On Board Air install (lots o' pics)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tooblutacoma06, Apr 6, 2011.
  1. Apr 6, 2011 at 8:15 PM
    tooblutacoma06
    tooblutacoma06 [OP] Member
    Kellon
    Houston
    Finally getting around to doing a write-up on this. It's been completed for a few months now. Atleast this way I can give a little feedback on the functionality:D
    Compressor: From seller SafeVehicleProducts on eBay. Evidently he's not selling compressors anymore but its identical (specs and looks) to the VIAIR 350C. 100% duty cycle with ~1.2cfm. Although it states it's 200psi capable, I won't ever need to drive it that high.
    Tank: VIAIR 2.5 gallon 200 psi tank. VIAIR 2.5gal tank The perfect size to fit in the spare tire cavity
    Wiring: 10 AWG since wiring long runs
    Hose: 3/8" ID hose (from Lowe's)
    Fittings: All types. These things suck to find and plan for. They are never as cheap as you would want them to be either. I did find some quick connect couplers that I like though. They are made by Legacy: Legacy ColorConnex couplers
    And lots of other miscellaneous stuff.
    On to some pictures:
    Started by finding a place to mount the compressor. I've seen this done before and it was the best place I could find to put it. Where it would be mostly protected and would be in my way under the hood.
    And back in the truck:
    Wired in the relay:
    Needed to find a place to put the switch, so I came up with this location. I actually like the location alot. Can't be seen from the rest of the vehicle's seats so it's kinda stealthy, atleast until you open the driver's door.
    Now I needed to mount the tank. Removed the spare since that is really the only place, besides the bed, that can handle a tank of useful size. Fabbed up some brackets of 3/16" steel, and it mounted up easily. It's tucked up out of the way but still easy to get to for draining.
    Can barely seem them in the picture, but I cut some spacers (white in the picture) that mount between the tank and the bracket on the drain side. This is so that the moisture will make it to the drain. It's a very slight angle. The spacers might be 1/4".
    Now the business end of the system. I fabbed up yet another bracket to hold a manifold in the engine bay. It mounts to the pre-tapped holes in the fender. Manifold is 2x 3/8", 3x 1/4"NPT. The 3/8" in comes from the tank in the back, the 3/8" out goes to my horns, 1 1/4" goes to the regulator, 1 1/4" goes to gauge, and the last one is capped for now. This setup has worked awesome so far. Oh, the black thing on the end of the coupler is just a little rubber cap to keep dirt out.
    The air pressure gauge inside the cab is from GlowShift: GlowShift gauge Honestly, the gauge is cheap. The bezel is flimsy and easily dented, the wiring is silly, and overall feel is a 6-7/10. Haven't tested its accuracy though. It's an OK buy for an inexpensive gauge, but if I were doing multiple gauges, I would probably invest in a little more well built unit. The color adaptability is a nice feature though.
    So you'll notice that the gauge is tilted here. That's because I'm still working on my pillar pod and the fit is really tight with the gauge. I'm living with it for now.
    That's it for now. The system has been used several times. I've aired up several tires and used the blowgun with it several times and it has performed well. Don't have times though. I haven't run any air tools with it, mainly because I don't own any, but I plan to test some out on it.
    That's it for now. Let me know what you think!
    Benson X, Toynado, Biscuits and 3 others like this.
  2. Apr 6, 2011 at 8:18 PM
    REVHARD25
    REVHARD25 Well-Known Member
    so cal
    RUGGED TRAIL PACKAGE
    Tint on front windows. Dnx7120 kenwood. Rear tsb springs. Wet okoles seat covers UWS truck box Weathertech floor mats TSB floor mat hook grommets Satoshi grill AFE drop in filter Fumoto drain valve Bed mat
    Great job..looks nice
  3. Apr 6, 2011 at 8:19 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    nice job man!
  4. Apr 6, 2011 at 8:21 PM
    ttran
    ttran Expert Mallcrawler
    Tim
    Cary, NC
    06 DCLB Prerunner Sport
    TRD Sport Prerunner
    Looks pretty good! I'm planning on getting on board air on my tacoma soon, just building up the funds now :D
  5. Apr 6, 2011 at 8:21 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Looks nice. Good writeup.
    Where is your spare going to go? Does it end up taking more space than the air tank would have?
