OME suspension
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 99superduty, Oct 8, 2015.
  1. Oct 8, 2015 at 11:46 AM
    99superduty
    99superduty [OP] Well-Known Member
    2016 DCSB OR 4x4 OME LIFT W/886 and DAKARS 265/75/16 Duratracs C4 lo pro bumper
    I'm familiar with the OME stuff as thats what I had on my GX470. HOWEVER.....that did not have leaf springs so my question is, are they a needed upgrade for the '16? I'm planning on putting a topper on there at some point, just wondering if the stock leaf's are up to that?
    I'm going to do the heavy springs up front with the nitrochargers as I plan on putting the ARB bull bar on when they become available.
  2. Oct 8, 2015 at 11:49 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    If it was me, I would
  3. Oct 8, 2015 at 11:49 AM
    2016_dbag
    2016_dbag Well-Known Member
    2016 POSTURD
    How high do you plan on going in the front? If you want truck to sit flat or even stock with a taller rear-end, you're gonna need at least an AAL if you go above 1" in the front...
  4. Oct 8, 2015 at 11:54 AM
    99superduty
    Whats an AAL? I think I had gotten about 2" out of that setup on my GX, thats what I was planning.
  5. Oct 8, 2015 at 11:56 AM
    geekhouse23
    AAL is "add-a-leaf" but you won't want that..trust me. I installed one on mine and it started riding terrible and sagged really bad after 3k miles. You will want at least a progressive AAL pack to add to the stock leafs or replace the stock leaf pack completely.
  6. Oct 8, 2015 at 11:59 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    If you're going to be buying a camper shell I wouldn't recommend the 3 leaf AAL either. I had it, and it wasn't great.
    Replaced the entire leaf pack in half the time it took to install the 3 leaf AAL and it's the only way to go IMO. I wish I'd never bothered with trying to supplement the stock leaf pack.
    Airbags are another option (that I didn't try). About $300 and a 2 hour install in your driveway.
  7. Oct 8, 2015 at 12:00 PM
    99superduty
    Airbags needed for just an ARE topper?
  8. Oct 8, 2015 at 12:04 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Get a set of Dakars and you won't regret it. You don't want to get into using air bags to lift your truck to level it out. If you do it will ride like shit. Air bags are ok to bring up the rear if you are hauling 800 lbs or towing a heavy trailer.
  9. Oct 8, 2015 at 12:05 PM
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    I got the toytec AAL. It rides pretty good not too rough and rides a little softer in my opinion.
  10. Oct 8, 2015 at 12:34 PM
    T4RFTMFW
    Depends on the weight.
    My shell weighs 225 lbs.
    What does yours weigh?
    Try and have someone (or some items) of similar weight stand in your bed and see how it handles the weight, then imagine it getting worse with time because the stock leaf springs are terrible for hauling.
    geekhouse23 likes this.
  11. Oct 12, 2015 at 5:09 PM
    99superduty
    So reading on another thread, the Dakar leafs and nitrochargers do not fit the rear of the '16. Posted said that ToyTec gave them that info. So I guess I'll hold off until OME gets the '16 stuff engineered.
  12. Oct 12, 2015 at 5:35 PM
    T4RFTMFW
    Dakars should.
    OME shocks shouldn't.
    What was wrong with the Dakars?
  13. Oct 12, 2015 at 8:04 PM
    99superduty
    Why wouldn't the shows fit? Supposedly the same suspension from the '15. Not sure about the dakars....I lost the thread.
  14. Oct 12, 2015 at 8:08 PM
    T4RFTMFW
    Some 2015s wouldn't fit the OME because the lower shock body would interfere with the lower shock mount.
    Being as it wasn't every 2015 and only some, I am guessing the 2016 mounts hit the production line mid 2015 MY and so the 2016s would have the same fitment issue.
  15. Oct 12, 2015 at 8:26 PM
    AngelMoroni
    AngelMoroni Well-Known Member
    '16 TRDORDCLB
    I was exchanging emails with toytec last week, they said OME rear shocks won't fit without mods, Dakar leafs should fit, but they told me to hold off until they have a chance to test fit them. I think they'll work, and this was more a CYA reply, so Im still debating ordering now.
  16. Oct 12, 2015 at 8:36 PM
    T4RFTMFW
    Without a single mod, not mods.
    2015s with the different lower shock mounts just needed to grind 1/8" of metal off of the sides of the mount, and that's all that was needed to clear the shock body.
    AngelMoroni likes this.
  17. Oct 13, 2015 at 7:13 AM
    Gingerbeard Man
    Gingerbeard Man Well-Known Member
    Jared
    North Dallas
    2016 MGM DCSB Sport 4x4
    Icon stage 3 tubular 285/70/17 Toyo ATII
    Air bags will likely improve your ride, not kill it. Different application but my old truck had Firestone 9000s and it did not compromise the ride.
