on-dash brake light problem!!??
Discussion in '1st Gen. Tacomas (1995-2004)' started by the408taco, Feb 2, 2010.
  1. Feb 2, 2010 at 3:35 PM
    the408taco
    the408taco [OP] Active Member
    Nick
    San Jose
    97 4x4 Taco SR5
    K&N intake, flowmasters, rancho 5000's, american racing 18's wrapped in BF Muds, WAGG bumper guard w/ some hella head lights
    Hey whats up? I got a 97 sr5 taco w/ a strange problem, recently while driving I noticed my parking brake light keeps coming on when I romp on the throttle, and everytime I make a right-handed turn. I have no idea what it could be I was leaning towards a short w/ the light or a pinch in the brake line caused when I turn... Do you happen to know the problem? Or has there been similar threads with alternatives I can try?
  2. Feb 2, 2010 at 3:43 PM
    erik_found
    erik_found Legendary
    Erik
    Flagstaff, AZ
    99 reg cab
    If it comes on intermittently, that seems like some sort of electrical problem. For me every once in a while the parking brake light stays on after it has been relased and I found if you just give it a little tug and then lubricate the line, it's fine.
  3. Feb 2, 2010 at 3:53 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Have you checked your brake fluid level ?
    2stroke-Taco likes this.
  4. Feb 2, 2010 at 4:30 PM
    herdnerd
    herdnerd Member
    If it is not the fluid level, try adjusting the parking brake.
    I had a similar problem on my 98. Occasionally, when I hit a bump the brake light would come on. There is a switch at the end of the shaft that the parking brake slides in. The parking brake was not adjusted right so the return spring underneath the truck did not have enough force to hold the parking brake against that switch when the brake was released. If I pushed the parking brake in just a little when the light was on, it would go off.
    I adjusted the p-brake and lubed the spring and problem solved.
  5. Feb 2, 2010 at 6:01 PM
    Wreckless_71
    Wreckless_71 WRECKLESS for Life...
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    3" Lift via OME 881's, Bilstein 5100's, Dakar OME 3" leaf packs, MBRP custom exhaust, HID headlights, CB, Canopy, aluminum wheels, upgraded sound system, full set of studded snow tires and wheels, auxilary lighting, more to come.
    Yeah I have the same problem... exactly the same...
  6. Feb 2, 2010 at 6:10 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Same problem here, I figured it was a wiring issue so I've kinda been ignoring it. I'll have to try lubing the return spring and see what happens.
  7. Feb 2, 2010 at 7:38 PM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    I had the same prob, it was not electrical for me, it was the washer at the retun spring holding everything up under that was not letting my cable release. For awhile I tried wd40 but it would just get gummed up. So I took out the washer and my cable releases with ease. no brake light anymore. My 98 had the same prob.
  8. Feb 3, 2010 at 12:19 PM
    another gsxr 1k
    another gsxr 1k Active Member
    Jax, Florida
    03 DCab PreRunner
    Tonneau cover, Fog and dual purpose backup / warning lights, tinted windows, stereo upgrade vent shades
    All my Yotas have been super sensitive to brake fluid level. If the fluid gets down by the low mark the check brakes light will come on.
  9. Feb 3, 2010 at 12:25 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Crawl under the truck and follow the E brake cable to the rear axel and spray the "arm" of the cable guide and move it back and forth. The reason the light keeps coming on is because of the lack of tension on the cable, which in turn doesn't keep enough pressure on the e brake handle pressure switch. That is why the light will go on and off.
  10. Feb 3, 2010 at 1:38 PM
    the408taco
    Nick
    San Jose
    97 4x4 Taco SR5
    yup checked it. its full
  11. Feb 3, 2010 at 1:43 PM
    the408taco
    Nick
    San Jose
    97 4x4 Taco SR5
    I appreciate all the info guys!! thanks a lot I'm gonna try everything that damn lights annoying.. Any one know why my front lockers have trouble going from unlocked to locked? It's practically impossible at a certian point when trying to turn one side (If i remember correctly). I've taken both sides off and greased them up real nice and its still froze?
  12. Feb 3, 2010 at 5:11 PM
    Jzelano76
    Jzelano76 New Member
    FL
    99 Toyota Tacoma 2X4
    I have the same problem, I adjusted the e brake cable and checked the switch and the fluid and every thing is ok. The problem started when it got cold and does it when I take turns. I will try to lubricate the back brakes cable and see how that goes.
    Thanks!
  13. Feb 3, 2010 at 9:36 PM
    ShadowFalken
    ShadowFalken Well-Known Member
    Jim
    Maryland
    10 Off Road
    Raptor stainless bars, Wet Okole covers, RollBak bed cover, PopNLock, Redline hood struts, XM radio factory kit
    What I find usually causes that problem is the bell crank for the ebrake is binding on one or both sides. The cables are not out of adjustment, the shoes are held partially applied in the drum. If you tighten the cables to pull the handle back down the shoes are dragging. You can burn up a set of back brakes in a hurry doing this wrong.
    The weather eventually gets inside the boot on the backing plate and they bind. They are easy enough to unbolt from inside the drum area so you can clean and lubricate them.
    HTH
  14. Feb 4, 2010 at 8:56 PM
    04YodaTaco
    04YodaTaco Well-Known Member
    central NY
    04' Tacoma 4x4 base
    New frame mod. 265/75/16 Duratracs.
    x2 and great advice.
    My truck did the same thing, the brake light going on and off. At first I thought the problem was the e-brake handle and spring being loose. Turns out the "arm" and cable guides under the bed of the truck were the culprit. Mine were seized up and were replaced under warranty. I would check this out first.
  15. Feb 4, 2010 at 9:03 PM
    04YodaTaco
    central NY
    04' Tacoma 4x4 base
    Also great advice.
