OME Suspension Advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Be3fTaco, Nov 14, 2012.
  1. Nov 15, 2012 at 8:37 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Except for the part about that 200 lbs hanging over the front end, not directly over top of the springs. That extra 200 lbs has some extra torque on the suspension. It's like the difference between having 500 lbs in the front of the bed vs. 500 lbs on the hitch.
  2. Nov 15, 2012 at 8:42 AM
    nat
    nat Well-Known Member
    South San Francisco Bay Area
    2007 DC SB Tacoma
    Bestop, MP3 Aux Input
    It is a cantilevered load, still not enough to significantly compress the springs at rest. I might argue it makes no difference, but I would need to make some calculations to compare.
  3. Nov 15, 2012 at 8:46 AM
    Pugga
    Massachusetts
    I agree that it is more significant when the whole truck gets bouncing but keep in mind that even the stock springs are 540 #/in which means they would need over 1,000 lbs to compress them an inch and an ARB bumper has a significan't impact on that setup.
  4. Nov 15, 2012 at 8:50 AM
    nat
    2007 DC SB Tacoma
    540 lb/in springs means it takes 540 lbs to compress it 1 inch, 1080 for 2 inches, etc.
    Somewhere I have compression spring formulas.
  5. Nov 15, 2012 at 8:54 AM
    Pugga
    Massachusetts
    Correct, 2 springs though. My point was that just looking at the spring rate vs. the weight of the bumper, having that weight cantilevered does make a significant difference in how the front suspension handles the load. The 886 coils will do a good job resisting sagging at rest but you'll be able to tell that you put 200 lbs on the front of the truck.
  6. Nov 15, 2012 at 8:58 AM
    nat
    2007 DC SB Tacoma
    Yes, 2 springs.
    My point was/is there won't be a significant difference at rest, but you are correct, it will be noticeable when exposed to the various loads created by a rough road, potholes, speed bumps, etc.
    You a mech engineer as well?
  7. Nov 15, 2012 at 9:01 AM
    Pugga
    Massachusetts
    Nope, Civil but I liked that courses that overlapped with Mechanical.
  8. Nov 15, 2012 at 9:07 AM
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    Simple answer OP. If you plan to get a plate bumper..886..if not 885. and Lol at the engineers arguing :D
  9. Nov 15, 2012 at 9:09 AM
    nat
    2007 DC SB Tacoma
    Cool stuff man!
  10. Nov 15, 2012 at 9:09 AM
    Pugga
    Massachusetts
    At least we didn't break out the calculations and fill the thread with numbers :D
