On Board Air - Cheap!
Discussion in '2nd Gen. Builds (2005-2015)' started by HBMurphy, Sep 17, 2009.
  1. Sep 17, 2009 at 8:27 PM
    HBMurphy
    HBMurphy [OP] Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    On Board Air
    Stainless Steel 2.5 gallon tank with Cadillac Air Suspension Compressor(s)
    I’m currently getting the parts together for my on-board air system.
    My first part of my purchases was one of these for $25-30 (how to get them? – see below):
    You can pick these tanks (fire extinguisher) up for about 25-30 dollars. Call Erik in Tustin. 714-624-2070.
    Erik works in the fire extinguisher biz and sells these pressure tested and all for $25-30.
    He’s seems like a good dude and for out-of-area guys he can ship (I met him thru eBay). PM me if you want one next week. I’m going to meet up with him on Tuesday and maybe we could do a group buy thing.
    Combined with 1 or two of these compressors from a Caddy air ride suspension:
    You can pick these up for about $20-50 bucks
    I realize that this is somewhat of a tease right now but search Google for this and you’ll find a couple of setups.
  2. Sep 23, 2009 at 8:38 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Looking forward to the outcome!!!
  3. Sep 24, 2009 at 8:12 AM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    How much pressure can that compressor supply? Will it fill that tank @ 125PSi?
  4. Sep 24, 2009 at 8:28 AM
    ruler
    ruler Well-Known Member
    SoCal - Los Angeles - SGV
    08 Tacoma, TRD Sport, DC 4x4
    Fox Extended Travel Coilovers 2.5 (front), Fox 2.0 shocks (rear),Total Chaos UCA's, AllPro Expedition leaf pack, AllPro front plate style bumper,BHLM, GrillCraft MX series Grill, ATX Thug 17inch rims, Toyo Open Country MT (295,70,17), TRD CAI,Rear smoked LED tail lights, slimcubby HID Head Lights (50w 1200k), ADVMonster 60 Series 3600 Lumen LED Off Road Lights , Pioneer Avic-F700bt (navigation,head unit)
    one of my friends uses an old C02 tank, but if your gonna get a compressor why not just use a hose instead of lugging around a big old fire extiguisher ?
  5. Sep 24, 2009 at 8:34 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I have found they go anywhere from 80 to 100 psi:
    [SIZE=+7]Caddy Compressors and Fire Extinguisher Air Tank[/SIZE]
    This page outlines the procedures I used to modify two cadillac compressors and a fire extinguisher for on-board air.
    Having the freedom of going off roading and knowing there is a source of air after the trail is a great feeling. These sources of air include the Powertank, ViaAir air compressor, converting the air conditioning compressor and other various 12V air compressors. However, for those of us who are on a budget and like air conditioning, there aren't a lot of choices for that source of air. Every air compressor that is inexpensive also has a low flow rate, short duty cycle, and will not last long.
    Although the caddy air compressors are slow, they are still faster than the cheap Wal-mart specials. 1980's cadillacs used an air ride suspension system and to pressurize the system a 12V air compressor was used. The air compressor can be found on the driver's side of the engine compartment. Be sure to get the mounting brackets too. Some compressors are known to be made with plastic pistons and I'd assume these are on the late 80's caddies. I'd recommend looking for the early 80's models.
    First, I obtained two caddy compressors from the junkyard for $20 each. They were a lot smaller than I thought which was good because I still hadn't figured out where to mount them. I took them apart to see how they work and see how I can improve the flow. ​
    From my research I found that I could remove the electronic bleed off valve and the desiccant chamber. The electronic bleed off valve allows the cadillac suspension system to release air pressure and the desiccant chamber dries the air before it is released to the system. I didn't need the desiccant chamber because my air tank is stainless steel and should not rust, besides, I'll just empty it a couple times a year.
    Once removed, the electronic bleed off valve will leave a hole that needs to be plugged. Also, by removing the desiccant chamber I had opened up a hole that couldn't be used for air hose attachment. To plug these holes I JB welded them shut, as shown in the picture below.​
    However, with the output port plugged, how do I get air to the tires? Well, the best place to attach an air hose is the schraeder valve on the top of the compressor. It's the perfect size for the 1/4 inch ID of the hose, but the ID of the schraeder valve is tiny. I ended up drilling the valve larger to 7/32".
    In an attempt to provide the compressors with clean air I loosely stuffed oily foam in the area where the electronic bleed off valve was as shown in the above picture. I then punched out the sheet metal circle on the side of that chamber and sealed the opening on the top plate with aluminum foil as shown in the picture below.
    Other than general cleaning, that's all I did to the compressors. Now I needed a place to mount and wire them. Not wanting to move anything in the engine compartment I looked under the 4Runner. I found lots of space above the rear axle and to my surprize it was relatively clean, no mud splatters. And as for water crossings, that part of the body is about 8 inches above the bottom of the door sills, so at that point I think I have more things to worry about than getting the compressors wet. Besides, I don't think enough water can get in the compressors to do any damage, it's not like I'm running them while crossing a stream.
    So I drilled some holes in the body and screwed them there. I then ran some air hose from the two compressors into a manifold and into the inside of the runner. There I have a length of hose long enough to reach all 4 tires from inside or I can attach my air tank and fill it up.
    [FONT=Times New Roman, Times, serif]Fire Extinguisher Modification[/FONT]​
    As for the fire extinguisher air tank mod I got the idea from Roger Brown's website, who in turn stole the idea from somebody else.
    Disclaimer: Working with pressure vessels can be dangerous. I cannot guarantee the safety of the following procedures for modification, nor can I guarantee the safety of using a fire extinguisher as an air tank. Use at your own risk.
    Roger Brown's air compressor page.
    There is a fire extinguisher refilling company around the corner from my work so I walked over there and asked if they could donate a stainless steel water fire extinguisher tank that they had no use for. They said sure and I picked up one for me and one for my friend.
    The modifications were really easy. First, I removed the pick up tube on the inside and removed the handle and firing mechanism from the head. Then I drilled out the top (where the firing mechanism is) and tapped the hole with a 1/8 NPT tap. I also chased the hole where the hose was with the 1/8 NPT tap. These two ports are used for the inlet and outlet since they have the most material to work with and don't require too much more drilling. The holes where the gauge and the schraeder valve are have really small ports to the tank, so if you want to use them then you have to drill them out.
    Here's a few pictures of the tank:
    So how long does it take to fill up the tank and fill up the tires?
    Well, here's what my tests have shown:
    Tank only:
    0 PSI - 20 PSI takes 20 sec
    0 PSI - 40 PSI takes 40 sec
    0 PSI - 100 PSI takes 3 min 45 sec
    Tire, (1) 32x11.5 inch Pirelli Scorpion AT :
    With the tank filled to 100 PSI and the compressors running it takes 3 mins to fill from 10 PSI to 32 PSI.
    Without a tank it takes 5 mins to fill from 10 PSI to 32 PSI.
    http://www.robinhood4x4.com/compressors.htm
