OME vs Bilstien 5100
Discussion in 'Suspension' started by hud445, Feb 7, 2009.
  1. Feb 7, 2009 at 7:43 AM
    hud445
    hud445 [OP] Member
    Glendale az
    08 TACO TRD DBL CAB 4X4 6cyl
    Looking for a front end lift, I'm using the TSB/AAL in back.
    Definatley want coilovers. Looking at the Old Man Emu 885 coils & shocks, thier spec says it only lifts 1 3/4". I called a shop in CA who recommends going with the Bilstien 5100's adjustables @ 2 1/2 with the stock coils for a better ride, over the OME. They sell both.
    Tried to reach OME a few times over the past couple of weeks to clarify the hieght @ 888-907-4625, & left several messages, no return calls. Sent them 3 emails also, no replys.
    Any feedback?
  2. Feb 7, 2009 at 7:46 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    Your best bet is to call toytec lifts ( ) -- They'll be able to help you out with OME and Billy questions.
    I'd go OME coils and an OME shock in the front -- it's a 3" lift... and then put OME shocks in the rear. :thumbsup:
  3. Feb 7, 2009 at 7:49 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    That lift info for the OME springs is old info. They give 3" lift, give or take a little. Mine were 3.25" right after install, and they have since settled to 3". OME has assured me that their springs are rated to give 2.5" to 3" lift, and the springs are scragged to reduce settling. The 5100's preload the existing springs, where as the OME springs are a longer spring with a 50# increase in spring rate (540# vs. 590#). The OME shocks are a low pressure nitrogen filled twin tube shock. They hold more oil than the 5100's, thus will stay cooler longer. The lower pressure will make them more compliant (from what I have read), and less likley to leak.
  4. Feb 7, 2009 at 7:59 AM
    rpoint16
    rpoint16 Well-Known Member
    Tempe, AZ
    2022 TRD Off-Road, Super White.
    Bone Stock
    I'm in the same situation. Chris 4X4 helped me see the light! I'm getting the OME's. That seems to be the consencious of the board.
  5. Feb 7, 2009 at 8:02 AM
    rpoint16
    Tempe, AZ
    Bone Stock
    Delmarva, cool AVATAR . That episode last week was the funniest I have seen ! I was almost crying I was laughing so hard.
  6. Feb 7, 2009 at 8:03 AM
    Delmarva
    Tucson, AZ
    Thanks -- I'm a super fan... :D :thumbsup:
  7. Feb 7, 2009 at 8:06 AM
    hud445
    hud445 [OP] Member
    Glendale az
    Good info.
    Just so I am on the same page,
    885 front OME coils
    OME N140S front shock
    correct?
  8. Feb 7, 2009 at 8:08 AM
    hud445
    hud445 [OP] Member
    Glendale az
    Additionally, where do you guys stand on the OME rear shock & OME AAL?
    It seems I have seen some good OME pkg deals online.
  9. Feb 7, 2009 at 8:22 AM
    Delmarva
    Tucson, AZ
    Yes. :D
    OME rear shocks are fantastic. :thumbsup: I have the Alcan AAL and it does the job -- I think most of the AALs will be the same exact thing... :D
    and I've never heard of an OME AAL... hmm...
  10. Feb 7, 2009 at 8:58 AM
    hud445
    hud445 [OP] Member
    Glendale az
    OME calls it a lift spring.
    Here is a link:
    http://www.rocky-road.com/tacoma.html
    Looks like the package deal is pretty good.
  11. Feb 7, 2009 at 9:57 AM
    sonjay
    sonjay Well-Known Member
    That rear lift spring is a new spring pack. That site looks like its priced per side.
