OME - Rides like low rider
Discussion in '1st Gen. Tacomas (1995-2004)' started by czenkov, Nov 28, 2010.
  1. Nov 28, 2010 at 9:40 AM
    czenkov
    czenkov [OP] New Member
    SLC
    '04 Xtra Cab 4x4
    I have done the searches - no help. The truck rides real stiff. Here are the specs:
    2004 ExtraCab SR5 4x4
    255/75/16 BFG AT's
    ARB Front Bumper w/M8000 Winch mounted
    OME 882 Front Coils - Heavies
    90004 Front Nitrocharger Sport Shocks
    OME Dakar CS 046R A/B Rear Leaf's
    N85 Rear Nitrocharger's
    I did seem to get more than the advertised 2-2.5" of lift as well - closer to 4..25"(w/spacer, since removed). 1st Pic before lift, 2nd After, and standing level w/KM2's before I changed the tires.
    On rough blacktop it basically makes you feel like you are riding a horse - but out of time with the up and down rhythm. It is quite the shock to your internal's - believe me. However, larger bumps off road are like butter. Nice and smooth. What can I do to achieve a smoother ride? Change springs? Change shocks? To What? Any help is greatly appreciated.
  2. Nov 28, 2010 at 9:44 AM
    kcbmx
    kcbmx doing my thing.
    Marco
    Bakersfield CaLiFoRnIa
    2tr-fe 4wd
    spit cup, weathertech floor mats, riffle rack, and bilsteins.
    Try removing your sway bar, really makes the suspension feel like a suspension, atleast for me it did.Just a suggestion, so don't chew me out lol .
  3. Nov 28, 2010 at 9:45 AM
    YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
    I think the kit is doing it's job...The OME kit is designed to be off road, and with those 882s with your ARB it will make it a stiff ride on top of that...
    I have the 881s and they are a little stiff, but I think it's a better ride than stock.
    I think that ARB with the 882s might be part of the problem, it's just a heavy bumper!
    Good luck.
  4. Nov 28, 2010 at 9:46 AM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    The 2-2.5" lift numbers are over new stock. Yours were probably worn and sagging a fair amount.
    New springs will also settle and soften slightly after a few miles.
  5. Nov 28, 2010 at 9:47 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    what psi do you have in the tires?
    the coils will sag and soften up, they all do.
  6. Nov 28, 2010 at 9:49 AM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    on the 1st gen's it makes the truck VERY tippy, I wouldn't suggest doing this.
  7. Nov 28, 2010 at 9:53 AM
    YellowDog01
    04 4x4
    X2, I haven't heard of any 1st gen. doing this.
  8. Nov 28, 2010 at 9:56 AM
    czenkov
    SLC
    '04 Xtra Cab 4x4
    The original springs had 25k miles on them and the bumper/winch had already been installed at that measurement. So that makes a bit of sense. The springs have now been installed for 16k miles and about a year. They have dropped a bit but the ride has not improved - has probably worsened. Truck has 41k on it and is in great shape so do not want to sell - looking for a solution - not willing to accept it as is. That being said I know I need to change the setup to better meet expectations. Just wondering what that setup might look like. Do I install 881's and hope between that and the shocks it mellows a bit? Or do I change the shock and leave the 882's installed. Where to start?
    For example I have a Defender and as purchased it had heavies in front with stiff shock, and medium rear coils with a stiff shock. Changed the rear shock to the softest OME offers and now it rides quite nice. The short wheel base tends to give a harsh ride anyway but the shock helped it relax a bit. In fact now the Defender rides better than the Tacoma!
    Looking for the same change here. Thanks for the ideas!
    Front: 32psi
    Rear: 30psi
  9. Nov 28, 2010 at 11:40 AM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    psi sounds fine, not sure what to tell ya man!
  10. Nov 28, 2010 at 11:58 AM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    I see 2 possible things:
    1. Are you sure OME sent the correct LENGTH springs? 882's can come in several lengths for different applications... If your spring is too long = too much preload, and also why you might have had to ditch the spacer.
    2. Wrong shock choice. Many off-road shocks are more ridgid on the small stuff and softer on the big hits as a result of their specific valving. This is always an issue when trying to outfit a daily driver that sees alot of asphalt. You could potentially benefit by swithcing to a more 'plush' shock.
    -Also with the shocks, they could have been intended for a 1gen on 881s stock otherwise... the 882s and the additional front weight could be 'tricking' your shock valving in a bad way.
    Good luck!
