On Board Air or Winch?
Discussion in 'Off-Roading & Trails' started by Uncharted, Jul 26, 2010.
OBA or Winch?
Poll closed Aug 25, 2010.
  1. OBA
    14 vote(s)
    58.3%
  2. Winch
    8 vote(s)
    33.3%
  3. Neither
    2 vote(s)
    8.3%
  1. Jul 26, 2010 at 1:11 PM
    Uncharted
    Uncharted [OP] Well-Known Member
    Phoenix, AZ
    08 Taco
    Icon Extended Travel C/O's, TC UCA's, 285/70/17 Hankook Dynapro MT's, 17" XD Revolvers, Avid Off Road Sliders, Toytec TSB AAL, Rear 5100's, All Pro Front Bumper & Skids, Color Matched Grill, Grillcraft Upper, BHLM, Tinted Taillights, Lightforce 240's.
    So I'm trying to decide what my next mod will be.... OBA setup or a winch.
    I'm kinda leaning more toward the OBA because sooner or later I'll pick up an ARB locker for the rear. I'm kinda torn because a winch will always come in handy too.
    Viair OBA: Medium Use System
    Winch:
    Smittybilt 97281 XRC Black Winch/ Smittybilt 98281 XRC 8
    [​IMG] [​IMG]
  2. Jul 26, 2010 at 1:18 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I'd go with OBA, then save up for a winch later on.
  3. Jul 26, 2010 at 1:27 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    If I were you, and knowing what I no now, I would bypass both and get a CO2 setup - you can air up very fast. You can pick up a tank for $40-130, a regulator for $50-150 (AirSorce) and a hose and chuck. It will also require you to refill the tanks from time-to-time. Aside from that you will be back on the road in 5 minutes!!!
  4. Jul 26, 2010 at 1:31 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    oba for the locker :D
  5. Jul 26, 2010 at 1:32 PM
    JasoTaco
    JasoTaco Well-Known Member
    Salt Lake City, Utah
    09 Tacoma TRD Off Road
    ToyTec Ultimate 3" Lift -TSB Rear springs - TRD Cold Air Intake - TRD Skid Plate - Total Chaos Upper Control Arms - 2 Hella Rallye 4000 lights (130W Bulbs) - Clear Bra - Under Coat - Bed extener - Toyota Bed Mat - Weathertech floor mats - Tailgate hose clamp & washer mod - PIAA Fog Lights - ScanGauge II - Beefed Sliders - Differential Breather Mod - Heated Seats - All-Pro Bumper - Warn M8000 Winch with wireless controls - Boztec Diff Skid - ATO skids
    I vote for OBA, that way you are only small mod away from a train horn. A winch + new bumper is a MUCH larger expense than OBA.
  6. Jul 26, 2010 at 1:32 PM
    Uncharted
    Phoenix, AZ
    08 Taco
    And then you would just run the locker off of a CO2 setup too?
  7. Jul 26, 2010 at 1:34 PM
    Incognito
    VA
    No I don't think that is possible, someone correct me if I'm wrong. The CO2 makes it quicker to air up tires, and that's the extent of it IIRC.
  8. Jul 26, 2010 at 1:35 PM
    C17Guy
    C17Guy Well-Known Member
    Dennis
    Charleston, SC/ Charlotte, NC
    09 SR5 Access Cab 5 Lugger
    Readylift Kit, 245/75/16, HID's, Debadged, Kenwood DNX9960 Double Din Navigation, Image Dynamics Door Components, Pioneer Amp, Dynomax Super Turbo Muffler, Grillcraft Uppers and Lowers
    yep
  9. Jul 26, 2010 at 1:56 PM
    HBMurphy
    Paul
    So California Coast
    None
    Not a bad idea. I do like the idea of a compressor too. I have the hi-volume ARB for my locker and if I was in a real pinch, I could air up using the ARB if I ran out of CO2.
  10. Jul 26, 2010 at 2:00 PM
    HBMurphy
    Paul
    So California Coast
    None
    Is possible and many do it - heres some highlights
    http://www.offroad.com/trucks-4x4/tech/using-co2-for-your-locker-20454.html
    Also - probably the best way to drive an impact tool off road as well. Try to do that with the illustrated set up.
  11. Jul 26, 2010 at 2:10 PM
    Uncharted
    Phoenix, AZ
    08 Taco
  12. Jul 26, 2010 at 2:15 PM
    HBMurphy
    Paul
    So California Coast
    None
    All this talk of CO2 made me order a 10 lb tank to go next to my 20 lb tank so that I can always make sure I have one with juice in the garage. I hate this site!!
  13. Jul 26, 2010 at 2:53 PM
    SiRMarlon
    SiRMarlon The Photo Ninja!
    Marlon
    Los Angeles
    Canon 5D MarkIII
    Here you go...:D
    Co2 Tanks - http://www.beveragefactory.com/draftbeer/tanks/co2.shtml
    Regulator - http://www.trdparts4u.com/Scripts/prodView.asp?idproduct=-7165
    And I vote for Both! :)
  14. Jul 26, 2010 at 2:56 PM
    Incognito
    VA
  15. Jul 26, 2010 at 2:59 PM
    HBMurphy
    Paul
    So California Coast
    None
    That's where I learned about it!!!! :) the only thing that you may want to do differntly is the hose - I don't think the temperature of the CO2 screaming through the regulator and line will last as long - it may make the hose brittle (higher the velocity - lower the pressure - lower the temperature).
  16. Jul 26, 2010 at 5:27 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Why not get a cheap air pump and a good winch, then save for oba and locker? It may take longer to air up, but you can still get un-stuck.
  17. Jul 26, 2010 at 5:39 PM
    1welder
    1welder Well-Known Member
    tony grace
    edgewood, tx.
    98' ext. cab
    toytec coilovers, bil 5100's, dakar leafs, e-locker rear,aussie front, 4x innovations sliders,cooper stt's 32x11.5x15, max 4 marathon seat covers,
    i think OBA system is the next mod i'll do to my truck. i just got my smittybuilt XRC 8000 from ups today and hopefully tim will be shipping my bumper this week from relentless fab. so i'll be watchin this thread to see which direction you go. CO2 or air. i think i like the way siRMarlon did his and i def. like the price tag!
  18. Jul 26, 2010 at 6:23 PM
    HBMurphy
    Paul
    So California Coast
    None
    In the words of someone I know (who is very wealthy) "I can't afford to buy something twice!" :)
  19. Jul 26, 2010 at 6:25 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    I agree, but you can't take oba out and put it in your wife's vehicle.
  20. Jul 26, 2010 at 6:29 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    My point is, leave the small one in her car for emergencies with a plug kit. You can't be in two places at once, right?
