On-board Bottle Jack for 3" Lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jmed99, Jul 6, 2010.
  1. Jul 9, 2010 at 1:58 PM
    #41
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    You should look at DoubleCabMike's setup - It's a floor jack with a Engage Off Road piece attached. I've used it and I think it is one of the best setup's out there! :)
    At ~26 pounds, when going out on a long ride with others, pound-for-pound next best thing to a full-sized spare!
  2. Jul 9, 2010 at 2:21 PM
    #42
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    ^^yup! there are cupons for them that are like 60 bucks
  3. Jul 9, 2010 at 4:17 PM
    #43
    jmed99
    jmed99 [OP] Well-Known Member
    SC
    09 DC PreRunner TRD OR
    14" aint enuff
  4. Jul 9, 2010 at 5:14 PM
    #44
    CtTaco
    CtTaco Well-Known Member
    Eric
    Connecticut
    2010 4x4 Doublecab Sport Longbed Supercharged
    3" lift, Tundra wheels with BFG ATKO's, Viper Remote starter TRD Supercharger
    Yup, that was me...no sliders and the stock bottle jack. I have a 60" highlift (50 bucks on craigslist :) ) but way to use it on this truck. I suppose I could use it in the rear receiver hitch for the back, but does anyone have a solution for the front? and to those people using 2x6's to make the stock jack taller, have you ever seen a piece split while doing that :eek:. Really scary stuff happens...there's gotta be a solution someone has come up with for the front...
  5. Jul 9, 2010 at 5:18 PM
    #45
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    The better question is... how are you going to drive your truck around with a 31" spare tire on one side and a 33" tire on the other side? That is the question!
  6. Jul 9, 2010 at 5:19 PM
    #46
    DrRabbitFurHead
    Salem, VA
    best reply of the year!!! :d
    ricco333, daveleau and Taco-Obsessed like this.
  7. Jul 10, 2010 at 12:59 PM
    #47
    jmed99
    SC
    As long as the 31 is on the front you'll be ok. No biggie there.
  8. Jul 10, 2010 at 5:17 PM
    #48
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Don't jack off of the LCA. That's an accident waiting to happen. Hi lift that fucker or get some 2x4s to put under the jack or between the jack and the frame.
    Second, compressing the spring with that flimsy ratchet strap is another fucking accident waiting to happen. Spring that can take half the weight of the vehicle or a Wally World ratchet strap with a 250-500lbs breaking limit...
    Air down the 33" till it's the same rolling diameter as the 31"?
  9. Jul 21, 2010 at 9:08 PM
    #49
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    Yeah, but if your tires are full of nitrogen, you can just use a small stick to lift your truck. ... :D
  10. Mar 12, 2016 at 1:31 AM
    #50
    m00seNUckLEz
    m00seNUckLEz tAc0 aFiCi0nAd0
    Fresno, CA
    Under Construction
    I made a heavy duty stand for my factory bottle Jack. I found some scrap C-Channel at work and used that. I measure the inside of my spare tire well and cut the pieces to fit inside my spare tire when not in use. Welded the pieces into an X configuration. Drilled and tapped holes for two bolts to secure the bottle to the stand. Then drilled a large hole in the center for the spare tire chain and holder to fit through. Just finished it tonight. Going to have it powder coated in the next few days then store it in the truck
    bax, Relyk711, jcmotr and 3 others like this.
  11. Jan 21, 2017 at 12:59 PM
    #51
    000doodie000
    000doodie000 Well-Known Member
    J
    2015 Taco TRD Off-Road
    Many and always modding Wheels Suspension lift Armor Electrical gadgets etc...
