On Board Air blowing fuses
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EdinCincinnati, Jan 21, 2020.
  1. Jan 21, 2020 at 11:34 AM
    EdinCincinnati
    EdinCincinnati [OP] Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Well crap...
    “If it is necessary to mount the air compressor further away from the battery in the bed of your truck, use a minimum 8AWG positive lead wire for remote installation.”
    damn it.
    16Tacos likes this.
  2. Jan 21, 2020 at 11:42 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    If they gave you 20' of 12 gauge wire, it shouldn't make a difference where you mount it. Now, if you had to extend the loom for whatever reason, then it would advisable to upgrade to 8 gauge wire. 20' of 12 gauge wire will still have the same resistance whether its straight laid end to end or curled up in a spool.
    -J
  3. Jan 21, 2020 at 11:47 AM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    You need a fuse rated for more than the pump draws, not exactly what it draws.... I use a 50a breaker for my 30a compressor. All you're really doing is protecting the wires against a short.
    You didn't mention an on/off relay. Most cheap switches will fuse shut switching a 30a load. Maybe it's in the grey housing?
    EdinCincinnati[OP] likes this.
  4. Jan 21, 2020 at 12:05 PM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    There is a on/off relay in the grey pressure switch. Off at 145psi. On at 110psi. I have it wired to a manual remote switch that connects into the pressure switch - it’s part of the air gauge display at the far right in the first picture.
    and here:
    At this point, it is working fine with a 25Amp fuse. I have a spare 25 and a spare 30. I’m leaving it as is.
    Thanks everyone for your input!
    16Tacos likes this.
  5. Jan 21, 2020 at 12:26 PM
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    I realize things seem to be working now, but I am going to encourage you to go to a) thicker wire and b) a circuit breaker instead of a fuse. I initially ran 6g for an ARB dual in the bed and had the exact same problem with fuses. Ultimately I ran 4g to the bed with a breaker and havent reset it since.
    The lesson i have learned when it comes to wiring something like this is that it's generally better to spend the extra couple bucks on thicker wire given the time and effort to run power from the battery to the bed. Honestly I wish I had gone with 0g so I could support another secondary fuse panel in the bed for my bed camper setup. Just my .02 cents.
    Cudgel and EdinCincinnati[OP] like this.
  6. Jan 21, 2020 at 12:38 PM
    badger
    badger Well-Known Member
    07 SR5
    Can you hear the pressure release just as the compressor stops?
  7. Jan 21, 2020 at 1:01 PM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    no...pretty sure it doesn’t have one. Probably why it was a good deal.
  8. Jan 21, 2020 at 2:52 PM
    DG92071
    DG92071 Well-Known Member
    OP you're about 3 feet too long with 12 gauge wire, put a 30 amp fuse in it and leave it as is forever.
  9. Jan 21, 2020 at 3:03 PM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    when the 25Amp blows...the 30Amp spare is in the coin cubby ready and waiting
    DG92071[QUOTED] likes this.
  10. Jan 21, 2020 at 3:16 PM
    Littles
    Bryan
    Elizabeth, CO
    3 tons of fun
    Lol...I know it's been suggested by other members and I'm not saying it won't work, but you do know that replacing a blown fuse with a bigger one is like the epitome of what you're not supposed to do, right? I'm not trying to be a jerk here, but the whole point of the fuse is to make sure you're not drawing more power than the wires can handle. I mean you should be fine going from 25 to 30, but if the 30 amp fuse starts blowing, sticking in a 40 or 50 amp fuse is probably not the BEST solution and could potentially result in the truck fire you're trying to avoid. Going back to the wiring chart that was previously posted, 20ft of 12G wire with 25 amps is the upper limit of what the wires can handle. Thicker wires is the answer...not a higher amp fuse.
    badger likes this.
  11. Jan 21, 2020 at 3:21 PM
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    one more thing to consider, if you continue to blow fuses, you may want to try to run a fused power wire directly from the battery to the compressor (bypassing the fuse block). It looks like a blue sea fuse block which is only rated at 30a per terminal. if the compressor actually maxes out at 28a you should be fine but if it happens again, id bypass the fuse block just to rule that out as a potential bottleneck.
  12. Jan 21, 2020 at 3:23 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Do not just throw a bigger fuse on it and expect everything to work out okay.
    You're essentially taking a wiring system that maxes out at 25amps (based on the wire gauge you have, and the chart posted earlier), and going to a 30 amp fuse, which means you'll max out the wire before the fuse blows.
    I can't say why you were given 12g wire in that kit, but that honestly is a bit undersized, especially if you're throwing a 30 amp fuse on it. That chart is really showing you the minimums, when in doubt, go bigger.
    I'd run at least 10g, probably 8g if there's ever a chance you'd upgrade to a bigger 40a compressor.
    Littles likes this.
