omg another suspension thread. but wait, I kinda know what I want.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sean73T, May 16, 2018.
  1. May 16, 2018 at 7:26 PM
    Sean73T
    Sean73T [OP] Well-Known Member
    Sean
    SoCal
    17 Pro
    Going to be lifting the new truck about 3 inches in the front on fox 2.5 extended travel coil over with remote resi and dsc. Don't want to have a ton of preload as I had on the last truck. Which coil does the forum recommend to swap out with the one that comes on the fox coil over.
    And for the rear, I will have the fox remote resi with DSC. But I want to change out the leafs. I do not carry much weight as I have another truck for that. I do NOT want to lift the rear, but I'd like to change it out as I feel it's super stiff with nothing in the bed, causing the rear to jump when going over any bumps at speed. What's the forum recommend?
    Thanks.
    PS, you'll get your pictures in due time.
    Joe23 likes this.
  2. May 16, 2018 at 7:37 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    If I remember right the rear is not 3 inches higher so if you lift the front 3 inches and don't lift the rear you'll be facing the sky.
    You're going for the same set up as me basically . But I have dakars leaf pack medium duty. It's actually pretty smooth .Better than OEM
    Dunno if you forgot to mention or don't know if you need it but if you're doing that much lift you'll need new UCA and to get that extended travel you're paying for you need UCA anyways.
    Before you ask I have total chaos and I absolutely love them
  3. May 16, 2018 at 7:46 PM
    Sean73T
    Sean
    SoCal
    17 Pro
    I had to lift the 17 PRO at least 2 inches to clear 285/70 Toyo MT's. I will be running Camburg's UCA. I imagine I'll have to lift a sport at least 3 inches to fit the same size tires.
  4. May 16, 2018 at 7:51 PM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    Lift isn't what allows 285s to fit
    Joe23 likes this.
  5. May 16, 2018 at 8:05 PM
    Joe23
    I'm guessing you understand that tire doesn't fit just with lift but also needs trimming of other things right?
    I run a 285 70 17 duratrac with roughly 2" of lift
    Pro isn't the 1" higher they claim it is. I've checked they're the same height
  6. May 16, 2018 at 8:14 PM
    Sean73T
    Sean
    SoCal
    17 Pro
    Yeah I'll be doing a CMC and trimming of the liner. It's not a question of how to fit the tires, as I've done in the past. I had a 16 sport lifted on on the same suspension for the most part, when it was parked next to my stock PRO, they were almost identical with the pro on smaller tires. I just don't want a bunch of preload as I've had in the past. I figured by changing the coils I could avoid that. These trucks have always had a ton of rake from the factory, which I'm personally not a fan of. So hoping to level it out.
  7. May 16, 2018 at 10:53 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    So most coilovers are not actually preloaded. This term gets thrown out a lot.
    If you are referencing that in regards to height adjustment, what’s wrong with that? The coilovers are designed for adjustment.
    Joe23 likes this.
  8. May 17, 2018 at 4:38 AM
    Joe23
    Are you adding other stuff? 3" shouldn't be running too much preload if you're not that heavy.
    I sag a lot in the front from armour and both batteries and when I do bumper I'll be switching to 700lbs springs.
    If you just switch to 700lbs springs without having the weight to actually need them your ride will be terrible
