OME vs TAC3-05
Discussion in 'Toytec Lifts' started by grady77, Jun 28, 2012.
  1. Jun 28, 2012 at 3:46 PM
    grady77
    grady77 [OP] Member
    glendale az
    2008 Tacoma 2wd PreRunner TRD Off Road access
    Toytec TTHA-CK 3" lift
    For my 2008 Tacoma 2wd PreRunner Access Cab TRD Off Road, I'm interested in the following ToyTec kits:
    TAC3-05: 3" FRONT: top plate spacer that uses the factory struts/springs. REAR: 2" ToyTec add-a-leafs.
    BK0510: ~2.5" lift using FRONT: Bilstein 5100 adjustable shocks & 620lb Eibach/Toytec springs and REAR: 2" Add-A-Leaf + Bilstein 5100 shocks.
    TTHA-CK: Full 3" lift using all of the BK0510 components plus a 1/2" front top plate spacer and various bits of hardware (and comes preassembled.)
    OME-TAK: Full 3" w/ top spacer. Complete Old Man Emu suspension. FRONT: OME 90000 sport shocks, 884/885 OME coils. REAR: OME N182 shocks and ToyTec 2" add-a-leafs.
    Questions-
    My goal is to fit 285/65/18 or 285/70/18 tires (on deeper offset rims) without trimming any plastic other than the mud guards. I want the ride to be smooth. I rarely off road. Any suggestions on which kit to get? Does the OME kit get a full 3" up front if I have an access cab and use the 855 coils?
  2. Jun 28, 2012 at 4:06 PM
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    OME all the way 100%.....i agree with wolfpack
  3. Jun 28, 2012 at 4:17 PM
    Desert Rat
    Desert Rat Well-Known Member
    Monterey, California
    2012 Tacoma DCSB TRD Off Road Double Cab
    3" OME lift, Avid lightbar and sliders, PIAA 525s, custom Baja Rack, SnugTop with Windoors, PopnLock tailgate, power moonroof, ARB awning, Pioneer AVIC-Z140BH, Alpine amp, Pioneers speakers, custom subwoofer.
    OME with Dakars, no question.
  4. Jun 28, 2012 at 4:21 PM
    grady77
    grady77 [OP] Member
    glendale az
    Thanks for the quick responces! OME sounds like the way to go.
    I've got some calls to make. Still looking for input from anyone with the billy setup.
  5. Jun 28, 2012 at 7:32 PM
    hard2kill
    Rhinebeck NY
    i have billys up front and i put OME 885 springs on them and i love the billys with the ome springs before the ome springs the billys were kinda ok not great if i was to do it again i would have just got the entire OME set up.......youll want 885 springs and top plate spacer for 3in lift and awesome ride
  6. Jun 28, 2012 at 7:58 PM
    Desert Rat
    Yes, 885s here as well (but no spacers).
    Go full OME and also replace the leafpack completely with the Dakars.
  7. Jun 29, 2012 at 10:09 AM
    grady77
    grady77 [OP] Member
    glendale az
    I finally talked to a knowledgable person at ToyTec. They insisted the Bilstein 5100 kit with Eibach coils and a top-plate spacer would be smoother than the Old Man Emu kit. Anyone able to weigh in?
  8. Jun 29, 2012 at 10:34 AM
    greenrustic
    greenrustic Well-Known Member
    NY
    2012 DCLB 4x4 TRD SPORT
    Access LTD Tonneau Cover, Weather Tech Digital Fit Mats, Weather Tech Rain Guards, 35% Tint up Front, AFE Dry Power Intake Filter, Debadged, GrilleCraft, OME 884x, OME 9000 NitroChargers, Icon 3 Leaf Progressive AAL
    Toytec seems to push the Eibachs and 5100 combo because they told me the same thing. I am still trying to decide Eibach or OME.
    I know this post doesn't help out the op but I guess its my way of subscribing to the thread.
  9. Jun 29, 2012 at 10:36 AM
    Desert Rat
    Smoother=not as good off-road. Spacers=not as good off-road.
    The full OME setup is much stiffer than stock without being harsh...it was *exactly* what I was hoping for...but my goal was greatly improved capability on Utah trails. YMMV.
  10. Jun 29, 2012 at 10:36 AM
    grady77
    grady77 [OP] Member
    glendale az
    Yes I was speaking of the TTHA-CK kit. And thanks for the correction, original post edited.