  13. Jan 21, 2020 at 3:24 PM
    Littles
    Bryan
    Elizabeth, CO
    3 tons of fun
    This is a really good point too...I would not recommend running something like a compressor off a blue sea fuse block. Run it directly to the battery with proper size wires and fuses or circuit breaker.
    rob1208[QUOTED] likes this.
  14. Jan 21, 2020 at 3:24 PM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    lol...yeah I have questionable judgment but I get it. I actually have 2 spare 25Amps and 1 30Amp in the coin cubby.
    And three fire extinguishers in my truck. You can see one in the previous picture.
    I will likely only use the air system a few times once a year to use the blow gun to blow the dog hair out of the bed but it’s fun to hit the little switch and see the gauge needle rise.
  15. Jan 21, 2020 at 3:28 PM
    #35
    jbrandt
    Justin
    Doesn't really matter if you have 20 fire extinguishers.
    A few feet of 8g wire will always be cheaper than repairing fire damage.
  16. Jan 21, 2020 at 3:33 PM
    #36
    Littles
    Bryan
    Elizabeth, CO
    3 tons of fun
  17. Jan 21, 2020 at 3:38 PM
    #37
    Do58
    Do58 Well-Known Member
    2015 white tacoma limited
    ^ This
  18. Jan 21, 2020 at 3:39 PM
    #38
    supmet
    supmet Well-Known Member
    Paul
    Rancho Cucamonga, CA
    2019 White TRD OR 4x4
    Maybe I'm being a bit pedantic, but that's not the main purpose of a fuse. Fuses have tons of uses protecting equipment from overloading, so a power surge or overloaded motor doesn't blow your multi thousand dollar PCB. I'm guessing a compressor motor has a little more tolerance for over amperage than other components, but there is more to picking a fuse than what wiring you are using.
    Generally if you aren't an EE(or at least studied in the field) and have some very specific knowledge on the electronics you are dealing with, the best course would be to ask the manufacturer what their recommended fuse is. Then figure out your wiring etc. based on that. It seems half the advice in the thread is working backwards.
    All that being said if the manufacturer included a 40A in the kit I'm not sure why this is a thread.
  19. Jan 21, 2020 at 3:47 PM
    #39
    badger
    07 SR5
    So I think we finally know enough to understand the issues here. First off, this needs to be a relayed harness, not direct wired through a switch. As mentioned, It should be directly off the battery, not the fuse block. With the distance between the battery and the bed, it should be wired with a minimum 6 awg wire, and 4awg would be better. That size is not so much for safety, but to prevent a voltage drop. A voltage drop will cause the compressor motor to run hotter, and reduce the performance of the compressor. It will also shorten the life of the compressor motor. That wire should run through a minimum 80A relay. The switch is only used to activate the relay, and the wires from the switch to the relay can be 16awg. There are lots of wild guesses in this thread about wire size. There is only one right answer. Measure the length of the wire from battery to compressor. Find the amp draw of the motor. Plug the numbers in here using 2% drop: https://www.wirebarn.com/Wire-Calculator-_ep_41.html That is the true size you need.
    You should have a release valve, also called a "blow-off valve" or "unloader valve". Whoever sold you the kit should know if one is there or not. If not, get one. You can find mechanical valves or electronic. Here is a good electronic valve (recommended): https://www.extremeoutback.com/product/electronic-blowoff-valve-12v-application/ Here is a mechanical valve: https://www.ebay.com/itm/CA-12-Load...8-Self-Unloading-Check-Valve-New/281915550936 This improve the function of the unit and keep it running a LOT longer!
    #39
  20. Jan 21, 2020 at 3:48 PM
    #40
    DG92071
    Replacing an undersized fuse with a correct size fuse poses zero threat of a fire.
    It probably came with a 40 amp fuse and 12 gauge wire because of the electrical surge a previous poster commented about. Wire ratings are for continual amperage draw and not spikes in the amperage draw. A 40 amp fast blow fuse (standard vehicle fuse) will blow just as quick as a 30 amp fuse with a dead short in the system with a 12 gauge wire. His truck has about 17' of wire and not 20'. It's amperage draw is 28 while running with a max load and not 25 amps. Lastly, a thicker wire will do absolutely nothing to prevent blowing a fuse that's too small to begin with.
    Bypassing the fuse block with that amount of current draw is an excellent idea which I personally would do but I don't think it's a mandatory must do job.
    All of these fire comments have me laughing my ass off. The OP's situation ain't even close to anything near catching fire lmao!!! You're fine OP, leave it.
    I've completely rewired 10 cars, everything from the headlights to the taillights and everything in between. I've completely rewired at least 15 boats, probably over 50 trailers, easily over 7,000+ car stereo amplifiers, several winches, probably over 20 off road lights, 10,000+ car alarms...
    Oh f___, an engineer posted lol I'm out, they're the freakin worst... oh snap he's bragging about his degree lmao see ya'!
