OME with Dakar alignment, truck going left???
Discussion in 'Suspension' started by Imageoguy, Dec 17, 2012.
  1. Dec 17, 2012 at 1:57 PM
    Imageoguy
    Imageoguy [OP] Well-Known Member
    Gatineau, Qc, Canada
    2012 DCLB SR5
    Full OME suspension (885 front springs, Dakar leaf pack + OME shocks) + D29XL extra leaf + 3 deg. shim + RideRite airbags
    I just finished installing OME front shocks with 885 springs, LR UCA's and Dakars in the rear. I brought it in for alignment and changed tires for 265/75/16 duratracks whill I was at it. The steering now has to be a bit to the righ for me to go staight. Before going back to the shop, any insight as to what would have to be done to correct the problem? It didn't do that on my way to get it alligned...
    Here are my present alignment #'s.
    Front Left
    -0.1 Camber
    2.6 Caster
    0.01 Toe
    Front Right
    0.1 Camber
    2.8 Caster
    -0.01 Toe
    Rear Left
    -0.1 Camber
    -0.39 Toe
    Rear Right
    -0.4 Camber
    0.47 Toe
    Any suggestions?
  2. Dec 17, 2012 at 2:00 PM
    650H1
    650H1 Well-Known Member
    NH
    2010 Tundra TRD OR C/M 5.7l 4x4
    that's prob something your going to have to deal with. :notsure: as long as the truck doesn't pull to the right or left it should be fine.
  3. Dec 17, 2012 at 2:02 PM
    blakes09
    blakes09 Toyota Tech..when im not Fishing
    Blake
    Deep South
    4x4
    is it pulling or the steering wheel is off center?
  4. Dec 17, 2012 at 2:03 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Have someone follow you down a straight, flat road and see if you're back end is in line with your front end (make sure your back end isn't trailing to the right). Sometimes that happens when you put on new leaf springs or an AAL. There is a little bit of play where the centering pin goes into the axle, just enough so you can get the rear end off a bit. If that's the case, loosen the u-bolts and shift the axle the correct direction to correct it. Otherwise, your alignment shop messed up.
  5. Dec 17, 2012 at 4:42 PM
    Imageoguy
    2012 DCLB SR5
    Steering is off center. I seem to have a bit of wondering which could be due to the bad roads here but the steering is definately off center.
  6. Dec 17, 2012 at 4:44 PM
    DriverSound
    DriverSound Señor Member
    SoCal
    15 DCSB OR 4x4 & 15 Mustang GTPP
    Too few to list. 10 4runner SR5 4x4- 09 Pre-Runner TRD-OR AC- 14 Prius Two- 08 xB 03 Tacoma 5spd TRD OR 4x4
    I would say it's the shops fault as it would take a more than bad roads to do that.
  7. Dec 17, 2012 at 5:36 PM
    650H1
    NH
    Sometimes you can't get the steering wheel perfectly straight, that's a chance you take :notsure:
  8. Dec 17, 2012 at 5:45 PM
    Pugga
    Massachusetts
    F-150 Mod
    Only if you let a gorilla align your truck... There's no excuse to not get the steering straight. If might wander a little bit because of tire selection but it should track straight overall.
  9. Dec 17, 2012 at 5:57 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Steering wheel should be able to be straight
  10. Dec 17, 2012 at 7:49 PM
    Rocknroll
    Rocknroll Well-Known Member
    Devin
    Ventura County, CA
    TRD Sport DCLB 4x4
    My understanding is if your caster is set too close or is even, you will get some wondering.
    I put this exact suspension setup on my truck and then took it down to the local tire place and had them set the caster at 2.5 left and 3.0 right. No problems at all so far.
