On Board Air brand Toyota Switch won't dim
Discussion in '2nd Gen. Tacomas (2005-2015)' started by smgcon, Nov 20, 2013.
  1. Nov 20, 2013 at 9:13 AM
    smgcon
    smgcon [OP] Well-Known Member
    Geoff
    Vernon, BC
    2013 DBC
    I bought one of the On Board Air Toyota look a like switches (looks like a Tacoma fog light switch) to install in my 2013 Double Cab. The switch installed properly and works well. The back light comes on and off with the dash lights, but does not dim.
    I have previously wired in the Toyota Highlander heated mirror upgrade from the forum here without difficulty, but this has me stumped. The OBA switch only has four wires: power in, out to the relay, ground, and a single wire for illumination which I wired to the green wire on a nearby factory switch.
    Any ideas?
    Thanks!
    Geoff
  2. Nov 20, 2013 at 9:18 AM
    Large
    Large Red
    I think the actual LED has to be a dimmable one.
  3. Nov 20, 2013 at 9:21 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    If it's like the fog light switch it goes
    Pos+
    Neg-
    Illumination
    Illumination
    Did you tap both illumination wires to both green illumination power wires from another switch?
  4. Nov 20, 2013 at 9:53 AM
    smgcon
    Geoff
    Vernon, BC
    2013 DBC
    Jerez:
    The pin out from the vendors wiring diagram is:
    1. +12 volt power in,
    2. relay pin 86
    3. ground,
    4. dash light or +12 volt
    I wired Pin 1 to ignition power, Pin 2 to the device, pin 3 to ground, and pin 4 to the solid green wire on a nearby switch. The back light comes on and off with dash lighting, but won't dim.
    The attached lights turn on and off as expected however the back light won't dim. Large may be correct, and the LED may not be dimmable.
  5. Nov 20, 2013 at 12:17 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    That's weird...any led I've added to switches have all dimmed perfectly
    Post a picture of the switch!
  6. Nov 20, 2013 at 12:32 PM
    Monkeyboy
    Monkeyboy Well-Known Member
    Grand Junction, CO
    2012 AC TRD Sport
    The dimmer in second gen tacoma works in reverse. The stock dash lights are grounded through the dimmer circuit that varies that ground voltage from 0V (full bright) to 12V (full dim).
    So, you can make your switch dim by grounding the switch to green/white instead of ground.
    However! Many after market switch bodies ground the switch and the switch LED through a common ground. This means that it is possible to backfeed current from the dimmer circuit through the switch to unknown and probably bad effect.
    So, If your switch has a separate illumination ground, ground it to green/white and it should work OK. If not, you'll have to build or acquire a voltage comparator to drive the LED with the difference of the light circuit (12V) and the dimmer circuit (0-12V) which will result in the light dimming (approximately) with the dash lights.
    This thread has some more info.
    Biscuits likes this.
  7. Nov 20, 2013 at 1:38 PM
    smgcon
    Geoff
    Vernon, BC
    2013 DBC
    I was afraid of that...
    I am okay with the inability to dim the backlight based on the fact that the breadboard circuit is not something I want to build right now.
    Thanks for the assistance however :)
  8. Jan 24, 2014 at 7:59 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
