OME UCAs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bees015, Sep 3, 2020.
  1. Sep 3, 2020 at 11:37 AM
    bees015
    bees015 [OP] Well-Known Member
    Sacramento, CA
    2017 White Tacoma TRD Offroad
    OME 886/HD Leafs w/nitrochargers LVL8 MK6 16in Wheels w/265/75/16 BFG KO2 Rigid Ditch Lights w/CaliRaised Brackets Various MESOs B&M Trans Cooler WeatherTechs LED Hi/Low w/Fogs Pop N' Lock Tailgate UltraGauge MX HD Front Brakes OVTune 1.05 2000 T4R SOLD 2014 RAV4 SOLD 2008 FJ Cruiser RIP 2010 Scion tc
  2. Sep 3, 2020 at 12:13 PM
    GladiatorNOT
    GladiatorNOT Well-Known Member
    2017 TRD OR
    Old Man BP51 coilovers Dakar HD leaf springs Icon Delta control arms TRD Pro rims with Kenda Klever RT 33x10.5 tires Exhaust mod TRD front skid, RCI tranny and transfer case skids Southern Style Slimline front bumper Baja Designs S8 bumper light Warn Zeon Platinum 10s winch 4.88 Nitro gears ARB front locking differential ARB twin air compressor X2 Power 27 battery RCI rear bumper with Rigid SRQ lights RCI rock sliders RLD canopy Dometic CFX3 55 refrigerator TRD Pro grill Front & Rear anytime camera Seat Jackers Diode Dynamics Pro fogs
  3. Sep 3, 2020 at 6:17 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
  4. Oct 19, 2020 at 12:04 PM
    B.Peak
    B.Peak Well-Known Member
    Brian
    SWFL
    '19 Tacoma TRD Sport 4X4
    '19 Tacoma TRD Sport 4X4, Premium and Technology Packages OME-888 Coils w/ OME-90021-P Nitrocharger Sport Shocks- softer valving ToyTec .5" Top Spacer OME-EL095R-P Rear Leaf Pack w/ OME-60091-P Nitrocharger Sport Shocks Eibach 1" Lift Block OME Upper Control Arms OME Driveshaft Carrier Bearing Drop Kit ToyTec 1" Diff Drop ECGS Clamshell Bushing 18X9 Enkei RPT-1, 0 Offset on LT305/65R18 TOYO Open Country M/T 2020 OEM Limited Grill 2020 OEM Limited Fog Light Bezels MESO Stage 1 Total Tail Light Kit All Interior and Exterior lights replaced with Diode Dynamics LEDs TRD Cat Back Exhaust Passenger Door Smart Key Mod
    I just ordered them. I've been on the fence since they came out over a month ago.
  5. Oct 19, 2020 at 1:24 PM
    tacomarin
    tacomarin ig: @travelswithchubbs
    Bay Area
    2018 DCLB TRD OR
    Prinsu Cab and Top Rack VO Drifter LED Interior, License Plate, and Reverse Lights Huskyliner Weather Beater floor mats Salex Center Console Organizers 35% Front/15% Rear Tint Debadged and De-stickered Anytime Front and Rear Cameras Brute force front bumper BAMF HC Dual swing out 285/75r17 BFG KO2 Front: ADS 2.5, EXT, RR, Clickers Rear: OME Dakar HD, ADS 2.5, EXT, RR, Clickers Stainless steel brake lines (+4 in rear) Wheeler's Offroad Superbumps Front and Rear Wheeler's Offroad U-bolt flip ECGS CV Axle Bushing SCS Stealth 6 17x8.5 wheels, matte dark bronze
    We put some on my buddy's 4Runner recently. They seemed well built, had a replaceable ball joint, grease zerks for the bushings. Definitely not flashy, but had a nice, durable coating on them and came with all the necessary hardware you would expect. One weird thing was the use of washers. For the ball joint you had to put two washers under the castle nut (clear in the instructions), which just felt a little weird. Also there are different thickness washers that you had to sandwich between the control arm bushings and the frame mounts, which was a pain. One side went in smoothly, the other side was a very tight fit and took some effort to get everything in. The only thing that didn't seem right was the ABS mount on the UCA seemed to be too far inboard. It ended up working out okay, but we had to do a little manipulating of that wire to get things to have the appropriate amount of slack.
    Overall, they seem fine. For the money though I'd personally get SPC's.
  6. Oct 29, 2020 at 1:00 PM
    B.Peak
    Brian
    SWFL
    I just installed the OME UCA. Super easy install. Passenger side I had done in under 30 min, driver side took longer because I did the ECGS bushing. Still had it all done in under 2 hours. No spacers or washers. Just unbolt the OEM UCA and slide the new OME in place using the original hardware.
  7. Mar 20, 2021 at 9:28 PM
    elassowipoh
    elassowipoh Member
    so cal
    2011 prerunner
    do you know where these ome uca's are manufactured?
