On Board Air Setup Questions and Accessories
Discussion in '2nd Gen. Tacomas (2005-2015)' started by idgara007, Jul 26, 2012.
  1. Jul 26, 2012 at 10:54 PM
    idgara007
    idgara007 [OP] Active Member
    tx/CA
    09 TRD Sport double cab
    As the title states, I am interested in a good compressor for general purpose uses like airing the tires, using some air tools, and providing air to a new horn (and lockers when I finally get some). Does anyone have any recommendations for a good compressor? I know arb and viair are pretty reputable brands. What type of features or performance should I look for? If I understand correctly a 100% duty cycle means that it would never need a cool down period so it could constantly compress air. What about psi ratings or mass flow rates? Higher would be better so it could fill a tank faster, correct? Then what size tank should suffice for various needs, but be small enough to fit underneath the truckbed (or another compartment)?
    Next, what other pieces are needed for an OBA setup? I know the compressor, wiring, relay, switch, and fuse/circuit breaker, air lines, tank, but what else? I have seen a water catch/filter, manifolds, gauges, etc but Idk what is necessary.
    Lastly for the immediate use (other than air lines for tires) would be for an air horn. I know some people love or hate the train horns, but Im interested in the big rig ones. They arent as loud and I personally think they sound cooler. As a kid hearing that sound I knew some bad ass truck was comin by so I guess I want that sound as well haha But there are so many vendors of train horns and such, but what would I look for to get the big rig style? maybe its just a different size to the same air horn, so then does anyone know of a good brand/material/size for air horns?
    I know I wrote a ton, but I wanted to go into depth to describe my situation. Thanks a lot for the help guys!
  2. Jul 26, 2012 at 10:59 PM
    poison
    poison Well-Known Member
    Keith
    Denver, CO
    05 DCSB SR5
    topper, bed cabinet/storage system, roof racks, iPod adapter, rooftop tent
  3. Jul 28, 2012 at 10:40 PM
    idgara007
    tx/CA
    That is a pretty nice compressor. I am also curious about installation whether or not certain placements are better. Like you said engine compartment is one option if there is space might as well use it, but it gets very hot in there. Also its close to the battery to do all the wiring. Another placeis in the bed cubbies, so thats out of the way, not very hot but farther from the battery and switches. idk if there are any others. hopefully we can get some more people to chime in haha
  4. Jul 28, 2012 at 10:47 PM
    medic2230
    Murph
    Bama! Roll Tide
  5. Jul 30, 2012 at 8:57 AM
    550kawirider
    550kawirider Well-Known Member
    Bryceson
    Visalia, CA
    '09 TRD Sport DC SR5 4X4 - Mag Grey
    Magnaflow Cat-back Exhaust, 2 10'' Image Dynamics IQD.V4, JCV 2DIN, Axxcess Steering Wheel Controller, MB Quart ONXY Component speakers, OME 855 Coils, 5100's Front/Rear, 1/4 Taco Lean spacer Firestone Ride Rite Air bags, GloShift Dual Digital Air Guage/Needle Gauge, LotTek A Pillar Dual Gauge Pod, Powder Coated TRD Sport Rims, Coverking Seat Covers, Custom Interior Lighting, Custom TRD Sport Decals, Tint, In cab power outlet, Fog anytime mod, Backup camera anytime mod, Blue Sea Systems 6 bank fuse block w/ thermal switch, Viper 5901 Security/Remote Start, LED Bed Lights, Blacked out Badges, In-cab air bag controller, 265/70/17 Duratracs, Viair On-board Air System, Grover Semi truck air horn, Rhino Rack over bed rack system
    I finished my OBA install a few months ago. I went with the Viair kit (10007) with a 450c 100% duty cycle compressor mounted in the driver side storage compartment and a 2.5 gallon tank mounted under the bed, over the rear diff. The kit comes with everything you need for a basic install (pressure switch, gauge, few fittings, ect...) Currently i have my air bags, semi horn, air gauge, and air chucks hooked up to the tank. I would suggest getting a 100% duty cycle compressor because you will find yourself constantly recharging a 2.5gal tank (esp when running an air horn and filling tires).
    As for the air horn, i found a Grover 32'' semi-truck horn for cheep. I promised my GF that I would only use it for good rather than evil but it is the funniest thing scaring the piss out of ahole Prius' that cut me off!
    My install was a bit complicated (esp mounting the tank and installing/plumbing everything for the air springs) let me know if you have any questions or want pics of my install.
