OME Suspension Advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Be3fTaco, Nov 14, 2012.
  1. Nov 14, 2012 at 7:12 AM
    Be3fTaco
    Be3fTaco [OP] Member
    So, I ordered a 2013 DC TRD Sport, and I want to order an OME Suspension Lift Kit before my truck gets here so I can lift it the same day, but I don't know how many leaf springs it has.
    I asked the dealer and he said, "The TRD Sport rear leaf springs are 3 major and one minor for a total of 4 springs." So, does that mean that I need to order the TSB aal? Do any of you guys with 2013 DC Sports also have 4 leafs?
    Also, what weight spring should I go? Is the 886 really that stiff?
    Thanks.
  2. Nov 14, 2012 at 7:14 AM
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    Go with 886's if you have or plan on getting bumper/winch.
  3. Nov 14, 2012 at 7:16 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Yes , TSB AAL
    How much lift do you want ?
  4. Nov 14, 2012 at 7:17 AM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    886s are stiffer and are designed for tacomas with added weight like a plate bumper or armor. 885s would probably be a better choice if you are not adding extra weight.
  5. Nov 14, 2012 at 7:18 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    886 springs are pretty stiff and will give you a lot of lift if you don't have any extra weight up front. They are designed to hold up the ARB bumper and a winch.
  6. Nov 14, 2012 at 7:35 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    The 885 are too stiff for me thinking about switching out for the 884s.
  7. Nov 14, 2012 at 7:36 AM
    Pugga
    Massachusetts
    884's have the same spring rate, they're just shorter.
  8. Nov 14, 2012 at 7:37 AM
    Toyota Truck
    JT
    Texas
    2008 Prerunnner
    Thanks that's good to know.
  9. Nov 15, 2012 at 7:06 AM
    Be3fTaco
    I want to get a full 3" and level in the rear. I was planning on getting 885s with a top spacer.
    The dealer said something about getting the stiffest springs because it is better when you are towing or haling junk. Does that mean 886s? I don't plan on getting a winch or bumper.
  10. Nov 15, 2012 at 7:10 AM
    OZ-T
    Peter North
    British Columbia
    Stick with the 885's if you aren't adding a bumper and winch
  11. Nov 15, 2012 at 7:26 AM
    OZ-T
    Peter North
    British Columbia
    Not true
    884 and 885's share the same rate
    886's are stiffer
  12. Nov 15, 2012 at 7:27 AM
    Be3fTaco
    Thanks for all the info on spring rates. I've been doing some more reading, and some guys put on extended brake lines. Is that required?
  13. Nov 15, 2012 at 7:29 AM
    Saskquatch11
    Saskquatch11 TRUCK YEAH
    886s have a higher spring rate than the 884s and 885s.
    http://cruiseroutfitters.com/tech_OME_coils.html
  14. Nov 15, 2012 at 7:31 AM
    OZ-T
    Peter North
    British Columbia
    Not with the AAL you are intending on using
  15. Nov 15, 2012 at 7:33 AM
    nat
    nat Well-Known Member
    South San Francisco Bay Area
    2007 DC SB Tacoma
    Bestop, MP3 Aux Input
    You might want to consider getting the Dakar spring pack. I have those and 886 coils.
  16. Nov 15, 2012 at 7:35 AM
    OZ-T
    Peter North
    British Columbia
    You have an aftermarket bumper and winch ?
  17. Nov 15, 2012 at 7:42 AM
    BakerTaco
    BakerTaco Well-Known Member
    Will
    Lower Alabama
    2006 4x4 SR5
    Black UWS Toolbox, Window Tint, Weathertech mats, OME lift: 885x coils, top plate spacer, OME shocks all around, 2 inch AAL driver side trim packer, Toytec diff drop, Grillcraft, Colormatched grille, CHLM, 6000k HIDs - headlights and fogs, Smittybilt shackle hitch, ARB snatch strap, Pioneer avic x940bt headunit,
    TSB AAL, if it does in fact have the TSB done(I'd do a little investigating), 885s with top plate spacer
  18. Nov 15, 2012 at 8:08 AM
    OZ-T
    Peter North
    British Columbia
    Says he has 3 + the overload , that's the " TSB " pack
    The 2012-13 Sports come with the 4 leaf " TSB " leaf springs stock
  19. Nov 15, 2012 at 8:25 AM
    nat
    2007 DC SB Tacoma
    Not yet..............I need to build one or buy one. Same with a rear bumper/tire carrier. I like a stiffer ride in my trucks.
  20. Nov 15, 2012 at 8:34 AM
    nat
    2007 DC SB Tacoma
    Adding another 200 lbs to the front isn't enough to settle the springs significantly. A 660 pound per inch spring rate means it takes 660 lbs to compress it an inch, 1320 lbs for 2 inches, 1980 lbs for 3 inches, etc.
    Where the stiffer springs help is in rough roads when the extra weight up front creates greater forces.
