?? on Bleeding Brake System (Brake Pads, Rotors)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dudewheresmytaco, May 16, 2012.
  1. May 16, 2012 at 6:27 AM
    dudewheresmytaco
    dudewheresmytaco [OP] Member
    North Texas
    06 PreRunner Doublecab TRD Offroad
    06 PreRunner Doublecab TRD Offroad, 3" toytec lift, 16" MotoMetal Wheels, Nitto Terra Grappler Tires - 285 75 16
    While changing my brake pads and rotors, I was working on the front passenger side, when i was pressing the piston down for space for the pad, the piston on the opposite side of the caliper shot out leaking out brake fluid. I assembled the caliper back and completed the brake pad and rotor swap with out bleeding or flushing the system. Now my brakes travel to the floor board with out much stopping power.
    I have a couple of question i was hoping to get feed back on. I have read many posts on TW and the rest of the internet on bleeding the brake system. but I was hoping to hear what an experienced "brake person" would think would be the best method for bleeding the system. I have read about the "gravity" method and this sounds rather simple and doable. I personally would prefer this method as getting a second set of hands for help may not be an option. But if other methods would be ideal in my situation I would like to know. Also, what is the correct order to bleed the system for our trucks?
    Second question is, I explained about the piston that shot out. I reassembled it with out replacing the boot or seal with new pieces. Should this be a real issue?
    Any and all answers are appreciated. Thx
  2. May 16, 2012 at 7:10 AM
    dudewheresmytaco
    North Texas
    B.T.W. my truck has over 100K miles. the rotors were practically welded to the hub. The stock rotors have 2 holes for screwing i think 12mm screw into for "popping" off the rotors. Didnt realize this till i was in the situation. Took a brake logged on to TW and came across it in a post here. Only found 1 post with this info so maybe adding it will come in handy to some one researching this info prior to starting this job.
  3. May 16, 2012 at 7:13 AM
    LieutenantFF
    LieutenantFF Member
    Bryan
    Altus Oklahoma
    2009 Tacoma Prerunner TRD
    Not to sure about the second part of the question, however the first part of the question is bleed from the brake farthest from the one with the leak (IE if left front was leaking, start with right rear then left rear then right front and then finally the leaky one) that way all of the all is pushed out correctly.
    bleeding the brakes is rather easy. there is a nipple on the back top of the caliper. loosen it, have second person push brakes down a few times and then have them hold the brakes to the floor. when they are holding brakes to floor loosen nipple to expel brake bluid and air. after each wheel check resivor for brake fluid level. keep it topped up. as to not put MORE air into system.
    the youtube vid i used.
    http://youtu.be/Hf1iPbeg778
  4. May 16, 2012 at 7:19 AM
    spithead051
    spithead051 Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    BRAKE FLUID (W/ VSC )
    This PDF goes over the correct way to bleed the brakes for Tacoma's with VSC. I have bled brakes for years and when I changed my brake lines I could not get the damn things to bleed for the life of me. After reading this, it is a pretty easy process, you just have to do a few things differently.
  5. May 16, 2012 at 7:37 AM
    dudewheresmytaco
    North Texas
    thank you spithead051 and LieutenantFF for the speedy replys. I will watch the video LieutenantFF posted and also use the manual spithead051 posted. thank you both.
  6. Mar 12, 2013 at 8:05 PM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    sorry bout the thread revival, just curious if this happened to anybody else, and did just reassembling it have any problems?
  7. Dec 3, 2013 at 8:48 PM
    fenderpicks
    fenderpicks Well-Known Member
    Soorry for bumping the thread, but why on earth do you have to turn the truck on , hear the pump, depress pedal 20+ times and repeat this process 2 - 3 times?
  8. Oct 22, 2015 at 1:54 PM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
  9. Oct 22, 2015 at 7:38 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    '15 Tacoma PreRunner V6 SR5 Auto
    If you are working alone, you can use a length of lumber - I use a piece of 2x6 to simulate a person pumping. Pump the pedal and lock it down with one end of the board on the brake pedal and the other up against the front of the drivers seat. You may wish to put a piece of clean towel/cloth around the end that butts up to the drivers seat.
