OMG time to change diff fluids again.... two issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeremy_283, Jan 3, 2012.
  1. Jan 3, 2012 at 10:38 AM
    jeremy_283
    jeremy_283 [OP] Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    Time to change them out again. Few Questions....
    Last time I remember it being a PITA cause I had trouble getting the fluid into the differential and I couldn't find a pump to fit this bottle.
    Next, last time I didn't replace sealing washers. Should I this time? Do the washers tend to stick to the the bolt to where they wont come off?
  2. Jan 3, 2012 at 10:40 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    A pump like this should fit the bottle
  3. Jan 3, 2012 at 10:44 AM
    jeremy_283
    No local stores had it. Have any links or product codes to ensure i get the right one? I may need to order online.
  4. Jan 3, 2012 at 10:46 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Walmart should have it, if you have one close. Or a NAPA
  5. Jan 3, 2012 at 10:46 AM
    brett
    brett Member
    Texas Hill Country
    11 4x4 DCLB TRD Spot
    Weathertech floor liners, Procomp 3" lift, iON 18" wheels, Nitto TG 285/60-18
    Seems like i remember reading that the washers didn't need replacing. That said, they're cheap so do whatever helps you sleep at night.
    Also, removing the spare tire will help tremendously when it comes to filling with oil. The pump is nice but isn't necessary.
  6. Jan 3, 2012 at 10:47 AM
    jeremy_283
    it was a few years ago but I don't recall either store having it :spy:
    what I did find the threads didn't match
  7. Jan 3, 2012 at 10:47 AM
    Seabass
    Seabass Chrome won't get you home
    Adam
    AZ
    '06 Sport 4x4
    Let's be honest... you really only care about your own rig.
    Chris just removed the pump from the Jergen's lotion bottle on his nightstand, and then pulled the plastic tubing off of his penis pump.
  8. Jan 3, 2012 at 10:48 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Check the RV section....
    Been talking to your Mom again?
  9. Jan 3, 2012 at 10:49 AM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB MGM
    Afe CAI (removed back to stock intake), TSB 4 leaf pack with Firestone Air Bags and Daystar cradels, 3rd OEM HU, Wranger All Terrain Adventure with Kevlar 265/75/16, Cali raised LED pods, Wheeler Off Road Front Bump Stops.
    I had to remove the spare tire to fill my diff. I also had a pump already so I didn't have to go crazy finding one. The cheap pump fits most bottles so like stated above, walmart, pepboys should have it.
  10. Jan 3, 2012 at 10:51 AM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    yep...i just bought one at Walmart....its in the marine section.its a gear lube pump for outboard engines
  11. Jan 3, 2012 at 10:51 AM
    jeremy_283
    I see this talk of the rear diff but wasn't the front the worst for ya'll? I remember for me it seemed like it was...
  12. Jan 3, 2012 at 10:52 AM
    jeremy_283
    Thanks! I'll check again....
  13. Jan 3, 2012 at 11:09 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Never used a pump and don't recall having any issues with the front or rear. When I changed the transmission fluid, I used a funnel with a long hose that would make it up to the engine bay. That would work for any type of fluid although gear oil might take a while to make it through the hose...
  14. Jan 3, 2012 at 11:19 AM
    MQQSE
    MQQSE Afoot is the game
    Rob
    Palmer, AK
    Bought mine at local NAPA same time I bought the oil.
  15. Jan 3, 2012 at 12:09 PM
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Yeah, she said you owe her money again.
  16. Jan 3, 2012 at 12:26 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Washers don't need to be replaced.
    I've been using this for years with good results. Have seen them at all the automotive places, Wal Mart, NAPA, etc.
    Way easier and quicker than the bottle mounted pumps. Can be filled by removing the cap and filling from bottle, or can be used to suction the oil directly from the bottle. I find removing the cap and filling the cylinder much cleaner/quicker.
    http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=BK_7151245_0282450295
  17. Jan 3, 2012 at 12:28 PM
    xxaarraa
    xxaarraa Well-Known Member
    EDIT: I guess I should have bothered to read the post right above mine first! Same difference.
    I used one of these and it worked perfectly. Only issue was needing to refill the gun for every quart, but minimal wastage, no need to worry about gravity or angle. Well worth it for $10.
  18. Jan 3, 2012 at 12:36 PM
    huntark03
    huntark03 I'd rather be hunting!
    Maumelle, AR
    2005 Limited Tundra DC 4X4
    Spidertrax Wheel Spacers aFe Pro Dry Drop in Air Filter Weathertech Liners Bilstein 5100s w/ OME 885 coils and ToyTec 1.5" AALs Light Racing UCAs
    Sub'd for reference
  19. Jan 3, 2012 at 2:09 PM
    Bishop2Queens6
    SoCal
    2009 DCSB MGM
    Front wasn't that bad because it doesn't take as much fluid as the rear.
  20. Jan 3, 2012 at 2:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I offered to pay her, but she didnt have change for a buck.....Oh.....And she left her shoes at my house again.....
