OME Trim Packer question
Discussion in 'Suspension' started by Ryan81, Aug 20, 2012.
  1. Aug 20, 2012 at 12:30 PM
    Ryan81
    Ryan81 [OP] Active Member
    Texas
    Dodge Ram
    I think once I get a Tacoma I've decided on the OME setup with 2" AAL in the rear and new LR upper control arms. I would like to get closer to 3" but also want to correct the "taco lean" so I thought about stacking two trim packers. Is this safely, doable?
    I would do two on the driver's side and then 1 on the passenger side to still gain some lift over there. Two of the 5mm packers would be less than 1/2"(12.7mm) so I don't see any difference between the 1/4" or 1/2" optional spacer.
  2. Aug 20, 2012 at 12:32 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    What shocks are you getting ?
  3. Aug 20, 2012 at 1:03 PM
    Ryan81
    Texas
    Dodge Ram
    The ones that come with the OME kit.
    Front: 90000 sport shocks
    Rear: N182 shocks
  4. Aug 20, 2012 at 1:36 PM
    OZ-T
    Peter North
    British Columbia
    In that case , I would suggest using the OME trim packer on the driver's side shock , it mounts below the coil seat , and then put a 1/4" top plate spacer on both the driver and passenger side .
  5. Aug 21, 2012 at 3:25 PM
    Creole Knight
    Creole Knight Man's got to know his limitations.
    Ulysses
    So. Cal
    05 Super White PreRunner
    gear shift knob and other things.
    OZ-T I just had a OME lift installed with the 885s and 90000 shocks with the Maxtrack spindles in front, and N182s in the rear to include the Allpro Expo leaf pack. It was installed two weeks ago. I am sitting at 26" in the rear and 27" on the passanger in front and 26 1/4" on the driver side front. Should I waite to let it settle more or what would you suggest to correct the driver side. The trim spacer was not used and the top plate 1/2" spacers were not used either. I would like to stay at 27" in the front and bring the rear up to 27" and even it out. What is your advice. Thank's
  6. Aug 21, 2012 at 3:34 PM
    OZ-T
    Peter North
    British Columbia
    I would say , 1/4" top plate spacer , driver's side , that way you wouldn't have to disassemble the coil / shock
  7. Aug 21, 2012 at 3:35 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    X2. We just did this on my friends truck this past weekend.
  8. Aug 21, 2012 at 5:53 PM
    Creole Knight
    Ulysses
    So. Cal
    You are the MAN OZ-T Thank you very much.