  6. Apr 6, 2011 at 8:24 PM
    ilovetacos
    ilovetacos Well-Known Member
    Gavin
    Sacramento/Woodland
    2006 TRD Sport 4x4 DC
    Sold!
    Nice man! As always a well detailed write up!
  7. Apr 6, 2011 at 8:25 PM
    ruslanus
    ruslanus Well-Known Member
    Rus
    Wasilla, AK
    Nice write-up, thanks for taking your time. Onboard air system is on my list of things to do, but will have to wait for now. There are a lot of things I would like to do first
  8. Apr 6, 2011 at 8:39 PM
    tooblutacoma06
    Kellon
    Houston
    Thanks guys! Hopefully it will be of use to someone in the future. That's why I take so many pictures! I always need more info than I can find it seems.
    Since you asked...Custom tiregate build :D
    So nope, doesn't take up any of my bed space. Before the gate, I had the spare in the basket on top.
  9. Apr 6, 2011 at 8:55 PM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    Nice! very clean!
  10. Apr 6, 2011 at 8:55 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Were did you run the compressor wires? Did you go under the drivers seat?
  11. Apr 6, 2011 at 9:05 PM
    tooblutacoma06
    Kellon
    Houston
    Yep, through one of the rubber grommets. Sealed it with some RTV. Then along the frame bundled up in some loom.
  12. Apr 6, 2011 at 9:11 PM
    kinkrider101
    santa barbara
    wheels and tires
    Did you run the power wire for the switch and the compressor through firewall that leads to the engine bay? I ask because I can't find a way to wire something from the bed and have the wires directly lead to the engine bay
  13. Apr 6, 2011 at 9:37 PM
    tooblutacoma06
    Kellon
    Houston
    The switch in the cab only activates the relay. I'm pretty sure I ran the power wire up the inside of the fender, keeping it away from any hot surfaces, and loomed it ofcourse. It's been a little while since I did it! Haha, I'll have to check and make sure, but I'm about 98% sure that's what I did.
  14. Apr 6, 2011 at 10:27 PM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    From the picture it looks like when you rear squats it might hit the tank? Or is it just the angle of the picture?
  15. Apr 7, 2011 at 7:32 AM
    tooblutacoma06
    Kellon
    Houston
    Just the angle. It's away from the axle enough to where it wont hit. I'll try and get some more pictures of the clearance.
  16. Apr 7, 2011 at 12:36 PM
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    I NEED on board air...sometimes
    Sterling_vH111 likes this.
  17. Aug 20, 2011 at 12:28 AM
    Hayes
    Hayes Well-Known Member
    Brandon
    Denver, CO
    2011 Regular Cab Tacoma 4x4
    Any updates on how well this works? I have a different mounting idea, but this is the system that I would like to run.
  18. Aug 20, 2011 at 5:06 AM
    Hanz
    Hanz Well-Known Member
    Doug
    Long Island, NY
    2003 Tacoma DC 4X4 TRD
    LED Instrument lights
    I haven't seen this thread before. Really nice job with the write up and install. Very well thought out project.
  19. Aug 20, 2011 at 5:50 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    This thread is WIN!
    I just read through your other write-ups as well.:cool:
    You have some excellent fab skills buddy. :bowdown:
    Here are some more green squares for ya...;)
    +1 for mad skills.:D
  20. Aug 20, 2011 at 12:22 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Can't you just run a pressure regulator relay? That way the pump just comes on when the air pressure gets low to a certain point? I would think that would be better than running a dedicated switch no?
