OME UCA play in arm
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Geraldini, Apr 6, 2021.
  1. Apr 6, 2021 at 1:37 PM
    Geraldini
    Geraldini [OP] Member
    2017 gray trd offroad
    Bilstein 6112/5160 Dakar hd
    Went through the forums and there isn’t a lot of info on the new ome UCA. I just installed them yesterday and on the drivers side there is movement on the arm along the long bolt. I can’t torque it anymore and there is a visible gap on the top washer. Anybody have an idea about how to solve this?
  2. Apr 6, 2021 at 1:40 PM
    Burqueboy505
    Burqueboy505 Well-Known Member
    Albuquerque, NM
    2019 Cement OR DCSB
    You may be able to use an allen wrench at the end of the bolt to back it up while you tighten the nut
  3. Apr 6, 2021 at 1:45 PM
    Burqueboy505
    Albuquerque, NM
    2019 Cement OR DCSB
    Actually not sure what you're talking about. The long bolt that connects to the frame through the bushings?
  4. Apr 6, 2021 at 1:45 PM
    Geraldini
    Yeah the long one through the bushings and frame
  5. Apr 6, 2021 at 1:48 PM
    Burqueboy505
    Albuquerque, NM
    2019 Cement OR DCSB
    You sure you got all the washers in there correctly? I think it usually goes - thick - thin - thin - thick, from one side to the other. Take a pic
    Mully, tcjacado and SR-71A like this.
  6. Apr 6, 2021 at 1:57 PM
    Geraldini
    I’ll post a picture shortly. The only ones that were on the original were the convex ones and they were facing towards the inside of the arm.
  7. Apr 6, 2021 at 2:03 PM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Do you have leftover parts?
    fatfurious2, Hooper89 and Skydvrr like this.
  8. Apr 6, 2021 at 2:04 PM
    eon_blue
    Azusa, CA
    Usually that's a sign that the bushings are bad, if you can see the bolt moving in them. But they're brand new so that's odd.
    fatfurious2 likes this.
  9. Apr 6, 2021 at 2:07 PM
    Geraldini
    I do not have any leftover parts and yeah they are brand new.
  10. Apr 6, 2021 at 2:07 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    I’ve seen people forget to install the inner sleeve for UCA bushings and wonder why they have sloppy steering. I don’t have any first hand experience with the OME arms, but I’d probably suggest removing them to double check you have all the parts in there. May not even be your fault if they were assembled incorrectly or shipped missing parts.
    Skydvrr likes this.
  11. Apr 6, 2021 at 2:08 PM
    Geraldini
    Yeah the sleeve was in there but do remember that specific one wanting to pop out.
  12. Apr 6, 2021 at 2:16 PM
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Well done getting the UCA bolts back in the way they came, that’s better than I did!
    These are Camburg, but I find it odd that you don’t have washers on each side of shock tower, inner & outer.image.jpg
    Mully and Burqueboy505 like this.
  13. Apr 6, 2021 at 2:33 PM
    Burqueboy505
    Albuquerque, NM
    2019 Cement OR DCSB
    It appears you are missing the inner washers. Each UCA should come with 4 washers. One on each side of each bushing
    Hooper89 and beergeek like this.
  14. Apr 6, 2021 at 2:38 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    The OME ucas use a similar bushing to the current gen SPCs. They don’t require inner washers to my understanding. And the photos of the OMEs show outer washers, no inners which seems to support that. Why there is a discrepancy with OPs bolt bottoming out, I’m not sure.
    edit: actually one side in this photo shows an inner, I don’t even know lol
  15. Apr 6, 2021 at 2:42 PM
    Burqueboy505
    Albuquerque, NM
    2019 Cement OR DCSB
    I went to the site and noticed the same and I don't get it either lol. Maybe somebody with experience with these can chime in. Good luck OP
  16. Apr 6, 2021 at 3:21 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    The installation instructions are pretty terrible. Basically say, "remove UCA. Install OME UCA"
    The pictures found online of 4runners with these arms show at least one inner washer. The other is not visible.
  17. Apr 6, 2021 at 3:35 PM
    Burqueboy505
    Albuquerque, NM
    2019 Cement OR DCSB
    I know dude. I read them too trying to find a solution for you. Hopefully somebody with these can contribute. Should've went JBA!
    Mully likes this.
  18. Apr 6, 2021 at 3:38 PM
    Geraldini
    For the good news on the arms. They were able to align the truck now without issue and have degrees left over to play with.
  19. Apr 6, 2021 at 3:40 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    This picture shows 2 washer zip tied to both of the arms. That shows 4 different washers. There has to be an order
  20. Apr 6, 2021 at 3:43 PM
    Geraldini
    Yeah I just saw that in the picture and mine 100% did not come with those.
