OME's and Billies!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Wreckless_71, Jun 16, 2010.
  1. Jun 16, 2010 at 9:27 AM
    Wreckless_71
    Wreckless_71 [OP] WRECKLESS for Life...
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    3" Lift via OME 881's, Bilstein 5100's, Dakar OME 3" leaf packs, MBRP custom exhaust, HID headlights, CB, Canopy, aluminum wheels, upgraded sound system, full set of studded snow tires and wheels, auxilary lighting, more to come.
    I'm going to pick em up right after work. Getting OME 881's and Bilstein 5100's for the front and OME Dakar 3" rear leaf springs. CL find FTMFW!
  2. Jun 16, 2010 at 9:33 AM
    98tacoma27
    Ben
    Not Beech Creek
    Ibtp!!!!
  3. Jun 16, 2010 at 9:44 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
  4. Jun 16, 2010 at 9:44 AM
    Wreckless_71
    Justin
    Pullman, WA.
    98 ext cab Tacoma
  5. Jun 16, 2010 at 9:55 AM
    98tacoma27
    Ben
    Not Beech Creek
    (In Before The Pics)
    :spy:
  6. Jun 16, 2010 at 10:04 AM
    Wreckless_71
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    Oh lol... I have to leave work at 4 to go get the stuff. I'll post pics of the shit and of the truck, before and after :) Gotta find me some tires now........
  7. Jun 16, 2010 at 10:22 AM
    SaltySteve
    SaltySteve Well-Known Member
    Denver
    2012 4runner
    Do you have your tire selection narrowed down to anything?
  8. Jun 16, 2010 at 10:36 AM
    Wreckless_71
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    Probably 33x12.50R15's unless I do a little body lift. I wouldn't do more than two inches and it would be done right, with gap guards and whatnot.. I just can't justify $2k for a 6" lift plus the cost of 35's... But as I said, probably 33's when I can find em...
  9. Jun 16, 2010 at 11:24 AM
    96er
    96er Sport Rally'er
    MA
    '96 Tacoma XCab 4x4 SR5
    If those 5100's are set to zero, you will have a nice rake going. The 881's are rated for about 2" of lift whilst the rear leaf pack will go up 3". Are you using any sort of trim packer for extra front lift?
  10. Jun 16, 2010 at 11:27 AM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    congrats! lookin forward to seeing pics
  11. Jun 16, 2010 at 11:53 AM
    Wreckless_71
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    I'm thinking about setting the billies at .85" or just putting the trim packer in there. Plus I don't mind rake and I haul a lotta shit.
    Would that be ok? I'm not 100% sure that the OME's are the 881's either. I have yet to see em. I just told the guy I'd be there, cash in hand. I don't care what they are.
  12. Jun 17, 2010 at 12:12 AM
    Wreckless_71
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    Ok so I went down there and got my stuff tonight, so stoked. I got front 5100's, OME 881's, rear OME Dakar's, greasable shackles, brand new bilstein rear shocks that match up to the Dakar's, PLUS the guy threw in a 4.56 ring and pinion :) SCORE!
    Pics soon.
    Oh and I decided to take some measurements of how the truck sits right now on stock worn suspension. Those will be posted tomorrow also.
  13. Jun 17, 2010 at 12:24 AM
    Wreckless_71
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    Oh and I have a quick question for those of you that have the OME dakar's on the rear. Do you I need longer than stock U bolts for the rear end? I forgot to crawl under there while it was light out to see how much thread was on them stock...
  14. Jun 17, 2010 at 5:39 AM
    98tacoma27
    Ben
    Not Beech Creek
    It's always suggested to NOT reuse u-bolts. They are a relatively cheap part at your local autoparts store.
  15. Jun 17, 2010 at 10:23 AM
    96er
    96er Sport Rally'er
    MA
    Can you post or PM me where you found the Bilstein's with the .85" setting? Most I see now are either 0, 1 or 2.5. I'd like to use the .85" and level out my '96, and I feel the 1", even though technically level, won't look quite right. Thx.
  16. Jun 17, 2010 at 10:26 AM
    98tacoma27
    Ben
    Not Beech Creek
    First Gen billies have three settings versus the second gen having 4 settings. They don't have a .85 setting on the first gens. It's 0(stock), 1.25" and 2.5"
  17. Jun 17, 2010 at 11:20 AM
    96er
    96er Sport Rally'er
    MA
    What's easier to get, 1st gens or 2nd gens (when they are available)?
  18. Jun 17, 2010 at 12:28 PM
    Wreckless_71
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    Yup... the billies I got have only three settings on them so I assume, 0", 1.25", and 2.5". The guy that I got them from was running the billies set at 1.25" with the 881's and never had any issues. So I plan to stick with that...
  19. Jun 25, 2010 at 9:52 PM
    Wreckless_71
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    Took the afternoon off today and started taking the rig apart :)
    So I got the fronts off in literally a half an hour, I ran them to my buddies alignment shop so he could switch the top plates for me. I guess they were a total PITA. While he had the fronts I tore the rear apart and installed the new leaf springs, had to drill out the bump stops to accommodate for the length of the spring center pin. Used all new u-bolts, and shackles. Installed the shocks and it was done. Ran up and picked up the front billies and had to race to work. Off to the shop now to reinstall the front billies and tomorrow I need to get my new tires mounted and balanced, BFG KM2's :)
  20. Jun 25, 2010 at 10:09 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    pics man, pics man!!!!
