OME vs. Eibach Springs? Thoughts Please
Discussion in 'Suspension' started by Jeremy92, Feb 2, 2011.
  1. Feb 2, 2011 at 3:18 PM
    Jeremy92
    Jeremy92 [OP] Tennessee Member
    Jeremy
    Smyrna, TN
    08 AC SR5 Prerunner Impulse Red
    Billies on all the way around, w/ Eibach Coils, w/ rear TSB. Brush Guard. Tail Light Guards.Window Rain Deflectors. 35% tint on side windows. Satoshi Grill(thanks TacoAlaMode). Fog Light Mod (thanks lifesaflaw123). 17x9 XD addicts wrapped in Kumho SAT Kl 61's 265/70/17.More to come!!!
    I'm getting to TSB tomorrow and I want raise the front up to level, or as.close to level as possible without being nose high. I have decided I would rather change out my springs than just keep the stock ones and preload the billys. I'm going to put billys on all 4 corners. So from there should I go with the OME springs and if so which ones(note I won't be adding any heavy thing to the front, but I do have a westin brush guard) and how much will they be, or the Eibach 1.6 springs, and getting 5100s all the way around.. Any thoughts will be greatly helpful
    Thank You
  2. Feb 2, 2011 at 3:20 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    Whichever spring you choose, I still wouldn't run with the stock shocks. Another option is to get the 5100s and use the stock spring for now.
  3. Feb 2, 2011 at 3:26 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    You can use the billy's with the OME's or Eibachs but you have to set them at 0" height. Let the springs do the lift. But I believe the OME 884's will give you about 2-2.5"s of lift a the eibachs give you around 1.6"s.
  4. Feb 2, 2011 at 3:28 PM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Pick-em-up-truck
    Ultimate Tailgate Machine
    I have OME and upgraded to the OME shocks... I believe with the lift the stock shocks will top out.
  5. Feb 2, 2011 at 3:28 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Check out Toytec Lifts in the vendor section. They will have your prices. As far as which spring, it depends on the amount of lift you want. OME 884s will provide approx. 3" of lift, whereas you need to set 5100s at .85, and add a top plate spacer to gain around 3" of lift.
  6. Feb 2, 2011 at 3:35 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    How much did you gain out of your OME 885s and 5100s at 0? Would you recommend combining bilstein struts with OME coils, seeing how OME coils were designed for a dual tube shock, completely different from the 5100?
  7. Feb 2, 2011 at 4:05 PM
    michaelg589
    michaelg589 Well-Known Member
    Ill have my 5100s and 885s this week. Might install them next weekend. Ive searched forever trying to find consistent information about how much the springs will raise a truck. I could not find anything conclusive. So, i decided to go with 885s. I'd rather be a bit higher than I wanted than not enough. I dont mind an excuse to get bigger tires :)
    Supposedly, if you have a Double Cab, or an extended cab with brush gaurd and/or winch, 885s will give you around 2.5" of lift. Every single dealer will say something slightly different. Which, now that I think about it, is very annoying. Youd think OME would make sure all the companies selling their product would have consistent and correct information.
  8. Feb 2, 2011 at 4:27 PM
    Jeremy92
    Jeremy
    Smyrna, TN
    Thank you all for your thoughts, I'm think the eiback's because I'm looking for a more of a stout look. Keep the thoughts rolling tho.
  9. Feb 2, 2011 at 4:34 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    What does "stout look" mean
  10. Feb 2, 2011 at 5:10 PM
    Jeremy92
    Jeremy
    Smyrna, TN
    ummm... im going to put some wide tires on her to. you know when you see a short person that is really built, they are short and stout. And to clarify on what kind of height im looking for, i'm wanting whatever will level out my truck with the Rear TSB done, or as close to level as i can get, without being nose high.
  11. Feb 2, 2011 at 5:14 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    You will need 2" aal to keep it level with either set up. Have you looked into complete ome lift? Full 3" lift, around $700 very solid, dependable lift.
