On board shower using exhaust heat?
Discussion in 'Technical Chat' started by Spencer, Jun 24, 2014.
  1. Jun 25, 2014 at 9:07 PM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    I see what you are after now. I converted my houses to on demand hot water.(Renai). Uses almost nothing to ignite,just need pressurized water source. But what you are after looks totally cool.:D
  2. Jun 26, 2014 at 9:05 PM
    Spencer
    Spencer [OP] Future President
    TIGGLEBITTIES
    Upland, Chino... all of 909.
    2013 DCSB 4X4 6cyl Sex Machine
    Redline hood lift, Flyzeye cabin lights, tailgate lock, SPOD Power block, VIAR onboard air, Cobra CB radio, Firestick 4' Antenna, Hot Blonde CoPilot Mod, SIX 9" Hella 4000 HID conversion with external 55W ballasts, Six 6" LED bars, Napier Bed Tent, Mudflaps delete using rocks, Roof rack by Brute force, Rock sliders by Brute force, Bed LED lights, Underhood LED automatic lights, Constant 12V bed plug, Rugged race radio, ICON uniball UCA's, KING 2.5 700 rate coilovers, Deaver rear leaf springs, KING 2.5 resi rear shocks (Flat 0.15 stack on compression shims), Scangauge, Empty wallet Mod Bug disease, AllPro Apex front bumper, On board heat exchange shower & water pump (Heater Core intercept mod), On Board Air - Viair for now, ARB when it dies-, allpro Skids back to gas tank- Tepui RTT on the shittiest "Bed Rack" ever made.... AllPro U Bolt flip kit with timbren bumps NEXT UP- expo leafs & bed rack, hydraulic bumps in rear, Total Chaos stock LCA's w/ Bypass, Rear 12" shock hoop relocate
    Bought all the parts today except hose etc
    Can't wait to get this thing set up!
  3. Jun 26, 2014 at 9:06 PM
    Spencer
    TIGGLEBITTIES
    If you come across this thread, go find the
    On Board Water thread by SkyGear- rather than chasing down info on 4 different ones I'm moving all questions and progress to there.
  4. Jun 26, 2014 at 11:02 PM
    skygear
    skygear                    
    Wow. um... just make sure theres a Heatshield where you decide to put the copper if you do.
  5. Jun 30, 2014 at 5:30 PM
    Spencer
    TIGGLEBITTIES
    Here goes nothin
  6. Jun 30, 2014 at 10:42 PM
    skygear
    skygear                    
    Son, you're gunna shoot your eye out with that thing.
  7. Jun 30, 2014 at 10:44 PM
    skygear
    skygear                    
    I'm opting for the larger surface area version and less plates as to not hinder the flow/ run into pressure issues
  8. Jun 30, 2014 at 10:52 PM
    Spencer
    TIGGLEBITTIES
    While I agree with your logic,
    I could whip out my nitrogen flow meter test gear from work & give a legitimate figure as to the resistance of this thing
    Or I could just tell you I went the old fashioned way and blew really hard in one end & felt very little resistance.
    I'm not sure exactly what pressure / flow rate the stock system circulates at, but I think this is gonna work perfectly.
    I'm about halfway through wrestling with putting fiberglass on it so expect a slow update for a couple days.
    I've gotta get this thing done before deer season opens though we're camping outta this truck for 8 days!
  9. Jul 1, 2014 at 9:33 PM
    skygear
    skygear                    
    It was mentioned before me ;)
  10. Jul 1, 2014 at 9:46 PM
    Spencer
    TIGGLEBITTIES
    Step one:
    Find a spot for your heat exchanger
    I chose next to the battery- close to the splices on the heater core hose & out of the way.
    This doodad was in the way.
    Found this
    Appears to be the fuel pump resistor & safe to relocate without screwing with VSC or airbags etc
    You need to pull it up, remove this L bracket, flip it over to mount upside down & put it off toward the fender in the hole that the wire loom clip was in.
