ome shocks right and left
Discussion in 'Suspension' started by htuong95, Mar 3, 2012.
  1. Mar 3, 2012 at 7:58 PM
    htuong95
    htuong95 [OP] Have a nice day
    Sacramento
    2001 Tacoma 4x4
    Full OME suspension, Level 8 Tracker 16" wheels, BFG T/A KO 285/75/16, etc., work in progress...
    I am currently installing my OME lift kit. I just have couple of questions.
    Are the front struts the same for both sides? The numbers are the same so I think it does not matter which side I put them in.
    Does it matter if the word OME on the strut faces towards the front or rear?
    What about the rear leaf packs?
    Any help would be appreciated. Thanks.
  2. Mar 4, 2012 at 8:06 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    None of the components are side-specific.
    Also, shocks, not struts :thumbsup:
  3. Mar 4, 2012 at 8:22 PM
    htuong95
    Sacramento
    2001 Tacoma 4x4
    Thanks for the information.
  4. Mar 8, 2012 at 2:10 PM
    rossivey
    rossivey Well-Known Member
    North Texas
    06 Black DCLB 4x4
    if you add the trim spacer then it needs to go on the driver's side but it doesnt matter what shock you put it on.
  5. Mar 8, 2012 at 2:16 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    And as lot of folks get the shocks and springs pre-pressed (I did). If a trim pack spacer is added (you'd have to have requested that - it costs extra but has been reported to alleviate the 'Taco lean' many experience and provide a more level look).
    Anyway, you'd certainly want to get the shock with the spacer on the driver side, if you went that route (I did).