  12. Feb 2, 2011 at 5:21 PM
    Jeremy92
    Jeremy
    Smyrna, TN
    So even if i set the billys at 0 with the eibach coils and the tsb, it wont be about level
  13. Feb 2, 2011 at 5:22 PM
    virgilus11
    virgilus11 Well-Known Member
    kearny, nj
    09 sr5
    TRD supercharger,EMU 884 springs, 90000 shocks, air bags rear and TSB with EMU shocks, grillcraft mesh, Relentless front bumper,Armology rear bumper, byxenon hid's retro ,undercover lid with bike rack on top, Kenwood dnx9140,TRD cover seats
    I am a little bit confused. The ARB site state very clear that the 885 will give about 1.75" lift. How are you guy's getting 3" of lift ???.
    The reason I am asking is that- I am in the process to replace my Icon's with EMU 885 and the new 90000 shocks. I went with 885 for the main reason that ,, it will not raise my truck more then 2". I don't want to get in to vibration zone.
  14. Feb 2, 2011 at 5:27 PM
    virgilus11
    kearny, nj
    09 sr5
    ARB site , TRDparts4u and wheelers -state 1.75" lift with 885. Not 3".
  15. Feb 2, 2011 at 5:30 PM
    Devildoc
    Devildoc Well-Known Member
    Lincoln, California
    Speedway Blue off road
    Running board, K&N air filter, Nitto Terra Grapplers G2 on ProComp 7089(285/70/17), 3" front lift and 1.5" AAl rear, all with bilstein 5100's with Eibach spring, 1/2 spacer in driver side and 1/4 spacer on the passenger, Wicked Flow exhaust, Debadge, satoshi raptor grille (HomerTaco)
    I have 5100's all around set at zero and tsb, I think it sits pretty level. I have 265/17/70 with this set up and its perfect, anything bigger you should be 2.5 higher at least.
  16. Feb 2, 2011 at 5:47 PM
    Jeremy92
    Jeremy
    Smyrna, TN
    I think you have exactly the look i want. Level by eye, maybe a little forward rake but thats not a huge deal. I pretty sure im going to go with the Eibach 1.6 springs and the billys set at 0, and the reat tsb will have raised the rear. Does anyone have pics of this sit up. Billys at 0 with Eibach's and the rear TSB? i keep getting different answers and i dont wanna screw my truck up.
  17. Feb 2, 2011 at 6:47 PM
    MedlinAround
    MedlinAround Failure is the result of letting setbacks stop you
    Cody
    Richmond, Kentucky
    2008 TRD off-road edition Tacoma
    Bilstein 5100's (.85), OME 885X Coils, AAL, Magnaflow exhaust, Volant Intake, OKledlight pods, Front Skid Plate, 4% Tinted Windows, Weathertec Floor Liners, Double Din Pioneer Player, 2 10" Memphis SR Subs, Plasti Blacked out Bumper, Grill, & Emblems, Custom Bed Rack, TRD Nation interior LED dome kit, 4X innovations sliders, DIY Roof Rack, Storage - Rotopax, Pelican 1600 waterproof case, Plano 42"case, Smittybilt RTT.
    I am also wondering the same thing. I was looking at the eibach coils with the bilsteins set at .85 in the front simply because i think it looks perfect and level with the 1.5" AAL in the rear with the TSB.
    Don't know about the OME's tho
  18. Feb 2, 2011 at 7:48 PM
    B...
    B... Member
    SLC, Utah
    some of this, a little of that
    I've been running this set up (885/9000) for a couple of months/few thousand miles. It's a solid 2.5" of lift on my Double Cab (no extra weight up front). I added the 5mm trim packer, got a kick ass alignment, and managed to significantly reduce the front end vibes to almost nothing when compared to the 2.5" spacer lift and crappy alignment that I had for the previous 2 years.
  19. Feb 2, 2011 at 7:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The OME springs work just fine with the Bilstien 5100 shocks.
  20. Feb 2, 2011 at 8:07 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    I'll post pic of my set up in a minute.
    OK. Here's mine. TSB and 5100s set at 2.5. I'll check to see if I have more of a side shot.
