OME UCA's?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jose_Dirte, Oct 2, 2020.
  1. Oct 13, 2022 at 5:13 PM
    #61
    WhiteTaco20
    WhiteTaco20 Well-Known Member
    Perkasie, PA
    SW 2020 TRD Sport DCSB
    You just use the stock washers you had
  2. Aug 23, 2023 at 9:58 AM
    #62
    myn75
    myn75 Well-Known Member
    Nor Cal
    2021 TRD Off-Road 4x4 DCSB, 1996 4runner SR5 V6 4x4 auto
    ARB OME BP-51 2”, TJM sliders, AT3Ws, Diode Dynamics SS42"
    is that the stock sway bar? any contact with the coilover at full travel?
  3. Aug 24, 2023 at 9:41 AM
    #63
    808stateofmind
    808stateofmind Well-Known Member
    Kona
    '22 Lunar Rock TRD OR 4x4 DCSB 6MT
    Eibach pro truck 2.0/2R lift kit 1.5" AAL OME/ARB UCA BFG KO2, 285/70-17 SCS Blaze 10, 17-8.5, -10 offset ECGS bushing needle bearing replacement Clutch accumulator disk delete Poor mans TRD intake, K&N 57 series intake tube, K&N high flow filter, TRD flow accelerator
    Only one way to find out lol... i got the eibach coilovers and mine came with the seat bar spacers
  4. Sep 8, 2023 at 12:44 PM
    #64
    myn75
    Nor Cal
    Looks like you have really little preload, how much lift you get from these? Mine came with only 5mm but the manual says they would come with 20mm. Doesn’t make sense lol
  5. Sep 16, 2023 at 3:44 PM
    #65
    Jose_Dirte
    Jose_Dirte [OP] Life's a garden, dig it
    Joey
    Green Acres, CO
    A Tacoma, just like everybody else...
    Stock sway bar but OME gives you spacers to install. No rubbing.
  6. Sep 16, 2023 at 3:47 PM
    #66
    Jose_Dirte
    Joey
    Green Acres, CO
    I have them at the factory setting.
    Works perfect for 33s, but I have the stock front bumper and no winch.
    Whenever I finally damage my front bumper on a trail I will replace and add a winch and add more pre-load for the weight.
    I am not willing to diminish ride quality for the aesthetic of another inch in lift.
    myn75[QUOTED] likes this.
  7. Sep 16, 2023 at 3:50 PM
    #67
    Jose_Dirte
    Joey
    Green Acres, CO
    Just wanted to provide an update.
    The bushings on the UCA bolts failed on on these and were causing a terrible noise/clunk.
    ARB had me new bushings 2 days after I emailed them.
    For what it is worth I have put about 90k on them and lots of wheeling on Colorado trails.
    Still happy with the purchase.
    CowboyTaco likes this.
  8. Sep 17, 2023 at 11:03 AM
    #68
    myn75
    Nor Cal
    Sounds about right for heavy duty usage, after all bushings are a life-limited part. Are they pressed in bushings?
  9. Nov 13, 2023 at 6:26 PM
    #69
    Jose_Dirte
    Joey
    Green Acres, CO
    They are pressed in and super tricky to get out.
    I bought hydraulic shop press but can't figure out how to get them out since you have to push from the inside out.
    I'm going to see if I can just send them in for ARB to rebuild.
  10. Nov 13, 2023 at 6:29 PM
    #70
    myn75
    Nor Cal
    Maybe they could do a exchange for a new pair. Alternatively a brand new pair costs around 500, id say thats a better deal than trying to spend on tooling and time just my opinion on it however.
  11. Nov 13, 2023 at 6:36 PM
    #71
    Jose_Dirte
    Joey
    Green Acres, CO
    I tried, they wouldn't.
    I was actually surprised honestly.
    I'm going to try to send them in for them to rebuild them.
    If they say no I'll just buy new ones.
  12. Nov 14, 2023 at 8:35 AM
    #72
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    can a standard ball joint press not be used?
  13. Nov 14, 2023 at 12:47 PM
    #73
    Jose_Dirte
    Joey
    Green Acres, CO
    It's the bushings in the arm that failed not the ball joint.
  14. Nov 15, 2023 at 11:07 AM
    #74
    CowboyTaco
    North Georgia
    11 TRD Sport
    Oh...I totally misread that. Still seems like you should be able to get them out and replace. Lots of heat and patience...
  15. Nov 15, 2023 at 11:14 AM
    #75
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Scissor jack between the bushings with sockets or ball joint press cups pressing on the bushings.
  16. Dec 11, 2023 at 10:14 PM
    #76
    guest_707
    guest_707 Well-Known Member
    Does anyone use these with 255/85r16s and factory wheels? I have the Trail Edition rims with the 255 tires and I'm thinking of getting these OMEs in the future because I found out JBAs won't clear the 255 tires (with factory wheels) according to their website.
  17. Dec 13, 2023 at 6:04 PM
    #77
    Jose_Dirte
    Joey
    Green Acres, CO
    I would like to think you would be fine but I can't say as I had -12 offset wheels when I put these ucas on.
