OME top plate spacers
Discussion in 'Suspension' started by tacoma98042, Jan 16, 2012.
  1. Jan 16, 2012 at 9:46 AM
    tacoma98042
    tacoma98042 [OP] Well-Known Member
    Hello,
    I am ready to buy the OME lift kit from Toytec, but I am not quite sure about the top plate spacers offered in the kit. I know I want the trim spacer for the driver's side lean, but I don't know if I should add the top plate spacer. Price isn't the factor as much as ride quality and appearance.
    My question is, will the top plate spacers offered in the kit make the front of the Tacoma sit higher or will it sit level with the back?
    I am looking at getting the 2"AAL and LR upper control arms.
    Any pictures of a Tacoma with the 10mm spacers and without would be greatly appreciated!
    -Mike
  2. Jan 16, 2012 at 9:47 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    What year/model Tacoma do you have and which OME coils are you getting?
  3. Jan 16, 2012 at 9:52 AM
    tacoma98042
    2011 double cab
    885 coils
    I have no bumpers or any added weight
  4. Jan 16, 2012 at 10:09 AM
    Pugga
    Massachusetts
    Without the trim plates, you should still have some rake. You should gain a little over 2" in the rear with that AAL and about 2.5" in the front with the 885's.
  5. Jan 16, 2012 at 10:23 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I got 2 1/2" up front on my DCLB 4x4 with the 885's , no spacers .
    There has been zero settling in 10 months
  6. Jan 16, 2012 at 11:25 AM
    RadRed06
    RadRed06 Christ Follower
    Daniel
    Flowood, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
  7. Jan 16, 2012 at 3:03 PM
    tacoma98042
    RadRed06,
    Your front end seems to sit higher up, do you think this is because of the access cab or the plate spacer?
    I'm just trying to find the best combo with the OME setup to have a level sitting truck.
  8. Jan 16, 2012 at 3:21 PM
    OZ-T
    Peter North
    British Columbia
    Just get the 885's without the spacer and the 2" AAL
  9. Jan 16, 2012 at 5:14 PM
    RadRed06
    Daniel
    Flowood, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
    X2^^
    My front end does sit a little bit higher because I got the spacer and 885's which are stiffer instead of 884's which are supposed to be for reg. cabs and access cabs.
  10. Jan 16, 2012 at 5:16 PM
    Pugga
    Massachusetts
    885's are the same spring rate as the 884's, they're just 10 mm taller. If you use 884's on a double cab, you can expect about 2" of lift.
  11. Jan 16, 2012 at 5:19 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    dont get the top plate spacers if u r 4x4. it will give u too much lift and ur CVs wont last IMO.
    i had the top plate spacers and then took them off
  12. Jan 16, 2012 at 5:21 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    885 is formed from the same wire as 884 and spring rate for both is 590#
    The difference is 885 is 10mm longer than 884.
  13. Jan 16, 2012 at 5:22 PM
    especk
    Erik
    Redding, CA
    885 with top plate spacer and dakars
  14. Jan 16, 2012 at 5:24 PM
    jflan
    Vancouver, WA
    Your halfshaft angles are prolly steep and the CV boot fins are rubbing.
    I'd take the top spacers out if so.
  15. Jan 16, 2012 at 5:26 PM
    RadRed06
    Daniel
    Flowood, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
    Im not a 4x4 tho?
  16. Jan 16, 2012 at 5:29 PM
    jflan
    Vancouver, WA
    Nvrmnd then.
    No halfshaft angle worries.
  17. Jan 16, 2012 at 5:31 PM
    RadRed06
    Daniel
    Flowood, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
    haha you scared me there for a second
  18. Jan 23, 2012 at 3:01 PM
    tacoma98042
    Update to my lift..
    any pictures or suggestions on doing this:
    OME 885s
    90000 NitroCharger Sport front struts
    N182 REAR SHOCKS
    1.5" Icon 3 Leaf Progressive Add a Leaf Kit
    with NO top plate spacers.
    found a good deal on this set up but I want to make sure it will look good.
    would this be a level lift and able to fit 285s?
  19. Jan 23, 2012 at 3:03 PM
    OZ-T
    Peter North
    British Columbia
    I got 2 1/2" up front on my DCLB 4x4 with just the 885's , no spacers
  20. Jan 23, 2012 at 3:16 PM
    Snowman20
    Snowman20 Active Member
    Cody
    Vancouver
    07 Trd Off-Road 4x4
    I have the 885's and dakars in the rear. The rear sits 3 inches higher then the front, though dakars do give more lift then the aal you have picked out
    And yes 285's will fit, you're going to need to do a little trimming though.
