OMG Which tires should I buy? (pics included!)
Discussion in 'Wheels & Tires' started by Taco Salad Sport, Dec 27, 2016.
  1. Dec 30, 2016 at 6:43 PM
    #61
    Sinner F.D.
    Sinner F.D. Member
    2013 Tacoma DCSB TRD Off-road
    I have the AT2's in the 265/70/r16 and I live in North Dakota. I commute daily on marginally driveable roads and I don't know if you keep up with the weather but we get a lot of snow and normally subzero temps. I've had zero issues with them even at -25 ambient sitting outside overnight on pavement. As several other posters have said they're snowflake rated and priced very reasonably. Yes the BFG's are nice having had them on an old Taco but I can't say enough good about the AT2's. Expedition Overland runs them, (check their YouTube channel), Mountain State Overland runs them, YouTube also, and a lot of people here do too. Best of luck in your decision! And I included a pic of the snow we get here. That was taken yesterday, Dec29th.
    ShOwStOpper likes this.
  2. Dec 30, 2016 at 7:08 PM
    #62
    barcelona7568
    barcelona7568 Well-Known Member
    CO
    16 DCLB, Stock
    Translation: I just moved here from CA and haven't adjusted my speed for conditions.
  3. Dec 30, 2016 at 7:13 PM
    #63
    EasyLivin
    EasyLivin Well-Known Member
    Jeff
    Euless, TX
    2014 White TRD OffRoad Double Cab
    Focal PS165AC / Focal PS165V / Alpine PDR V75 / Kenwood Excelon KFC-XW1000F / Leer 100XR shell / Bilstein 5100 lift
    Michelin LTX is what I have and they are great for snow and rain.
    Mush Mouse likes this.
  4. Dec 30, 2016 at 7:36 PM
    #64
    Sinner F.D.
    Sinner F.D. Member
    Haha that's too true. The drive into work after the first snow or ice of the season leaves the ditches littered with out of state cars.
  5. Dec 30, 2016 at 7:46 PM
    #65
    ShOwStOpper
    ShOwStOpper Well-Known Member
    i agree with everyone else here the General grabber AT2's are just killer all around tires,,great in the snow and quiet in summer got a nice aggressive look and insanely cheap if you shop around...
  6. Dec 31, 2016 at 8:42 AM
    #66
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    Can't argue......those look good. I'll post up pics after install
  7. Dec 31, 2016 at 11:59 AM
    #67
    BGXtobe
    BGXtobe Well-Known Member
    Central Valley, CA
    2016 MGM TRD Sport 4x4
    What's P rated mean?
    I'm a little confused with the P rated and C rated tire.
  8. Dec 31, 2016 at 2:04 PM
    #68
    Dark_Taco
    2023 TRD Pro
    Stock
    I miss typed.....was referring to P metric over LT tires.
  9. Jan 1, 2017 at 9:34 AM
    #69
    ThomasMore66
    Dallas/Fort Worth & Durango
    P=passenger car
    LT=light truck
    At least that's how I remember it.
    LT E rated tires are 10 ply and probably overkill, but I run them on my Tacoma and FZJ80. They are typically 50+ lbs depending the size, and will have some negative impact on gas mileage. However, you can drive over stuff. If you have cactus, mesquite, sharp rocks, etc., I say go for the LT E.
  10. Jan 1, 2017 at 9:47 AM
    #70
    Dawnpatrol
    Dawnpatrol Well-Known Member
    PNW
    I like the Michelin LTX AT2's (6ply). Work well for me in the sand, snow and snotty slick boat ramps up here in the PNW. I got 109,000 on the last pair and just put some new ones on the 2017.P1050304.jpg
  11. Jan 1, 2017 at 3:44 PM
    #71
    Architect
    Architect Well-Known Member
    ...and how many sets of of KO2s have you owned?
  12. Jan 7, 2017 at 2:54 AM
    #72
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    The Destination AT is what I run, I've had them for about a year and 15k. I don't rock crawl, not many places in Southern Maryland to do that, but I have taken it through quite a bit of mud and some snow with no issues. They aren't noisy and didn't kill my mpgs, only complaint is they pickup gravel by the handful.
  13. Jan 7, 2017 at 7:12 AM
    #73
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    they a pretty good tire and are priced good, mine got noisey around 40k and got nosier as they got more miles which was at the end of the treadlife anyway, but they performed best in snow conditions.
  14. Jan 8, 2017 at 4:13 PM
    #74
    tacomatyler
    tacomatyler Well-Known Member
    Tyler
    Kansas City
    2017 TRD Sport
    5100s & 884s, AAL, PRO SEMAs, Toyo ATs
    I've had the Cooper AT3s since 2013 and they're still like new about 35k miles later. Rotated annually. Great in all Midwest weather.
  15. Jan 8, 2017 at 4:30 PM
    #75
    Abragus
    Abragus Well-Known Member
    Adam
    Suffolk, VA
    I got the Cooper AT3's in 255/70/17 and so far they've been great. Didn't get stuck at all in the recent snowpocolypse in Virginia (4-6" in my area) and the ice.
    They've been great on the road too!
    1Shifter likes this.
  16. Jan 8, 2017 at 4:36 PM
    #76
    1Shifter
    Jeff
    09 PreRunner
    I took my Prerunner out today and did a little real world testing on the 8" snow we got the night before. My tires (Destination AT) have about 15K on em. No problems at all on gravel or dirt roads, up and down hills no worries. Can't wait for all of this to melt and turn the road into mud.
