leafs over the TSB. Was going to order then from 4wheel parts, last i checked (few weeks ago) they had some? Who knows?? Think i am going to try to do install myself.
