OME Top Spacer Bolts
Discussion in 'Suspension' started by JGJ, May 29, 2011.
  1. May 29, 2011 at 4:56 AM
    JGJ
    JGJ [OP] Well-Known Member
    I want to remove my OME top spacer.
    Do you know if the longer top mount bolts that come with the spacer will fit without the spacer? Or will they be too long?
    I don't have the original shorter bolts that came with the OME lift.
    If not, you think I could just buy these at the hardware store?
    Thanks
  2. May 29, 2011 at 9:06 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    They'll still fit.
    I put some on initially in case I wanted to add a top plate spacer later. Not much chance of that, it turns out. 885 springs fully lifted my regular cab.
  3. May 29, 2011 at 9:24 AM
    EVILSTI
    EVILSTI Well-Known Member
    Ray
    Catskill, NY
    1994 FZJ80 / 2022 Tacoma TRD Pro
    2022 Tacoma TRD Pro ......................................... 94 FZJ80 Land Cruiser Slee 6" lift kit 37" KM2s 17" procomp wheels Snorkel .......................................... SOLD: 06 TRD OFF ROAD OME Suspension lift kit with: Front OME 90000 shocks, 886 coils, top plate spacers, complete OME Dakar leaf spring packs, Front Diff drop kit, Rear N182 shocks, OME trim spacer, OME carrier bearing drop bushings, American Racing Chambers 16X8, Yokohama Geolandar A/T-S 285/75-16s (Winter tires), BFG MT KM2's 285/75-16, satoshi grille mod, TRD CAI, AP front bumper, AP skid plate, Cobra 75 WX ST CB, 2' Firestik antenna, Pioneer Avic-U310BT, Beefed Sliders, LR UCA's, Tinted Headlights, AP Rear bumper, DTLTH, Smittybilt XRC10 comp winch, Yellow top D35, pAP custom Transmission Skid ;-) , NFab spare tire holder, DT Pipe Bomb,
    The threads wont be low enough to tighten the nuts all the way down.
  4. May 29, 2011 at 9:31 AM
    JGJ
    So you have the Top Spacer bolts on now? Are they the ones that come with the top spacer?
    Just trying to clarify since EVILSTI says they wont work.
    Thanks guys
  5. May 29, 2011 at 9:32 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Steve (bjmoose) has his installed with no spacer
    Apparently his work
  6. May 29, 2011 at 9:40 AM
    EVILSTI
    Ray
    Catskill, NY
    I just swapped out my 885's with spacers for the 886's without spacer yesterday and left the long studs in. The threads do not go all the way down. The splines will be sticking out still. Just throw a few flat washers on the studs before you put the nuts on.
  7. May 29, 2011 at 9:40 AM
    Valley Viking
    Valley Viking Well-Known Member
    Menlo, WA
    05 4x4 DC LB SR5
    OME 885 Coils, OME Dakar Rear Leafs, OME NitroCharger Shocks, LR UCA's, AFE ProDry Air Filter, Scanguage, Wet Okole Seat Covers
    I removed my top plate spacers and the bolts had enough thread to tighten up. At worst you need to add a couple of washers under thr nut.