    Desert Rat: Thanks for your 2 cents. This build is for maximum comfort on the pavement and over potholes. The truck lives in suburbia 95% of its life.
  11. Jun 29, 2012 at 10:51 AM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2010 TRD Sport DC LB 4x4
    Work in progress, but installed so far; 265/70/17 Duratracs, Spidertrax, OME885X coils with OME lean spacer, OME N140S and N182 shocks, Wheeler's 1.5" 3 Leaf Progressive AAL (kept the overload), LR UCAs. TP14 spacers
    OP, any plans for a cap? Some say those Daks can be a little stiff without a load (I tend to agree).
  12. Jun 29, 2012 at 10:54 AM
    DevL
    DevL Well-Known Member
    285/70r17 with no plastic trimming is not possible. In fact I would recommend the top plat spacer lift because it limits uptravel and thats the only eay you sre gonna avoid cutting plastic.
  13. Jun 29, 2012 at 10:57 AM
    grady77
    grady77 [OP] Member
    glendale az
    cap?
    The Dakar leafs were never an option since they cost so much and I want the truck level.
    Thank for the reality check and good top plate spacer tip. I'll report back what the biggest tire I could stuff under there was and if I had to eliminate more than just the mud flap.
    That bilstein kit is a little different but I'm reading through the 11 pages anyhow. Good read.
  14. Jun 29, 2012 at 11:03 AM
    JonnyBb
    Arkansas
    Cap = topper.
    I just saw the suggestions for the Daks and didn't think they would be best for someone adamant about getting a smooth ride. FWIW, I agree with Brock (AAL is what I got).
  15. Jun 29, 2012 at 11:10 AM
    JonnyBb
    Arkansas
    :thumbsup:...I'm running Wheeler's 3-leaf AAL. I've never regretted spending the extra $ on it.
  16. Jun 29, 2012 at 11:19 AM
    grady77
    grady77 [OP] Member
    glendale az
    Progressive AAL sounds legit, I'll keep it in mind for a future upgrade. Really leaning on a full OME kit w/ 884 springs w/ .5" top plate spacer + 2" ToyTec AAL. Just going to spend a few more hours trying to figure out the valve rates on billys vs ome shocks then pull a trigger.
  17. Sep 13, 2012 at 12:18 PM
    grady77
    grady77 [OP] Member
    glendale az
    UPDATE/REVIEW:
    I ended up with:
    Kit: ---TTHA-CK--- Full 3" lift using all of the BK0510 components plus a 1/2" front top plate spacer and various bits of hardware (and comes preassembled.)
    Wheels: 18" XD series XD796 Revolver
    Tires: 285/60R18 Nitto Terra Grapplers All Terrain
    Very happy with this kit. Ride is very firm/stiff IF you go over rough bumps and offroad. In the city it is just as comfortable as stock. Perfect for old me like me (46yrs old.) There is no nose dip during hard breaking and no body roll in turns. I really can't tell it isn't stock until I hit a speedbump at 15mph.
    Full review and more pics will be posted soon. Thank you to JonnyBb, wolfpack, desert rat, and the dudes at Toytec that know their products (the chick has no idea and wasn't helpful.)
  18. Feb 16, 2013 at 10:34 AM
    randytho
    randytho Member
    SR5 4cyl 4x4
    I like the stance on that. I am looking at the TTHA-CK and the BK0510 and trying to figure out why the price difference. Looks like the main difference is the Ubolts, front caps and bushings, and the pinion angle shims? The only thing that seems necessary is the pinion angle shims?
  19. May 21, 2013 at 12:32 AM
    grady77
    grady77 [OP] Member
    glendale az
    ^ call Toytech. They will be able to answer that question.
    I'm updating my full review again. 1 year later I am not that happy with how stiff the ride is but it's still the best looking kit I've seen.
  20. Jan 22, 2015 at 4:13 PM
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    Georgia
    Yes
    The more expensive kit comes with the front shocks and coils preassembled with new hardware so you have a (more) simple bolt on job rather than the danger of compressing them yourself.
    OP: thanks for this post. I am debating the same kits vs. parting together my own kit. I want lift but I don't want a stiff ride. My TRD Pre dcsb is so smooth right now. It came with billies installed. I'd still need to swap them for the adjustable models.
