ome with 5100
Discussion in '1st Gen. Tacomas (1995-2004)' started by rab89, Mar 24, 2009.
  1. Mar 24, 2009 at 9:01 PM
    rab89
    rab89 [OP] Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    So, i may be selling my motorcycle soon, if I do I can finally order my lift.
    So I'm pricing it out on wheelers for the 40000th time, and this is what im not sure about.
    The OME 881's say "Average lift from this coil set on an extra cab v6 Tacoma is 1.75-2"
    and the 5100's say "3 spring seat positions you can choose that provide approximately 0-2.5"
    Are the OME springs going to be long enough to work with the 5100's set at 2.5?
  2. Mar 24, 2009 at 9:09 PM
    TengoTaco
    TengoTaco Newb
    La Quinta, CA
    2020 OR 4x4 Manual
    8112, SPC, Elka 2.0 rear and Icon AAL. About 1.5”
    I have the OME 881's and OME soft shocks. I love the ride. I got about 2.25"s of lift. Im subscribing because im curious to see if 5100's set at 2.5 and OME 881's will give over 4"s of lift.
  3. Mar 24, 2009 at 9:15 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    they won't get 4'' of lift. they would get max 2.5''
    What I'm wondering is are the 881's long enough to work with the 5100's?
    is this a good setup
    (chris 4x4 I know you think 5100's are the wrong way to go and full ome is the shit, but i've heard great things about the 5100's and heard of sagging with the ome's)haha your gona see this thread I'm sure so just wanted to clarify that right away.
  4. Mar 24, 2009 at 9:20 PM
    TengoTaco
    TengoTaco Newb
    La Quinta, CA
    2020 OR 4x4 Manual
    I would assume they would work because stock coils work with 5100's set at 2.5 and OME coils are longer.
  5. Mar 24, 2009 at 9:22 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    ahh right! I never thought of that.
    So now I'm wondering will they sag prematurely due to being made for different heights?
  6. Mar 24, 2009 at 9:31 PM
    TengoTaco
    TengoTaco Newb
    La Quinta, CA
    2020 OR 4x4 Manual
    I have never heard of someone putting the 5100's at 2.5 and stuffing 881's in there.
    Have you considered getting 881's with the reg 5100's that are not adj. You would still get a nice lift. Im worried about the ride....
  7. Mar 24, 2009 at 9:33 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    I don't trust the coil spring to do all the work, I feel like it would sag much faster..
    anyone else have some input?
  8. Mar 25, 2009 at 6:53 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i have ome 881's and billy 5100's, but my 5100's are at the stock setting. with them ome's though...adding them to the 5100's...i got 2 inches of lift. to be honest though.....not a good idea to preload those springs i dont think. better going with an 882 coil.
  9. Mar 25, 2009 at 6:55 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    the 882 is firmer...
    you mean because they will sag?
  10. Mar 25, 2009 at 6:57 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    not so much that they will sag....but they will give you a little more lift than the 881....and you can possibly set the 5100's at the first notch from the bottom......a little bit of preload, but a little more lift that way, and it should still be safe.
  11. Mar 25, 2009 at 6:59 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    sweet! thanks for the info. anyone have input on this?
  12. Mar 25, 2009 at 6:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I havent heard of any of the OME springs for the first gen trucks sagging. Use them with the 5100's, but use the 5100's at the stock setting. If Tacomaman (Will) got 2" of lift, and thats what you are looking for, then stick with the 881's. the 882's are a higher spring rate.
  13. Mar 25, 2009 at 7:01 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    hmm, I'll be building a fairly light front tube bumper soon. will this make the 882's a better decision or the 881's?
    I'd like about 2.5''
  14. Mar 25, 2009 at 7:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    if its more than 75# or so, get the 882's
  15. Mar 25, 2009 at 7:09 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep.............unless you like an extra stiff ride. may not be all that bad, but its definitely a stiffer spring than the 881.
  16. Mar 25, 2009 at 7:16 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    hmm, shouldn't be that heavy. I guess i'll go with the 881's and just set the 5100's on te second setting. sound good?
  17. Mar 25, 2009 at 7:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I would keep them on the bottom setting first. Then, after the bumper is made, see if it sags. If so, then move it up one notch.
  18. Mar 25, 2009 at 7:24 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    cool thanks!
    I am looking for some new leafs too, but I dont wanna spend $700 on the rear for some deavers and shocks
    So I was thinking the wheelers leafs..
  19. Mar 25, 2009 at 7:30 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i have the wheelers 5 pack rear leafs......love them. this is what my setup looked like(minus the 5100's) when i got all of it last summer.
  20. Mar 25, 2009 at 7:43 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    looks like we both want/ed the same thing. thats cool
    you seem to love your whole lift! show me a few pics if you don't mind.
    other than the leafs and shocks etc. what are the small things I need to make sure I get? new shackles? longer Ubolts? would this be a good time to do a Ubolt flip?
