On Board Water Build....(pic heavy)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Aug 21, 2016.
  1. Aug 21, 2016 at 7:09 AM
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Well, I have wanted a good on board water set up for a long time. I had all kinds of ideas, read all kinds of threads here and at expedition portal, and I ended up building the set up below. The water set up itself is done I just have to finish some wiring in the truck now. I decided to go with a mobile set up that I could run in my wall tent as well. I am happy for the most part on how it turned out.
    Here are all the supplies:
    LCI Water Can
    Whale Submersible pump
    Shurflo faucet
    12v outlet
    12v cord
    3/8" tubing
    wire ties
    wire loom
    electrical tape
    wire connectors
    Coffee!
    Step 1: Cut the Spout off the Can
    Step 2: Notch the white base on the faucet so you can run the wires outside of the water can. If you don't do this the electrical wires that are not intended to see moisture would end up inside the water can.
    Step3: Install Faucet through hole in can and cut 3/8" hose to length so you can connect it to the pump and the faucet.
    Step 4: Drill hole 1/4" hole in lid for submersible wires to pass through. Disclaimer: I was planning on using a rubber grommet in this hole to make it a tight water seal. however the thickness of the lid made using a grommet impossible. So, I ended up siliconing around the hole after I drilled it. If I had known the grommet would not fit I would have drilled a smaller hole to make the wire a tighter fit.
    Step 5: Run wires through the hole in the lid, cut off the male end of a heavy duty 12v cord, and strip all wire ends.
    Step 6: Do a test connection of the wiring to make sure you have it wired correctly. Here is how I did it:
    Faucet Blue A to Pump Blue
    Faucet Blue B to 12V positive
    Pump Brown to 12v negative
    Step 7: Make final wire connections, place all wire in wire loom, wrap with electrical tape and test!
    There is the water!
  2. Aug 21, 2016 at 7:18 AM
    nevadabugle
    Elko, NV
    The next step is to install a 12v outlet in the bed of my truck. This outlet will be switched off of my auxiliary fuse block and switch panel (build here: https://www.tacomaworld.com/threads/wiring-an-aux-fuse-block-relays-and-switches-in-a-2016.401253/ ). It will be switched so i can control when the on board water is operational. This will help with accidental activation's of the pump.
    Since I have the auxiliary fuse block, switch panel and relays installed already, all I need to do is run the wires from an open relay, to the 12v outlet location and mount the outlet. I'll update picks when that is complete.
    Danactive, Akroedge540 and bobrown14 like this.
  3. Aug 21, 2016 at 8:15 AM
    Danactive
    Danactive Instagram: xxdanactivexx
    Dan
    Upstate New York
    2016 MGM TRD Sport 4x4 DCSB
    Check Out My Build Thread :)
    brilliant! I could definitely see a sink base attachment or a strainer attachment that would work well with that!
    nevadabugle[OP] likes this.
  4. Aug 21, 2016 at 8:23 AM
    nevadabugle
    Elko, NV
    Thanks!
    Danactive[QUOTED] likes this.
  5. Aug 21, 2016 at 8:45 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Very well done and nice write-up NevadaBugle! What would you estimate you have invested in this, excluding your labor?
  6. Aug 21, 2016 at 10:17 AM
    nevadabugle
    Elko, NV
  7. Aug 21, 2016 at 4:32 PM
    Hobbs
    Yep…
    Cool. I like the ingenuity. I am trying to figure out my water situation and enjoyed your post.
  8. Aug 21, 2016 at 5:16 PM
    nevadabugle
    Elko, NV
    I stole the idea from some overland blog I found and then have not been able to relocate.
    Hobbs[QUOTED] likes this.
  9. Aug 21, 2016 at 5:28 PM
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Sub'd
    justinalldredge19 likes this.
  10. Aug 21, 2016 at 5:34 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Ive been looking into the same idea. I want to rig an aux fuse block in the bed (Blue Sea 5025) with all the extra electrical draws run through that. The plan is to make it a simple one wire change to that aux block when I eventually upgrade to a dual battery setup.
    http://beaujohnstontest.blogspot.com/2013/08/12-volt-water-system-scepter.html
  11. Aug 21, 2016 at 7:13 PM
    nevadabugle
    Elko, NV
    Yes. This is the blog I used for my design. Good find.
  12. Aug 21, 2016 at 7:14 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    How do you like that battery pack? I'm looking at building one for with my old battery.
  13. Aug 21, 2016 at 10:01 PM
    nevadabugle
    Elko, NV
    I just bought the battery box. Haven't used it till I tried the water set up. Seems pretty slick. I plan on using it to run the water jug and charge cell phones and tablets in our wall tent. It will be in use for 2 weeks in September. I'll report back later.
