OMU & Bilstein 4600?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jetta.the.hut, Aug 15, 2013.
  1. Aug 15, 2013 at 2:11 PM
    jetta.the.hut
    jetta.the.hut [OP] B4nn3d
    Aren
    Aberdeen,NC
    2013 Access Cab Long Bed 4x4
    trying to pick up a set of OME 885 coils without a spacer,toytec says you have to run longer struts, will a set of 4600's count or handle the lifted travel, i have a 2010 Prerunner SR5 but no TRD package. I'm not going to lift until i get the AAL for the back but would love to not have to spend 200 more on struts & shocks, i found a pair of 4600's local for less than 80 and 26,000 miles so i'd like to get those
  2. Aug 15, 2013 at 2:13 PM
    Large
    Large Red
    The 4600s are the OEM shocks I think, and they are cheaper than $80 brand new. You are better off going with OME shocks or 5100s.
  3. Aug 15, 2013 at 2:35 PM
    jetta.the.hut
    Aren
    Aberdeen,NC
    the TRD's came with non-adj. 5100's didnt they? mine are defintly not yellow & blue, all black.
    havent looked at a spindle lift, i thought i was doing good to not buy a tough country spacer lift
  4. Aug 15, 2013 at 2:36 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Your shocks are not bilsteins they are the crappy base shocks
  5. Aug 15, 2013 at 2:39 PM
    jetta.the.hut
    Aren
    Aberdeen,NC
    with no top spacer i shouldnt even get 3" of lift either, should be 2.25 to 2.75so if a spacer kit doesn't require it why does the 885's?
  6. Aug 15, 2013 at 2:47 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    since you have a prerunner you can do a spindle lift and keep the factory ride. or go the bilstein and ome coil route. yes you are doing well by staying away from spacer lifts! the 4600's will not work with aftermarket lift coil springs
  7. Aug 15, 2013 at 2:52 PM
    Blueitrgsr
    Blueitrgsr Well-Known Member
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Some bilsteins, OME 885's, and an AAL.
    huh???? That's a terribly worded question.
    are you asking why you do/do not need a top plate spacer?
  8. Aug 15, 2013 at 2:53 PM
    jetta.the.hut
    Aren
    Aberdeen,NC
    cool, thats what i needed to know. i hate it but i might have to buy slightly used on those too which sucks since i just hit 19,600 miles on my truck, i hate to put 35k mile stuts on it
  9. Aug 15, 2013 at 3:34 PM
    jetta.the.hut
    Aren
    Aberdeen,NC
    how do RevTek AAL's hold up vs, Dakar,ect..?
    i dont have the TSB 4 bar on mine