    -BKY
  6. Sep 4, 2012 at 8:10 AM
    Rebel Taco Man
    Rebel Taco Man Well-Known Member
    Tyler
    Western Kentucky
    2002 Manual TRD SR5 4x4
    Bilsteins front and rear, Eibachs up front, 2" Toytec AAL in rear, Diff Drop, Grey Wire Mod
    Cadillac Air level/ride system compressor. this seems like a neat idea. and shouldnt be to hard to do.
  7. Sep 18, 2012 at 12:06 AM
    Mach375
    Mach375 Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    http://www.amazon.com/Masterflow-High-Volume-Compressor-Inflator/dp/B004CNSKX0
    This is the one I have. I am currently (as in, this week) moving it from under-seat-storage to hardmounting in the engine bay, between the ABS pump and the air intake (upside-down, mounted to the side, with bracket support from below). I'll be adding a high-flow computer cooling fan to the head so as to help keep it cool, as well as isolate it via double-wall divider.
    I'll be using plastic big-rig air line to route throughout the truck. The plan is to have a dedicated in line and out line for the tank: in from the compressor, out for use. I'm not, at this point, planning on running a single-line system where everything feeds directly off the compressor. My thinking is this allows me to remove any water and contaminants from the air before I use it.
    I have an old Craftsman 3-gallon 120V compressor a neighbor gave me. I'll be cannibalizing it for parts (tank, safety valve, etc). Haven't quite worked out where the tank is going, but that's kinda small beans. There is an off-chance I'll just use a few runs of large-diameter black iron pipe mounted to the inside of the frame to give me capacity.
    The last thing the charged air will see before going into the tank will be a filter/separator. I have a couple laying around.
    The tank will have a drain valve, of course. I'll include Schrader valves so I can fill the tank at a service station if I want (saves wear and tear on the compressor).
    Usage will include: pressure gauge, horn, suspension bags, F/R ports (for airing up on the trail), maybe a blowgun for the interior (truck stops/shops have these), and eventual lockers F/R.
    Control will be from the dash with an auto/off switch.
    Anyone want to add/critique/recommend anything to this?
  8. Sep 18, 2012 at 12:07 AM
    Mach375
    Btw- the place to get most of the parts is a junkyard that carries big-rigs. If you want new, go to a truck shop.
  9. Sep 18, 2012 at 5:29 AM
    rockdamage
    rockdamage Member
    Las Vegas
    Brute Force Fab rear bumper, Bilstein 5100
  10. Sep 18, 2012 at 6:37 AM
    ShawnR
    ShawnR Roads?? We don't need no stinkin' roads...
    Shawn
    Denver
    10 Taco TRD OR access cab
    PIAA driving lights,Pioneer AVH-P3300BT stereo with HD radio and Axxess steering wheel control adapter,rearview mirror mod,ReTrax rolling cover,Demello front bumper,WeatherTech,10 inch woofer,500 watt amp,CB in armrest, heated Wet Okole seat covers,Spidertrax spacers, ARB twin compressor,Ikon 10,500lb wireless winch,A-pillar RAM mount,Pull-Pal,electric locking tailgate
    My stepson has a scuba tank in his Jeep to air his tires.
    I am planning to do the same and use an 80cf steel scuba tank. Steel ones are about 20 inches long and 7 1/2 inches diameter. It should fit under the hood on the passenger side.
    A regular tire has about 5-6 cf of air in it, so 80 can inflate a lot of tires, you don't need electric, it doesn't get too hot, and most important, it can air up at a very fast rate, since the tank starts at 3000psi. You can also carry it around to other vehicles if you are helping others air up in a group setting. The downside-you have to go get it filled for $15 occassionally, and unless you can find a cheap used one, the tank will cost about $350, plus hose and regulator.
  11. Sep 18, 2012 at 8:28 PM
    Hounddog
    Hounddog Active Member
    Calgary, Alberta
    '08 taco
    Have you considered co2? I don't think I paid much more for my PowerTank. There are other companies beside PowerTank and some are less $$ too!
  12. Sep 26, 2012 at 7:42 AM
    idgara007
    tx/CA
    This is the compressor I ended up getting. However, I just moved down to Florida and still adjusting, moving in, etc so I wont be able to install it for a few weeks. I'm still looking for a good semi truck air horn though. I'm probably going to install the tank and comp under the bed maybe in the cubbies. gonna use a contura V series switch and probably copper for heat dissipation and water condensing purposes to plumb from the comp to the tank. Then maybe just rubber hose to the QD mounts on the front, rear and horns. Barlowrs build helped me a lot