    Wires around it were zip tied up away from it for safety- this thing has heat sink fins on it for a reason & I don't want to know why when it's too late.
  11. Jul 1, 2014 at 9:50 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I have no actual use for this, but :popcorn: nonetheless. Awesome idea.
  12. Jul 2, 2014 at 6:33 AM
    tweeek
    tweeek Well-Known Member
    Victoria, BC
    2006 Tacoma Access Cab TRD OR
    I built a onboard shower using the same concept.
    You will need a thermostatic mixing valve on the output. If you turn the shower off to lather/conserve water or something, the water will sit in the heat exchanger and become scaulding hot. It can severly burn you for the first few seconds!! With all those plates in that beast of an exchanger, I would seriosuly consider a thermostatic mixing valve. Will prevent scaulding and maintain a regulated temp. Especially if other people are going to want to use it (they will)
    They aren't cheap, but nothing in the project is. Worth the $$ though.
    I found you need to raise your engine idle slightly too. 1050 to 1100 seems to work fine. At idle, I find the engine doesn't circulate enough hot water to get the shower water more than lukewarm. A camera tripod against the seat works nicely ;)
    I have used mine many times now. It works flawlessly, and is amazingly refreshing. Great backcountry camping mod. Let me know of you have any questions.
  13. Jul 2, 2014 at 1:36 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Spencer, what is the purpose of the fiberglass and where are you using it?
    Thanks.
    Curious about your setup. Did you write it up by chance? I've seen quoted posts by yourself in Skygear's On Board Water thread.
  14. Jul 2, 2014 at 2:57 PM
    skygear
    skygear                    
    If you click on the view original if you are on tapatalk, it takes you to the original thread/post. Same if you click the little blue arrow in the quoted text on a computer
  15. Jul 2, 2014 at 7:17 PM
    #35
    Spencer
    TIGGLEBITTIES
    I've got a thermostatic mixing valve just for this purpose! Glad to know I'm on the right track.
    My question now is
    Which of these is the supply / return? More specifically, which way does the water flow? My setup is using a 3 way ball valve & a hydraulic check valve so if I do it right, I'll have an idiot proof bypass & if I do it wrong, I'll have a busted tacoma.
    Any help would be appreciated! Standing here with fittings in Hand scratching my head
  16. Jul 2, 2014 at 7:24 PM
    #36
    tweeek
    Victoria, BC
    As far as I know, the top is input to heater core and bottom is return. I tapped into the bottom line, right where the factory splice is (why did they do that? ?)
    All I did to verify was turn the heater fan on full blast, the bottom hose was noticeably cooler. You may want to verify if you are using a check valve, why is the check valve necessary?
  17. Jul 2, 2014 at 8:05 PM
    #37
    Spencer
    TIGGLEBITTIES
    This.
    My design has a check valve & one three way valve (labelled but not pictured )
    That way, it's idiot proof. No matter which way you turn it, engine is getting circulation. No chance of accidentally turning them shut & damaging something. And in case of damage, anyone could pop the hood throw the valve and keep it running.
  18. Jul 3, 2014 at 6:29 AM
    #38
    Spencer
    TIGGLEBITTIES
    Assembled version of poorly illustrated photo above.
  19. Jul 3, 2014 at 7:12 PM
    #39
    Crom
    Nick
    San Diego, CA
    Millions
    Spencer, does that heat exchanger use 1/2" hose barbs? Is it model B3-12A?
    Did you find out what sized fittings the Tacoma uses in the factory heater core hoses?
    Edit: According to a search at auto parts online the Tacoma factory heater hose is 5/8". Can you confirm that?
    Thanks is advance.
  20. Jul 3, 2014 at 9:14 PM
    #40
    Spencer
    TIGGLEBITTIES
    I got the 1/2" barbed model heat exchange to save me 4 fittings.
    The stock hose fits 5/8.... But not as tight as I'd like.
    I'm gonna use a good set of hose clamps & should be fine. It's likely some metric size I don't have access to readily in the states.
    But I worry too much as is. It works fine.