  10. Oct 22, 2015 at 8:19 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Easiest way is to get a pressurized bleeder system 50 - 100 bucks and do them all at once by yourself.
  11. Oct 22, 2015 at 8:34 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    the bleeder is on the calipers as he mentioned.. but what about vehicles that have drum brakes in the rear?
  12. Oct 22, 2015 at 8:51 PM
    DoorDing
    DoorDing The game is afoot.
    Sussex Downs
    Hansom cab
    That, or a vacuum bleeder, like the Vacula I use. Very handy tool.
    The bleeder extends out of wheel cylinder, through the backing plate, near the brake line.
  13. Oct 22, 2015 at 8:52 PM
    ramonortiz55
    Ramon
    Texas
    stock
    thanks.
    remember bleeding brakes w my pops growing up, never had to do it now. figure it be handy i know how to do it.
  14. Oct 22, 2015 at 8:57 PM
    DoorDing
    Sussex Downs
    Hansom cab
    I use the Vacula to slurp as much old fluid as possible from the reservoir, and also attach it to an open bleeder when pressing a caliper all the way open to prevent pushing any accumulated debris into the system.
    I also spray the bleeders with brake-clean once I'm done to flush any remaining fluid from them, and I wash the truck well to make sure I don't leave any fluid anywhere else, including under the hood. Parts stores have replacement caps for the bleeders, if needed. You don't want them to get filled with crud.
  15. Oct 23, 2015 at 7:44 AM
    TacomaZL
    TacomaZL Well-Known Member
    Illinois
    2013 Toyota Tacoma 2.7L
    WeatherTech Floor Mats; 15" Cragar Black "D" Window Wheels; Custom Center Caps; 235/75/R15 Goodyear Radial Wranglers; "TOYOTA" Tailgate Decal; Magnetic Tool Storage (in Cabin); Stant Locking Gas Cap; Salex Glove box Organizer Debadged; BHLM; Aftermarket Fog lights; FlashWolves 1000 Lumen Reverse lights; DEPO Black LED Tail lights; Differential Extended Breather Mod; FalconZero F170HD+ Dashcam; Scosche MagicMount; Tyger Auto Tri-Fold Pickup Tonneau Cover;
    How do I know if I have VSC, and how often do you guys change your fluid? I know brake fluid is hygroscopic and needs to be changed eventually, but I know everyone has their own opinions on the subject.
    @Jimmyh
    @DoorDing
  16. Oct 23, 2015 at 8:19 AM
    jpachard
    jpachard Well-Known Member
    2006 4WD 4.0L Tacoma 6spd TRD
    I change my fluid once a year, more if I'm towing a lot. It's super cheap insurance and it's very easy to do, then again I bleed my racecar every weekend at the track so I can do this in my sleep. It's a nice way to check up on the overall health of one's brakes as I inspect my pads at the same time and give each wheel well an inspection.
  17. Oct 23, 2015 at 9:17 AM
    DoorDing
    Sussex Downs
    Hansom cab
    Your 2013 has VSC. I believe you'll find a switch for it to the left of the steering wheel.
    I change brake fluid every two years. It's cheap & easy, especially if you have a pressure or vacuum bleeder. At four years, I've seen a lot of contamination. Here's what 18 month old clutch & brake fluid from my Honda Civic Si looked like.
    BlueT likes this.
  18. Oct 23, 2015 at 10:06 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    /\ This, max life of brake fluid is around 5 years but 2 years is best especially when you live in humid climate.
    Brake fluid sucks moisture that turns into water in brake lines rusting them on the inside.
    Change brake fluid to avoid problems..
    DoorDing likes this.
  19. Oct 23, 2015 at 10:07 AM
    DoorDing
    Sussex Downs
    Hansom cab
    Not to mention what the crud does to seals. Rebuilding wheel cylinders is bad enough, but replacing an ABS pump isn't cheap.
  20. Oct 23, 2015 at 10:12 AM
    BlueT
    NorthEast
    Yep... I think the worst is replacing brake lines when they rust. I had to do this on my Ford and it was absolute pain in the Ass. They sell tubes as straight and you have to bend your shape, I thought I am going to go crazy..
