???? on the bilstein shocks set up
Discussion in 'Suspension' started by ydoow, Jul 29, 2009.
  1. Jul 29, 2009 at 3:32 PM
    ydoow
    ydoow [OP] Active Member
    Phoenix Az
    09 PreRunner
    With these shocks http://downsouthmotorsports.com/i-1...acoma-pre-runner-4wd-pre-load-adjustable.html set at the 2.5" setting on the front do you need to get a AAL for the back to make it sit level? I might be putting this on my 09 DC prerunner 4x2, not sure if I want to do this or a 3" spacer lift. I,m obviously not going to be doing hard core off roading in a 4x2, just need a little lift so when I go camping , and fishing:)
  2. Jul 29, 2009 at 3:35 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Or get the tsb done if you can. The billys are better than the spacer lift.
  3. Jul 29, 2009 at 3:48 PM
    ydoow
    Phoenix Az
    09 PreRunner
    what about this lift or is the first set up the best for what I need , also what size AAL would I need on the first lift to get it level 1.5" or more?
  4. Jul 29, 2009 at 3:54 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    No dont get that lift. If you do the billys, I think you get the long 2" aal and set the billys at 2.5" and it sits pretty level. Dont quote me though. Someone else that has done this will post.
  5. Jul 29, 2009 at 5:05 PM
    Notty
    Notty Well-Known Member
    5Twenty
    2017 DCSB TRD OR
    Bilstein 5100s OME887 Deaver AAL BAMF CMC ECGS Bearing Replacement Sprint Booster
  6. Jul 29, 2009 at 6:41 PM
    ydoow
    Phoenix Az
    09 PreRunner
    Your truck looks awesome, One question if I don't have the TSB done to the back should I go for the 2" AAL ? Also thanks for posting your pictures that really helps me out a lot , and I'm sure it will help other people out too. Do you think this set up would look OK with the stock rims and tires? I have the 09 TRD DC Pre Runner 4x2, My tires look a little bit bigger than non TRD package trucks could just be me thou, I don't have money right now for new rims and tires:mad:
  7. Jul 29, 2009 at 6:55 PM
    Notty
    5Twenty
    2017 DCSB TRD OR
    You could probably do the 2 inch AAL and be good to go. I would try to fight some dealers and get the TSB though on your 09. It's worth it in my opinion, especially for the extra load capacity. With stock rims and tires it will look OK I think. A lot of people do their builds in steps and run stock tires with a lift. You can alwyas upgrade down the road.
  8. Jul 29, 2009 at 7:13 PM
    ydoow
    Phoenix Az
    09 PreRunner
    What do they exactly do when they do the TSB, is it just an extra leaf spring or do they replace all the stock springs with new ones?
  9. Jul 29, 2009 at 8:59 PM
    Notty
    5Twenty
    2017 DCSB TRD OR
    It's a fourth leaf added to the rear. Since you have a TRD that's all it is. The non-TRD's get the Bilstein shocks that the TRD trucks have I think.
  10. Jul 29, 2009 at 9:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The TSB leaf pack is an all new leaf pack. Not an added leaf to the existing pack.
  11. Jul 29, 2009 at 9:08 PM
    Notty
    5Twenty
    2017 DCSB TRD OR
    Ahhh, thanks for the correction.
  12. Jul 30, 2009 at 6:14 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
