On board air opinions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gordi, Jan 27, 2014.
  1. Jan 27, 2014 at 1:40 PM
    gordi
    gordi [OP] Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    I am looking for a OBA compressor that i can fit in the long bed cubby with some modification, I dont wanna mount a tank and just wanna use it to blow off gear and air up some quad tires on my 450 trx maybe fill a tire or two on a vehicle.
    Does that mean i Need a certain psi one that will push air the whole time its working?
    All info appreciated!
  2. Jan 27, 2014 at 2:42 PM
    fyremanpat
    fyremanpat Well-Known Member
    Pat
    757
    2013 DC LB TRD Sport w/Entune
    OME 886x and 5100's all the way around. Toytec AAL. Phillips x-treme vision headlights. 886 reverse lights. Borla exhaust. 20% tint. Hi 6 mod. 285/65/18 Nitto TG on 18" Moto Metal 955's. Airaid intake. Scanguage2.JBA LT's.GC Grill..more to come.
    without an air tank you're gonna need something with 100% duty cycle for anything you listed
  3. Jan 27, 2014 at 2:44 PM
    BamaToy1997
    Bill
    Navarre, FL
    Also, I would suggest highly against putting a compressor inside the cubby. Compressors generate heat, and when enclosed in that small of an area they can heat up quickly, and fail prematurely.
  4. Jan 27, 2014 at 3:41 PM
    Large
    Large Red
    Look on CL for a good viair, I found a 440P with a carrying case for $150 IIRC that was practically brand new.
  5. Jan 27, 2014 at 6:42 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    thanks everyone. I think the cubby with the door open and the lid off into the fender should be open enough. A hot engine bay under the hood surrounded by metal sounds worse. I do get the heat thing though. How much was the super flow?
  6. Jan 27, 2014 at 7:04 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Viair with a continuous duty rating; get one that's rated for at least whatever size tire you have on your truck.
  7. Jan 27, 2014 at 7:12 PM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    If you plan on running without a tank, you'll have to find a compressor with a built in pressure switch or run a small manifold with a pressure switch in it.
    As far as heat concerns, with most/all compressors you have to cut a hole for the heat sink regardless in the top of the cubby so it should have plenty of room to breath.
    Heres a link to my build thread with a few pictures of my compressor install in the cubby. Still not complete.
    http://www.tacomaworld.com/forum/2nd-gen-builds/213614-aaronarfs-2012-dcsb-build-8.html#post8059154
  8. Jan 28, 2014 at 11:24 AM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
  9. Jan 28, 2014 at 11:33 AM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    I have that same compressor and have it in my bed cubby. Works just fine, just takes a while. But I've aired it up and right after aired up my uncle's truck and it never over heated. I use it to air up my tires and ARB rear locker. I have a pressure switch and air gauge in the a-pilar. Then I have couplers extended to the front and rear bumper to help reach my tires. Pics of all of it in my build
  10. Jan 28, 2014 at 1:34 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    So the pressure switch is just for a tank right? I wanna not have a tank, i wont need much air and would rather the compressor just do the short work of filling a atv tire or dusting off something. So cant i just run power to it and then use it as if i hooked it to the battery.
  11. Jan 28, 2014 at 1:46 PM
    medic2230
    Murph
    Bama! Roll Tide
    How are you gonna get any pressure to blow something off w/o a tank to hold pressure?
  12. Jan 28, 2014 at 1:59 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    i thought you could get enough pressure from the motor itself with out a tank>? maybe im miss understanding 100% duty cycle at 150 psi?
  13. Jan 28, 2014 at 2:01 PM
    Large
    Large Red
    You use a pressure switch regardless, you don't need a tank. It just tells the compressor when to kill power.
  14. Jan 28, 2014 at 2:08 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    wouldnt the switch on the compressor kill the power? like the on off?
  15. Jan 28, 2014 at 2:27 PM
    3Leaf
    3Leaf Member
    Ben
    Sacramento Area
    06 TRD Sport
    Blacked out Badges
    You still need the pressure switch for when the air valve is closed, so the air line doesn't over pressurize.
  16. Jan 28, 2014 at 2:30 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    sounds good. so yes or no on having to have a tank?
  17. Jan 28, 2014 at 2:57 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
    You dont really need a tank to air up tires, but if you're looking to "blow off gear" like you were saying, you'll need a tank to build pressure
  18. Jan 28, 2014 at 3:18 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    would a 1 gal tank work well enough for that? how much does it actually hold>
