OME suspension.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Nunavut, Apr 1, 2013.
  1. Apr 1, 2013 at 10:20 AM
    Nunavut
    Nunavut [OP] Eh oh, Canada go.
    Canada
  2. Apr 1, 2013 at 10:23 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    Just go ahead and do it. Other than it's a lil rough on the road am happy with mine.
  3. Apr 1, 2013 at 10:29 AM
    bpkrules
    bpkrules Well-Known Member
    Jon
    Houston
    Tacoma4x4 BATMAN
    ARB Front bumper. Custom rear bumper. ARB snorkel. 883s 90004s. 1 inch daystar body mounts lift. Full skids. Leather seats.
    I would call and order and try to get a discount.
    AMR13M9 ... $120 off $800
  4. Apr 1, 2013 at 1:37 PM
    Nunavut
    Canada
    Thanks. I'll give that a try when I'm ready too order.
  5. Apr 1, 2013 at 1:49 PM
    scocar
    scocar Patron of the Farts
    They don't seem to specify which coils. It says 2-inch lift, but that is a little vague, depending on engine and cab type. Could be 881s or 882s. You should ask.
    You will need (or need to make, easy) a BPV relocate bracket, you may need the exhaust pipe extened bracket (to avoid leaf contact with ex. pipe at droop), and likely extended rear brake line (and max driver side droop, the stock line can get stretched tight).
    And don't forget to adjust your headlights after the lift.
    EDIT: I don't see front leaf hanger pins (bolts) in the pic. Yours are very likely seized in the bushings and will need to be cut off.
  6. Apr 28, 2013 at 6:56 AM
    camt10
    camt10 Well-Known Member
    03 ext cab sr5 trd 4x4
    Heavy kit comes with 881's did u get the kit
  7. Apr 28, 2013 at 6:58 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
